1996 International 4700 No Crank No Start - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 03-13-2010, 07:18 PM Thread Starter
Hey guys... I have a problem with a 1996 International. It has a T444E and it does nothing. It doesn't crank with the starter button. Here is what I have done. I have checked wiring and fuses. I had a blown fuse for the instrument cluster another thing is when that fuse was blown I had no check engine light on, replaced that fuse and the check engine light flickers along with that I have a relay on the firewall on the engine side clicking very rapidly. I have a problem with the glow plug relay and it has power on both sides of the control circuit (don't think that is right). Truck supposedly was running b4 parked for two years. I can make the truck crank only by bypassing the starter relay. It will run on ether. I don't know how to check flash codes. I checked for power and ground at ecm and edm. ECM has 4 powers and 4good grounds at the terminals. It also has 1 power and 1 good ground on EDM. The fuses are all good in fuse box and battery box. Where do I go next.
timmcgraw67 is offline
post #2 of 5 (permalink) Old 03-14-2010, 10:06 AM
Scottb NY's Avatar
i would check for a bad ground first. Use an ohm meter, the connection could be resistive.
2015 F-450 King Ranch on order 01/29/2015. Arrived at the dealer on 05/13/2015. Delivered 05/19/2015. Fisher plow has been transferred to the new truck.
2008 F-450 Lariat loaded on order 7/3/07 delivered 9/13/2007 Pueblo Gold and all the goodies except Nav radio and moonroof and Fisher 8'6" X-blade
2005
F-350 Lariat LOADED CC SRW LB 6.0 SOLD
Med. Wedgewood Blue
All Options except moon roof
8'6" Fisher X-blade SS
2003 PSD 6.0 Lariat CC SB SOLD
All options but the moon roof
Scottb NY is offline
post #3 of 5 (permalink) Old 03-14-2010, 12:21 PM Thread Starter
does anyone have a wiring diagram for a t444e of 96 year?
post #4 of 5 (permalink) Old 05-13-2014, 12:24 PM
Johndeere guy
Guest
Posts: n/a
97 international 4700 t444e
I am having the exact same issue with my truck only difference is it is a 97 model what did you ever figure out from your experience with this
post #5 of 5 (permalink) Old 02-21-2015, 05:11 PM
I just bought International 1993 4700 with Navistar engine I parked it yesterday and when I try to start it today it did not crank or no click or anything battery is full all lights and panel is alive I turned off key switch before turning off engine, the solenoid is bad I have a wire tied up to the lever to turn it on or off, can someone help me to understand what could be the problem and what should I check? Please
Thank you.
rrpakman is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
