350 horse Cummins - Diesel Forum - TheDieselStop.com
post #1 of 12 (permalink) Old 09-12-2006, 09:48 PM Thread Starter
350 horse Cummins
We just bought a Fleetwood diesel pusher motorhome on a Freighliner chasis.
It has a 350 horse Cummins and 6 speed Allison. It weights 31000 lbs dry.
Is it possible to chip this motor to 400 hp? without reliability?
I'm not trying to hot rod but I can appreciate a little more power.
05 Lariat 4X2 Dualie Powerstroke
telestar is offline
post #2 of 12 (permalink) Old 09-12-2006, 11:24 PM
brahamfireman's Avatar
Re: 350 horse Cummins
what year is it???? I take it its a bigger cummins not the 5.9???
Diesel Rod
Formerly Diesel Rod.
A
with 295K miles, 90 LED's and 5" stacks, among other things....
A
Reg cab with 210K miles, Needs to go away. PM me.
SHORT HOOD. The ongoing "project" it aint pretty but its got a
425 air to air Cat motor
.....13 speed Eaton. Corvette Dash, 17 gauges, 8" black stacks, 63" flat top---> 36" sitting here waiting for paint. 1.305 Million Miles.
I don't know what I am doing, I just know I don't have time to do it.
brahamfireman is offline
post #3 of 12 (permalink) Old 09-13-2006, 12:34 AM
If this is one of the larger engines, most of them can be turned up at a authorized cummins dealer.
fieldtrialer is offline
post #4 of 12 (permalink) Old 09-13-2006, 08:01 AM
Fordman84's Avatar
If it is a ISM (M11 if its older) it can go to 400hp, IF the allison torque rating will stand it. I would do some checking before you have cummins turn it up, also if its under warranty I would leave it alone.
Mike
2006 Chevy 2500HD Crew Cab SB 4x4 LBZ LT3. Driv Devilslide 20x9 wheels with 305-50-20 Cooper Zeon Tires, Magnaflow 4" Turbo Back Dual Exhaust, Edge Juice/Attitude
Fordman84 is offline
post #5 of 12 (permalink) Old 09-13-2006, 11:11 AM Thread Starter
My Mistake.
It's A Catipillar C7 7.2 litre in a 05 chasis.
I finally took a look and saw the yellow paint then looked at the manual.
The salesman didn't know the difference.
telestar is offline
post #6 of 12 (permalink) Old 09-13-2006, 11:40 AM
My Photos: (9)
350 out of that tiny motor is already a fire breathing monster...probably only available in RV and I am sure it is maxed out at that. Let it be for your wallet's sake
Birken
Birken Vogt is offline
post #7 of 12 (permalink) Old 09-13-2006, 11:45 AM
Fordman84's Avatar
Is that the same engine as the trouble ridden 3126? If it is I would stay away from that thing, I have never seen one make 300k without head trouble.
post #8 of 12 (permalink) Old 09-13-2006, 02:21 PM
My Photos: (9)
Basically, yes but with lots of improvements, however they are still known for breaking a lot, probably in no small part due to the excessively high output they often are rated at.
Birken
post #9 of 12 (permalink) Old 09-13-2006, 09:07 PM
You bought an RV without knowing which engine it has and trusting the dealer? Wow...
UApilot
2008 Dodge QuadCab 2500 Big Horn, CTD, 4x4, auto, tube steps, clearance lights, on-board air, air horns, air-ride coming. 300hp/540lb.ft. stock
2006 KTM 950 Adventure S
UApilot is offline
post #10 of 12 (permalink) Old 09-13-2006, 09:25 PM
in his defense, if it's new and your not going to do any repairs yourself and it's under warranty, who cares what brand it is? Granted I would have at least looked but hey [img]/ubbthreads/images/graemlins/shrug.gif[/img]. Cat or Cummins your not going to go wrong with either. And yes 330 is the highest factory rating for the C7 (fire and RV only) but if you want more, TS Performance makes the MP-8 box for it.
Jfaulkner is offline
post #11 of 12 (permalink) Old 09-13-2006, 11:30 PM Thread Starter
I wish you hadn't said anything engine worries.
However the manual says it has a 6 year or 6000 hour warranty.
I hope I don't have to use it.
I won't be changing my own oil I expect either. The manual mentions several different capacity pans but another RVer with the same motor says 19 gallons. Good grief.
The cooling system won't have to be flushed according to the manual for 300,000 miles. I think that is what I read last night. Haven't read far enough yet to know if it's got a cooling system filter but suspect it has with such a high mileage before changing coolant.
telestar is offline
post #12 of 12 (permalink) Old 09-14-2006, 12:34 PM
My Photos: (9)
Not 19 gallons, 19 quarts probably.
For insurance sake I just drain and refill coolant annually because I have had so many problems with corrosion, plugging, etc. I want to keep it fresh.
Birken
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
