3126 Cat Engine - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Old 09-23-2008, 11:55 AM   #1 (permalink)
3126 Cat Engine
Got a 2000 Freightliner FL80 with a 3126 cat motor. Complaint of a hard start problem. Replaced fuel filter and added injector cleaner to system. Found oil in fuel filter when I went to replace it. What would cause oil to get into the fuel system and how? Any remedies for this? Any help would be much appreciated.
tleisner is offline   Reply With Quote
Old 09-23-2008, 08:02 PM   #2 (permalink)
Dave Haven's Avatar
My Photos: (16)
First off, Welcome to TheDieselStop.com!
The injector o-rings are leaking high pressure oil into the fuel rail.
Replace the injector o-rings. That will keep oil out of the fuel, and should cure the hard start problem.
Dave Haven is offline   Reply With Quote
Old 09-24-2008, 09:47 AM   #3 (permalink)
Response
Thanks for the response Dave. Will be looking to this site for more info.
Old 11-24-2008, 11:04 AM   #4 (permalink)
3126 cat poor running
hope this is the right way, any how here it goes. Engine is in a Sterling truck. Codes 164-11 injection control pressure problem and 164-00 erratic injection control pressure. Have replaced injectors, huei pump, and pressure sensor. During test performed, with gauge installed in oil rail and laptop connected at idle, gauge will read 2000 to 3000 pressure, but laptop display will read 1450 and diag will also display. Engine runs but has no power. Have checked wiring harness for damage but not harness to ecm. Any thoughts would be helpful.
cenrep is offline   Reply With Quote
Old 11-24-2008, 11:56 PM   #5 (permalink)
My Photos: (33)
Oil in the fuel is injector O-rings with out question. The codes you have back that up.
Pull all 6 injectors and replace the injector O rings. Check the injector cups for coolant seepage buy pressurizing the system and visually inspecting for coolant leaking around the press fit injector cups.
00'F350 psd CC Drw 2wd Bright Amber Western Hauler, exhaust brake transfer flow 50 gal tank tool, 30K Cody goose neck hitch, hawk pads, cryo'ed rotors, stainless lines, 380,000 miles
02' Psd Excursion Limited ultimate Estate Green 7.3L Auto 2x4 hellwig swaybars and rancho 9000's. 381,000 miles.
1993 F-superduty (F-450) 7.3L Gutless non turbo 2x4 Auto, Tire eating S.O.B. 12,750lbs 80,000miles lincoln Vantage 500 Duetz bolted in the back.
1994 7.3 I.D.I.T. factory turbo, auto 2x4 DRW with lots of upgrades, 11 transmissions under 100K factory warranty. 280,000 miles Currently Cavitated and parked.
96 F-800 24'flat 5.9L cummins, 4spd allison juice brakes.
89 F-800 6.6L 5+2 27,00lbs light weight with National 556A crane behind the cab.
2006 T800 KW 550 C-15 18spd 22K front, 52K rears murray ramps, 195" W.B. CA spec heavy haul SOLD
2006 Murray 16 tire professional lowbed SOLD
1996 fetherlite 4 horse GN, Walton 18' 14K tag tilt equipment trailer.
Dualie is offline   Reply With Quote
Old 11-25-2008, 02:28 AM   #6 (permalink)
I am assumeing you have just replaced all the components you have listed in the above quote trying to fix this problem? What year is the engine.Does it have The External mounted Injection pressure regulator On the Pump?What kind of software are you useing is it CAT ET ? If so you should be able to go to special tests in the drop down diagnostic menu.Run the Inj pressure Step up test and Monitor actual pressure VS demand.If you are getting 3000 psi out of a Rail port at Idle with a external gauge The IPR is wide open.It seems The ICP sensor is telling the ECM it is only seeing the 1450 psi you describe,With the engine off,Turn the Ign. key back on.Then pull the plug off the ICP sensor,Give the laptop a few seconds and it should throw a High voltage code or Open for the sensor.If not check the voltage with a voltmeter at the plug should be 5 volts.This is just a quick way to see if the ECM is responding to the circuit.If you want to pm me with more info we may be able pin this down but, I need to know a few more specifics on what else you have checked if possible.
07,F-250 4X4 6.0 Torqshift, Lariat, Highline package, S/C LWB.
grounder is offline   Reply With Quote
Old 02-28-2012, 05:41 PM   #7 (permalink)
Thumbs up
dualie is right replace injector o rings change motor oil clear codes and fire it up
87LT500R is offline   Reply With Quote
