01 chevy 6.5 turbo diesel smoke - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Old 05-22-2008, 01:32 PM   #1 (permalink)
ok im not a diesel guy but i am a mechanic so i have a basic understanding of the basics of diesel i just don't have any experience. Now the problem is my buddys 01 chevy 6.5ltr (I think) diesel seems to smoke when the truck idles for a min. you sit at a stop light for like 3 min and then when you take off it puffs a little blue smoke. my first instinct was the turbo but im not so sure after reading some other stuff on glow plug issues. I do performance upgrades and tune gasoline engines using wide band so i know what color smoke means but i don't know if maybe diesel smokes blue?? anyway anyone with any knowledge please help. Thank you in advance.
hpiperformance is offline
Old 05-22-2008, 07:17 PM   #2 (permalink)
Although there are some very good mechanics on this site, you might be able to search the forums at "the diesel place" website and get some answers.
Scott
2000 F250 Ext Cab Long Bed 7.3 Auto
Performance Red
Ford Severe Duty AIS w/Zoodad and fender sleeve, MBRP 4" Turbo Back, FRx
Born in KY on 10/05/99
2005 F250 Lariat, CC, Short Box, FX4 - SOLD...loved that truck!
Arizona Beige/Tan
Magnaflow 4" Cat back
Leveled w/ Toyo Open Country A/T 285/75-18's
Bilstein 5100's
Born in KY on 12/07/04
Green2D is offline
Old 05-22-2008, 08:49 PM   #3 (permalink)
I think all 01s were Duramax. You really need to know for sure what motor the truck has before we can help.
1999 F250 2WD RC/LB posi AIS, Superchips DPI propane, 4" turboback exhaust, gauges, Edge Evolution tuner [looking into a Propane chip] Pics
SMOKESKULL is offline
Old 05-23-2008, 10:45 AM   #4 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Smoke at idle could be from many sources.
1. Bad turbo seals allowing incomplete burn of the oil.
2. Too much blow by, but I think that should be seen under power as well.
3. CCV letting too much oil out of it.
4. It could be over fueling at idle as well.
I think in 01 there was a option for the maxi or 6.5, but people are right you need to find out what motor it is.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
Old 05-27-2008, 02:47 AM   #5 (permalink)
Sounds to me like it needs injectors.
Nick
94 F250 IDI T, ZF 5, r/cab, 4x4
04 Dodge CTD, r/cab, 4x4, 48re 4" exh, intake, elbow
94 K2500 6.5, e/cab lb, 4L80e, 3-4" exh, intake.
94 Ram 3500 4x4, r/cab, NV4500 alum fb, work in progress
87 M-B 300D, turbo, custom 3" exh
lots of old diesel iron and gas M-B's
nberchem is offline
Old 06-24-2008, 11:50 AM   #6 (permalink)
its
its burning oil if its blue and if its a light grey or white its water or coolant
johnnyturbo741 is offline
Old 06-24-2008, 12:14 PM   #7 (permalink)
if it's an 01 then it's a D-Max, if the truck has less then 200,000 miles on it check the fuel in the oil, when you find it. then take to a stealership and get a new set of injectors. this is the poor filtration taking out the injectors by ball seat erosion. you can also use your scantool and do injector kill test to find a leaking injector, also try cylinder balance rates. this will show a bad injector.
Jay
2003 F-350 4x4 CCLB QUADZILLA FCHIP W/COMMANDER, BD TORQUE CONVERTOR AND ACC. BODY, AMSOIL FLUIDS, MAGNA FLOW DUAL EXHAUST, BULLYDOG AIR BOX W/AMSOIL FILTER
daytondiesel is offline
Old 06-25-2008, 10:07 AM   #8 (permalink)
its not a d max its a 6.5 cause the duramax didnt come in the trucks till 02
Old 06-25-2008, 11:19 PM   #9 (permalink)
01, not 02
Unless these ads are wrong?
Cars For Sale: Car Details - AutoTrader.com
UApilot
2008 Dodge QuadCab 2500 Big Horn, CTD, 4x4, auto, tube steps, clearance lights, on-board air, air horns, air-ride coming. 300hp/540lb.ft. stock
2006 KTM 950 Adventure S
http://community.webshots.com/user/cumminspower
UApilot is offline
Old 06-30-2008, 09:02 AM   #10 (permalink)
i seen a some 6.5 in 02
Old 07-30-2008, 12:38 PM   #11 (permalink)
The 6.5L was replaced with the 6.6L Duramax in 2001. Some heavy duty 1 ton "classic" models might still have the 6.5L in 2001, but very few.
The 6.5L is still being produced for military and industrial purposes.
Casey
1996 E-350 Van Cutaway, 7.3L PSD, E4OD, Dana 70 dually with 4.10 gears, Reading enclosed utility body, 160K miles....
1995 Chevy K1500 Tahoe, 6.5L TD, NP241, 4L80E, 3.42 gears, Kennedy Diesel OPS harness and FSD cooler kit.
1981 Chevy 3/4 ton converted to 6.2L TURBO DIESEL, bored .040" over, 6.5L pump, turbo injectors, DSG timing gears, lowered compression w/ceramic-coated pistons, 17 lbs of boost....4 speed auto, custom built 4" exhaust, 4.10's, keyless entry, etc. etc....See my photos
arveetek is offline
Old 10-30-2008, 03:38 PM   #12 (permalink)
glow plugs have nothing to do when idling at a stop light. blue smoke means you are burning oil, But diesel fuel is an oil. so it could be a number things.
Phil the lineman is offline
Old 10-30-2008, 03:40 PM   #13 (permalink)
can anyone here tell me how to get my 97 6.5 to black smoke on comand?
Old 10-30-2008, 04:20 PM   #14 (permalink)
Strokin' 6.0's Avatar
With the Dodge advertisements and now Chevy posts, is this still a Ford diesel forum???
The 6.5 was still an option in '01; my late-wife's father still has the one he bought new.
My vote is for injectors.
Fred
2004 F-350 CC DRW LB FX4 4x4
Oxford White/Arizona Beige
King Ranch
Herrin Hauler bed
4.10 Trac-Lok
Reman'd 6.0L @43,956 miles
Reman'd Turbo @54,814 miles
Strokin' 6.0 is offline
