2001 Int. 4700 w/ T444E dies while stopped in gear - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 12-28-2007, 10:26 AM Thread Starter
I have a 2001 International with a T444E engine. Just the other day the fuel filter light came on so I changed it. When I changed it, I filled the resivor back up with diesel and secured the cap. There should not of been any air in the system.
The very next day the truck started dying at stop lights. It would start back up and run fine. I can let it run in park with no problems.
Does anybody have any sugestions? Should I crack the injectors anyways?
dpatt420 is offline
post #2 of 8 (permalink) Old 12-28-2007, 10:42 AM
weasel79's Avatar
Re: 2001 Int. 4700 w/ T444E dies while stopped in gear
Souds like a problem with the oring on the cap. I would double check the roring and make sure it doesnt have a nick in it or a cut.
2003 F-250SD XLT X-Cab short box March 03 6.0L Torque shift, manual 4x4 superwinch hubs, 121,000 miles,315/75/16 BF Goodrich mud terrains, autometer boost/fuel psi/tranny temp, AFE 4" straight pipe,
weasel79 is offline
post #3 of 8 (permalink) Old 12-28-2007, 12:29 PM Thread Starter
does anybody know if these truck have a bleeder for air in the system, or do you have to crack the injectors.
can someone tell me the best process of bleeding air out of the system?
I dont know a lot about diesel systems.
Thanks.
dpatt420 is offline
post #4 of 8 (permalink) Old 12-28-2007, 01:42 PM
klhansen's Avatar
My Photos: (180)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: dpatt420</div><div class="ubbcode-body">does anybody know if these truck have a bleeder for air in the system, or do you have to crack the injectors.
Thanks. </div></div>
There's no bleeder for air in the injection system. Just drive it like you stole it for a while, and whatever air is in the system will soon purge thru the injectors. I doubt that your stalling problem is caused by air in the fuel system, but a check of the pressure delivered by the fuel pump might be in order just to be sure.
Your stalling problems may just be coincidental to your fuel filter change. It sounds like you may have a problem with the CPS (Camshaft Position Sensor), which is essential to keeping the engine running. It often cuts out intermittently. Ford has announced a recall of the CPS, having just recently come out with a new and improved (well, cheaper) CPS that's grey instead of black. I imagine that International has the same one available. Ford part number is F7TZ-12K073-B for about $20-30 (depending on how hungry the dealer is). Sorry, don't have the corresponding International #, but if you went in and asked them for the replacement for 1825899C93 (the old black one) they'd probably know what you're talking about.
), AIS,
regulated return,
klhansen is offline
post #5 of 8 (permalink) Old 12-28-2007, 01:48 PM Thread Starter
Can you tell me where the camshaft position sensor is?
dpatt420 is offline
post #6 of 8 (permalink) Old 12-28-2007, 01:54 PM
spg
Its mounted on the front timing cover on the pass side of the engine. It has a 2 wire plug going to it and is held in place by a 10mm bolt. Very easy to change and is most likely your problem. You can buy them from thepowerstrokeshop web site about as inexpensive as any place. It would not hurt to carry a spare.
2001 International 4700LP T444E 210HP Fuller Six Speed 4.10
spg is offline
post #7 of 8 (permalink) Old 12-28-2007, 03:45 PM Thread Starter
I cant get my hand in there. Does the radiator and fan need to be removed?
dpatt420 is offline
post #8 of 8 (permalink) Old 12-28-2007, 07:32 PM Thread Starter
Cam Sensor. Thanks everyone.
dpatt420 is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
