General DieselDiscussion about diesels in general. All brands are welcome, please refrain from brand wars. Discussions about types of diesel fuel also go here.
Anyone know the differences between the ZF-5 speed manual in the 97 F350 gas and diesel trucks. I am looking at buying a 97 F350 with a 460 gas motor and will be converting it to a 5.9 Cummins. I am just wondering if this tranny will work?
1997 F250 HD 4x4 5speed Reg Cab, 4" MBRP exhaust, 1.0 turbo housing, Tymar Intake , 17* HPOP,Swamps 150cc, TW 4 position chip, Dana 60 w/RSK, Crossover steering, sittin on 35's
Gas has a lower first and works up to an equal 4th and 5th - this helps overcome the lower torque rating of the gas engine as compared to the diesel when you are trying to get a load moving.
I was considering the change to add to 3.08 gears to raise my mileage - the lower first of the gas tranny should compensate for the higher speed ratio in the differential. I finally decided the truck is OK as is.
Dave / Believer45
__________________ THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
I knew the ratios, I guess my question is: Is there any strength issues on the gas tranny? Would it hold up to a Cummins as well as a the diesel version? Thanks for the info though Dave.
Dave
The ZF-5 has issues with the synchronizers. However there is likely no strength difference between gasser and diesel versions. You may have a hard time coming up with an adaptor to go from Cummins to big block Ford.
1997 Ford F350 SRW 7.3L PSD
1985 Ford Ranger 2.3L 5 speed
1966 Mustang 200 I6, auto, 4 wheel disk, power brake retrofit, Corvette master.
Former vehicles, 1994 E350 7.3L IDI, 1985 International 1654 rollback, 6.9L IDI, (2) 1994 Ford E350 7.3L IDI, 1985 Ford F350 DRW 6.9L IDI, 1985 Ford F350 wrecker 6.9L IDI.
*dual ASE Master Certified, Automotive, Medium & Heavy trucks*
Owner / operator, Patriot Automotive, N Ridgeville OH
No - a "gas" ZF has a 385-block pattern, and a "diesel" ZF has the IH pattern, which I've been told is basically the same 6.9 on up. There was also a 3rd one that bolts up to a 300-351, but I forget what the family designation is. (is it just Windsor?) To complicate it, they're all a 1-piece bellhousing/case, but allegedly the internals are interchangeable, i.e. the "gas" gears will fit in a "diesel" case, etc.
Sadly, I've been told the lower cluster is all one piece, so you can't mix and match gears - I wanted to do that in my personal pickup with 3.55's, swap in a gasser granny first gear and keep the 2-3 gears from the diesel. It'd be a big step from 1 to 2, but it'd sure be nice for picking up a load on a hill.
I think I was told once that the Cummins conversion shop over in the Bitterroot valley (Montana) had a custom one that they sold - but I could be wrong. Now if I could remember what their name is.......
I just call it the smallblock pattern. 240/300, 221/260/289/302/351W, 351C/a few 400's, 3.8/4.2L V6's. I think the early modulars used the smallblock pattern too, but don't quote me on it.
Reason: fix quote
Well that sucks, I don't think anyone makes an adapter to go from the Gas version ZF-5 speed to a Cummins.
did you check cumminscoversions.com?? i thought i remember seeing a cummins to big block ford adapter. if so, "big block ford" refers to the 385 family, usually.
Travis
'03 F350 Dually, 6.0, Supercab, longbed, 4.10 LS, sport pkg, extremely RED, STRAIGHT PIPED, SCT Xcalibrator, full guages
- Job1 programming, Harpooned, Skweeker Mod, Zoodad Mod
- Did that thing that you're not supposed to talk about
'79 Bronco, 468cid Ford 460 marine motor, C6/NP205
Previous -'99 F250, Rg Cab XLT, 7.3/6spd, 3.73
Project truck
- '96 Cummins, 215hp/5spd, Diprocol guages, Plate & AFC full fwd, hi-capacity external lubrication system
To add: 2 1/2T axles, 46" goodyears, etc.
Reason: fix quote
As stated in my original post I am wanting to buy a Crew Cab F350 4x4 with a ZF-5 and a 460 gas motor to convert it to a 12V 5.9 Cummins. What are some other things I am going to run into? Dash gauges? fuel tank problems? fuel line problems? Would I be money ahead to just find one with a powerstroke and then convert it? Problem is most of them are 5000-7000 dollars more than an otherwise equivalent gas powered truck.
