1996 International 4700 DT466 Turbo - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 09-10-2006, 10:48 PM Thread Starter
When running down the highway if you have any incline to put a load on the engine it jerks, dosn't die just jerks, any ideas on how to get diagnostic codes or any help with what to do, if there is no load on the engine it will run 70 all day long, but first incline it starts bucking and jerking. NEED HELP.
OKShadow is offline
post #2 of 7 (permalink) Old 09-11-2006, 07:37 AM
Re: 1996 International 4700 DT466 Turbo
You should have an engine diagnostic button on that year truck, it is a small black push button, with the key on and engine off just press it and count out the check engine light flash sequence. However it may not be storeing any codes. Have you checked your fuel filter and your prefilter fuel/water seperator screen behind the fuel filter?
06 3500 QC/LB/SRW/4.10/48RE/5.9/ Inferno red pearl
04 Hitchhiker 34.5 RLTG, Kubota B7610
trucky is offline
post #3 of 7 (permalink) Old 09-12-2006, 08:16 PM Thread Starter
I checked it dose have codes in it, but who has a list of what the codes are. I havn't checked the fuel filters, at first that was my first idea, I had bad fuel. Thanks
OKShadow is offline
post #4 of 7 (permalink) Old 09-13-2006, 09:36 AM
Post the code numbers, I"ll find there deffinitions and post later, or someone may post them sooner for you. Make sure you check your prefilter screen behind the fuel filter, it is a small plastic upright canister in the same fuel line as the filter, it unscrews counter clockwise, remove the screen and clean it then clean the screen housing and make sure you prime the housing or the you'll never keep the engine running.
trucky is offline
post #5 of 7 (permalink) Old 09-18-2006, 02:28 PM
Post all the 3 digit codes and I can help.... I have a list somewhere. Does it just jerk or does it lose power?
2000 F-350 CC, SWB, 6 speed, SRW, 4X4
1985 Mercedes 300D
1999 International 4900 DT466e 250/660 Allison MD3060
GreyHorse is offline
post #6 of 7 (permalink) Old 09-18-2006, 02:53 PM
May not be the same situation but we had a fire truck with a DT466 tht had periodic losses of power in an unpredictable way. Threw no codes. Int'l has a TSB out on the turbo actuator control solonoid and mechanism. Int'l replaced our entire turbo assembly and the problem went away.
'05 F350 Lariat DRW 4X4 6L Auto, stock.
Above replaced '91 F350 XLT Lariat DRW 2X4 7.3L 5 speed man.
jbdawson is offline
post #7 of 7 (permalink) Old 09-19-2006, 11:47 PM
fourhatz's Avatar
Your problem was on the 2004 and up engines. It does not apply to his engine. He needs to check codes and check his fuel pressure while under load.
96' F-250 4x4 SB Crewcab, 3.55 gears, rebuilt E4od, Air bags, 2" leveler kit, 10 disc cd changer, Tymar intake, Tymar 4 pos TS chip, 4590 cooler, boost, pyro(pre-turbo) & tranny temp AutoMeter gauges mounted in pillar, Diamond eye 4" exhaust with lost kitty, Tymar 3x4" downpipe, Warn hubs, Prodigy brake controller, Hypermax intercooler, CCV mod,17* HPOP, stage 1 injectors, fpr. Rebuilt tranny with pump and valve body mods, 3 disc torque convertor. Diesel mechanic 20+ years
fourhatz is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
