2.2l Perkins Diesel (1983 Mazda Truck) ????? - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 04-18-2012, 06:44 AM Thread Starter
This truck has around 180000 miles on it. The problem is it want crank fast enough to start. Had the pump and injectors checked (rebuilt a few years ago) and they work. Took the starter and had it checked at a starter rebuild place and they said it worked. If I take the glow plugs out the engine turns over somewhat pretty good, but when I put them back in it is a slow crank (Injectors lines currently unhooked.) I took the belt off the alternator to lessen resistance and used a diesel tractor that starts good and used heavy jumper cables from it to the battery cables to try and get it to turn over faster. It has a 5 speed manual transmission and the clutch was held in while trying to crank. I checked compression even as slow as it was cranking and all cylinders showed from 375+ and it hasn't been started in a while. The last time I had it started it ran great, but as soon I as turned it off it was a slow crank. Wonder what could be causing it to be so tight or hard to crank?
2002 F-250, PSD, XLT, 4x4, SB, 3.73, 6 speed, x-cab, gooseneck, T-red
jltrent is offline
post #2 of 13 (permalink) Old 04-18-2012, 09:52 AM
RT
RT's Avatar
Just like on our rigs - bench testing the starter is next to useless. A lot of starter motors will spin on the bench but don't have the oomph to spin a diesel. If you are sure your batteries are fully charged and the cables are all good, clean, and tight - then I'd replace the starter motor.
RT is online now
post #3 of 13 (permalink) Old 04-18-2012, 11:01 AM
Did the shop just spin test the starter or load test it? A spin test is nearly useless, as RT said. They should have put it in a test stand that will energize it and then bring it down nearly to a stall to check the amperage draw. That's the only way to really test it. If your battery and cables are good then chances are they didn't load test the starter, otherwise it should crank OK. Perkins is owned by Caterpillar, in case you need a parts source.
1693ta is offline
post #4 of 13 (permalink) Old 04-18-2012, 12:59 PM Thread Starter
I bet they didn't load test it. I will call them and see if they can do this. Thanks for the info. Where in this great country could someone maybe find a starter (reconditioned) to fit this. If I have to go through Cat I might just as well sell it for scrap metal as I bet it would cost a war pension Thanks again.
jltrent is offline
post #5 of 13 (permalink) Old 04-18-2012, 02:04 PM Thread Starter
I found this on Amazon.Com and went ahead and ordered it. I will know in a few days if I wasted my money or not. The last time I had it started it ran perfect, but could never get it to turn over fast enough to get it back started and that has been a few years ago. The truck would get around 40 mpg and that 5 speed would go almost 80 mph. It had good power on the low end , but not much on the top end. The motor number is gb 4.135 which stands for 4 cylinders and 135 cu. in. The engine is simple without the environmental BS on it just like working on an old farm tractor as I have done a lot of that. It has 59 hp and sounds like an old tractor running, pecking around. If I can get it running I will fix it up pretty good as the cattle have been rubbing around it for a while. It doesn't have much rust on it. If I can't get it running then will probably sell for scrap.
jltrent is offline
post #6 of 13 (permalink) Old 04-18-2012, 02:22 PM
I suggest you take your current starter to a good electrical shop for an overhaul at some point to have for a spare. You'll get a better job then from a parts store exchange. We do that with the starters for the 4-236 Perkins engines we have in a number of our older rollers. Never hurts to have a spare. Perkins can be a bear to start if you have had the fuel system apart. When you put the injector lines back on be sure to bleed them good at the injector.
SW VA, huh? We'll be going thru there on the way to Charlotte for the All Star race in May. If I see an 82 Mazda diesel running around I'll know who it is!
1693ta is offline
post #7 of 13 (permalink) Old 04-18-2012, 04:34 PM Thread Starter
Hope you see me driving it around. Just last week took a CAV injector pump apart for a 3600 Ford tractor and got it back working, it wasn't easy to get it back started though. I know several MF tractors that have the 236 Perkins engine. I live in the very tip of SW Virginia close to the Tri-State Tunnel (KY-TN-VA) is.
jltrent is offline
post #8 of 13 (permalink) Old 04-19-2012, 06:11 AM
Good luck with your truck.
Used to truck thru your area quite regularly back in the '70's and '80's on my way to the Gulf or the Southwest US. Kingsport was a regular stop also. It's a beautiful part of the country. One of my favorites. We still go to Bristol every other year for the August race.
We used to have some Murphy Diesel gensets that I got parts for from the outfit that now has the rights to the engine. Ditec Diesel in Mulberry, Fla. Fellow named John owns it. Good guy. Last I knew he also was a Perkins dealer, as well as several other makes. 1-888-823-2888
He would probably be a better parts source then Cat or Mazda. Haven't talked to him in some time, but he always treated me fairly.
1693ta is offline
post #9 of 13 (permalink) Old 04-19-2012, 06:43 AM Thread Starter
Thanks for the information I may need it as I have a couple tractors with Perkins Engines. I live about an hours drive from Kingsport and there is a used Farm Machinery place right next to the raceway I go to a lot, but during race week they use the area for parking.
jltrent is offline
post #10 of 13 (permalink) Old 04-19-2012, 06:49 AM Thread Starter
The old truck was my dads he bought new and passed away in 1995. I know it is not much, but I have always wanted to get it running and back in decent shape if possible. If I could get the engine running good maybe I could find a Ranger or something that it could possibly be put in. I checked the compression, as I have gauges, and it seemed all cylinders were about even and had plenty.
jltrent is offline
post #11 of 13 (permalink) Old 04-19-2012, 08:58 AM
you know you can get that starter from napa. change the oil and filter.put the fuel inlet line from lift pump in a bucket of fuel mixed with atf{1qt in 5 gals}to help lubricate fuel system internals.put in at least an 800cca battery.clean and tighten all battery cable AND ground connections.leave fuel lines 1/8 - 1/4 turn loose.if you can get 2 lines spraying it should start when you lock them off...diesel formulation was changed in 94 and again in 07. that engine was designed to run on original form of diesel NEEDS extra additive for lubrication of fuel system.should put additive with lubricity and cetane enhancers in EVERY tank of fuel.goes for ANY diesel built before 94...jd
trukdoc is offline
post #12 of 13 (permalink) Old 04-19-2012, 09:31 AM Thread Starter
As the engine turns over it now sprays diesel out the pump were the injector lines attach. I worked on the truck a few years ago (2003), had the pump rebuilt and injectors checked, but never could get it to crank fast enough to start very often. After spending around $700 on it I decided to cut my losses then. I have more time now and going to try again, i have a starter ordered and will go from there (if that doesn't do the trick then it is ready for the bone yard) If the new starter will turn it over fast then I will drain the tank, fuel filter and try and pump new fuel through the system as it has a hand pump on top of the filter and go from there. The last time I had it running it ran as good as it ever did, just wouldn't crank and couldn't find anybody close to were I live that knew anything about these. I am big on maintenance as I put Power Service and algae additive in every tank full I put in my tractors and 7.3 truck. Thanks for the information.
jltrent is offline
post #13 of 13 (permalink) Old 04-20-2012, 09:44 AM
nitrogen's Avatar
BEFORE you put that new starter on, do a voltage drop test between the positive post on the battery, and the pos post on the starter. then do the same on the negative side. simple test take a set of booster cables and go from the battery to the starter with both of them. i bet it solves your problem
nitrogen is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
