Wife and I are looking down the road a bit to buy a larger tag along trailer to make more room for grandchildren. Need a tag along for ease of climbing entry due to wife's health condition.
For those who own or have owned a Pullrite hitch, would you buy one again or spend the extra money for a Hensley Arrow hitch? Thanks in advance for your input.
__________________ Formerly TECMike:
2002 2WD XLT CrewCab, 3.73 Limited Slip, KC reverse backup lights with separate on/off dash switch, Mobil 1 transmission fluid, Undercover Bed Lid, Bilstein shocks, Gentex K-21 auto dimming/temp/compass mirrow, Michelin LTX/MS tires, Factory Aluminum Wheels, Door Seal Mod, Ford Severe Duty AIS w/Zoodad, Royal Purple 75W-140, Cryo'd Powerslot front rotors and Hawk LTS pads, Fleetrite ELC Coolant, Billet Aluminium Thermostat Housing, Ford Factory Bed Liner - Assembled 08-09-01, in Cuautitian, Mexico.
Well, I never owned a Pull-Rite but I was the Vice President of Hensley Mfg. for ten years before licensing the next generation of that design from Jim Hensley. Jim no longer has anything to do with the company that was named after him.
The Pull-Rite, Arrow and the 3P all provide a forward pivot point that shortens the lever arm between the rear axle and the hitch ball. The Pull-Rite physically moves the pivot point forward while the Arrow and the 3P virtually project it forward. In fact that is where the name 3P came from, Pivot Point Projection.
I know, not really what you asked, but I didn't want you to think you were being ignored...
ProPride, Inc.
800-960-4767
Reason: Pull-Rite for Page Ranking
Do a thread search on both Hensley Arrow and Pullrite. Lots of dicussion on both. Sounds like both are good, quality products. I've heard that the price on the Hensley Arrows has come down a bit recently.
2006 F350 - Amarillo Package,loaded with all the toys, 4" MBRP cat back exhaust, Autometer EGT gauge, Viper 791XV auto start/cool down timer/alarm, Pioneer AVIC-D3 navigation/XM Radio/Sirius, 2.5" Tuff Country Leveling kit, KC Hilights front & rear, Dieselsite.com coolant filter, SkyJacker dual steering stabilizer, Firestone Ride Rite airbags w/onboard compressor, Kleinn Train Horns, Bilsteins all the way around, Recon LED's in the back, Programmed with the SuperChips 1805 Tuner always set on Tow Safe for a little extra get up and go.
30' Cardinal 30TS 5th wheel. The weekend home away from home.
"The early bird may get the worm, but the second mouse gets the cheese."
In my post above the letters P and R (which I used for Pull-Rite) were somehow magically turned into the words Page Ranking so the one sentence does not make any sense.
It should read...
The Pull-Rite physically moves the pivot point...
ProPride, Inc.
800-960-4767
There should be an edit button at the bottom of your post. So you can edit and correct it yourself.
Yes, I see that now. Thanks. However, if you read it when you're not logged in it isn't there. So, I go up top and log-in and then come back down to post the reply because I figured the forum has user edits turned off. I should have looked at the post again instead of assuming. I use vBulletin for my own MyRVTalk forum so the bit of knowledge about user edits locked my brain from seeing.
