3406B low power - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Old 10-10-2009, 10:23 PM   #1 (permalink)
3406B low power
i have a 1993 peterbuilt with a 3406 b model engine. it came from california. i was wondering if there is a valve that limits fuel until so much boost. the truck is unstoppable once it reaches higher boost levels. it hardly smokes at all more like a E model.
clinton_00 is offline
Old 10-11-2009, 06:58 PM   #2 (permalink)
nevrenufhp's Avatar
Yep, there's a diaphram that will limit fuel until boost hits. It's replaceable, as are most of the parts inside the pump. You can take off the supply line and test it with a few pounds of air and see if it holds it.
commuter: 67 F100,300,offy intake,edel carb,274* cam,header
swapping in a Ford/New Holland 6.6(12 valve). Ford engine in a Ford! 6.6 vid: http://www.youtube.com/watch?v=zcflwjpRHUQ
Work truck:'94 IH 4900, DTA466 lightly bombed(#0 fuel plate, timing at 22*, 3 clicks tighter gov springs), Allison MT653, Voith retarder, and straight piped
nevrenufhp is offline
