General DieselDiscussion about diesels in general. All brands are welcome, please refrain from brand wars. Discussions about types of diesel fuel also go here.
Hi
I have twin 3208 caterpillars in my 42' boat and one has started to blow black smoke abd leave a film on the water could this be from bad fuel I have cleaned and replace the fuel filters and check the valves but it still blows black smoke will this clear up or could I have a problem with the injector pump the engine sounds fine I live in baja and I can't find anyone in town that knows for sure any information would be help full
thank you
alan
1994 7.3 I.D.I. Navistar 444 CI
ATS Factory TURBO E4OD Red On white Crew Cab DRW 4:10 w/ AUBURN LIMITED SLIP
3" ATS Exhaust and turbo housing, Banks Trans Command, calibrated pump, K&N filter, Gruss style coolant filter, 203K+MI not a lick of trouble with the motor. now on 16th trans. 10 under factory 100K mile warranty
Alpine CVA-7878 XM radio 6cd changer 3 8" phoenix gold subs 75x4 Sony mobile ES gold 4ch amp, Sony 500W 1ch amp MB quart components in Q forms kick panels. 1 farad cap.
Pro car parts jewel cut headlamps and turn signals
APC clear cab markers, suvlights.com harness silverstar bulbs and L.E.D.'s in the fenders. IT's paid for and its MINE!
Family Toys and tools,
00'F350 psd CC Drw 2wd Bright Amber Western Hauler
SOLD 01' Peterbilt 330 4Dr. Texas trucks conversion cAt 350hp
02' Psd Excursion Limited ultimate Estate Green helliwig swaybar 101K miles
1996 fetherlite 4 horse GN, 2003 sooner 6 horse GN with midtack
Usually black smoke means too much fuel or unburned fuel. As mentioned, could be a bad injector. How long has this gone on and what was it doing before this all started? Maybe some fuel injection cleaner in the system might work....
1999 E-350 Cub Wagon, 7.3L Power Stroke, E4OD, 3.55
1990 E-350 Club Wagon, 7.3L IDI, E4OD, 3.54LS
1983 F-150 2x4, 4.9L, C-6 w/GV-OD, 3.55 Farm pickup
1981 C-8000, 3208 CAT, RT-6510, Rockwell SSHD Tandems (Swap)
1977 K100C, NTC-350, RT-1110, Tandem
1977 Transtar II, NTC-290, RT-9509 Single
1977 Transtar II, Formula 290, RT0-9513, Tandem
1974 C-750, 391CID, Clark 5 speed, Eaton 2 speed
it hasn't been very long it was running find before but now when I start the engine it continues to run until it runs out of fuel it also runs at high rpms I have loosened the injectors and only one will leak any fuel I have been able to get a mex mech. to come out to look at it but this is mexico and you don't know if they will show up I will try the injector cleaner what brand would you recommend for diesel
sorry it has been so long but have been having problems with internet
what I found was the injector pump had a screw come loose and it got in to the piston springs and caused a lot of problems was able to order the parts and I'am now waiting for them to get here to baja so that I can rebuild the pump
thanks for your info this site has been very helpfull
thank you
alan
