4.5 V-6 powerstroke? - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 11-12-2006, 12:42 PM Thread Starter
Fireman87's Avatar
Anyone heard of one?
2012
F-250SD PSD Super Cab Longbed 4X4, 3.55, Firestone Air Helper Springs, Upgraded Headlight Harness, AMSOIL Fluids/By-Pass Oil Filter, owned since 8/8/2012
1997
F-250HD Reg. Cab 4X4 PSD "The Stroker", ZF5, 4.10, LUK Clutch Conversion,
Custom Open Air Intake, 3" to 4" DP, 4" Straight Exhaust, Gutted EBPV,
Bully Dog Boost/Pyro, HPO Crossover Line, Amsoil Bypass Filter, All Amsoil Fluids, Cali. FPR, High Voltage IDM, Upgraded Headlight Harness, Scosche Remote Starter,
in the front, One Ton springs in the rear, Owned Since 08/20/2004
Fireman87 is offline
post #2 of 7 (permalink) Old 11-12-2006, 02:02 PM
Re: 4.5 V-6 powerstroke?
i drove one...they r available only in the LCF (low cab forward) model...they came out late 05 as a MY05 or MY06...would be a nice option if it was available in the f-series and certainly in an e-series...if i am not mistaken it is just a 6.0l without two cylinders but havent heard too many complaints about them but there are not too many people who own them on this site
someday is offline
post #3 of 7 (permalink) Old 11-12-2006, 03:07 PM
MarkEkberg's Avatar
My Photos: (13)
I saw a bunch sitting on the side of the road last winter, but none recently.
I figured it would be a nightmare like the f-body, but I guess not.
The twin set-up looks intersting.
I mignt investigate a repower for my 96 in a few years.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
post #4 of 7 (permalink) Old 11-12-2006, 06:44 PM
hitecdan's Avatar
My Photos: (23)
This is supposedly the engine Ford was going to put in the F-150 back in 2003, but didn't. Instead they pulled out of the R&D phase and left International with a $30 million worth of red tape in the process. International had to sue Ford to get the money. Now the 4.5L is in Ford's LCF delivery trucks. It is a 6.0L with 2 cylinders hacked off.
Now Ford is talking about putting a 4.4L diesel sourced from Land Rover (which Ford owns) in the F-150. Too bad Ford didn't get off it's duff and put the 4.5L in an F-150 back in 2003. A half ton truck that gets close to 25 mpg and none of the new emission stuff that is going on 2008 models. Oh well, Ford was swimming in lot of red ink back then. Come to think about it, they still are.
My html Version of the
Now with 2005 Updates
Born on date: Jan 20, 2003
Number of C94 injectors replaced: 1 (#4 Jan 30, 2015)
Number of times the EGR valve has been replaced/cleaned: 0 (updated: 9/17/2014)
hitecdan is offline
post #5 of 7 (permalink) Old 11-12-2006, 06:54 PM
"Oh well, Ford was swimming in lot of red ink back then."
Unfortunately, that's not all they're swimming in.
The last I heard was it might be 2011 before Ford gets a
diesel in their large SUV's. They timing might be the
same on their F150 trucks if they do them both at the same
time. Word has it, GM will be putting a diesel in their large
SUV's by 2009. That would put Ford late to the party
again. They've made a legacy out of throwing whatever
advantage they have away. Every once in a while Ford shocks
with innovation and good lead time. It's too bad they
they tend to rest on their laurels instead of staying on
the offense. The orientals see business as war, we still
haven't figured that out. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1997 F250 HD PSD 4x4 OR Auto 3.55LS CC SRW SWB 265x75x16 Michelin LTX DP 211K mi.; Ford AIC; Fuel milege; 20.3 mpg @ 70 mph. 12.5 mpg pulling my boat,12.5K, along two lane rural roads. A number of mods ordered from DaleI. Nice round replacement DP. FS2500 by-pass oil filter installed. Fumoto drain valve. Tymar Intake installed! HX mod from Tymar installed. TFI fillneck kits installed. Auto-Rx cleaner in engine & transmission done. Switched from Rotella dino to Rotella synthetic. Amsoil 5W-30 Series 3000 installed!
FS-2500 Bypass filter installed. CD Changer
Velvet rides installed. Joe Servo IDM mod was installed. Replaced with Swamps HV/HF IDM! Rear air lift springs. 4" exhaust installed all the back from DP and bye bye Kitty.
Sparkydm is offline
post #6 of 7 (permalink) Old 11-12-2006, 08:21 PM
My Photos: (5)
My local dealer told me last week that this or a similar V6 diesel will be announced as early as next spring and will be available in the F150 and the Expedition.
2008 F350 6.4 EC SB 4WD SRW
FirstLight is offline
post #7 of 7 (permalink) Old 11-13-2006, 07:47 AM
"My local dealer told me last week that this or a similar V6 diesel will be announced as early as next spring and will be available in the F150 and the Expedition."
I sure do hope you're right. The 2011 number is what the
plant had been told when the question was asked of them. Maybe
they did this took keep competitors in the fog? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Sparkydm is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
