ah... the good old gm ground problem. CHECK ALL GROUND WIRES!
battery, frame, engine, cab, ect. gm is known for bad grounds on them. my 02 has a bad ground from engine to cab, headlights would randomly dim.
my neighbors 06 gmc has same issue as yours. brake light stays on, parking brake light and engine lamp also. his was a ground wire from frame to cab.
PLAY TRUCK
1986 F250 6.9,ATS turbo, np435, BW1356, hp 60,welded up sterling 10.25.
converted from 2wd to 4x4
sittin on 36x12.5 goodyears
GETTING CONVERTED TO SHORTBED AS WE SPEAK!
TOW RIG
2002 gmc 2500hd 6.6 duramax 5 speed allison
4x4 extened cab.
2000 F550 Lube Truck (Work Truck)
Certified PA Inspection Mechanic
i'd rather be 6.9'n than cummin or strokin'!
