453 Detroit Fuel In Oil - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Old 10-15-2009, 11:58 AM   #1 (permalink)
I have a 453 detroit on a 1970 international 1700 truck (factory engine). Recently I noticed oil level over full and determined it was diesel fuel. I checked the lift pump and found no problem. I removed the rocker cover and plugged the return line and actived the pump with a drill and could not find any leaks on the lines or aound the injectors. The engine has many miles on it and smokes blue smoke quite a bit when cold and black smoke when loaded hard. I am not looseing any coolant. Can the injectors be bad and leaking causing this?
smttractor is offline
Old 10-15-2009, 12:57 PM   #2 (permalink)
aekrogh's Avatar
I had a similar problem on my 6V53 it was a bad injector tip/plunger. It was stuck to were there was always a small amount of fuel dribbling into the cylinder......did not find mine soon enough and had to resleave the one cylinder. If the motor is running and you put your hand on the exhaust manifold (like when you first start it in the morning) look for the cylinder that is putting out less heat than the others. That is the injector that i would pull first. Let me know what you find.
Late 99 SD PS CC SB 4x4 Lariat. 7.3l TS 6xchip Stock-140hp , Banks 6gun, Full Banks Gauges, 4"SS turbo back exhaust, UMP Intake w/ Donaldson Filter, Auburn posi F&R 3.73, ATS Trans W/ 5Star converter and CoPilot, 18k trans cooler, Dynatrac FreeSpin front hub kit, ITP oil X over, ITP boost regulator, Aero Fuel Tanks Replacement 55 Gallon tank, New timing cover,oil pan,oil cooler, water pump,turbo petastel, reman HPOP, new fuel filter housing, slotted brakes all 4 corners W/ Ceramic pads, Adjustable trac-bar, Front 1.5" level kit only. 226,000 miles 10/1/09 Best mpg 27.3..Norm city 15 mpg hwy 20+
Early 99 CC LB 2WD Manual 6....Stock 228k (11/09) and running strong, only repairs Clutch, water pump, alternator. K&N FIPK since 36k and loving it!
2006 CC LB 4WD Lariat 6.0l 5R110 Stock 178k (12/09) "Dad's" 3 injectors and GP harness(12/09) Dynatrac Ball Joints, New ERG and 2 injectors (6/10)
aekrogh is offline
Old 10-15-2009, 01:24 PM   #3 (permalink)
Thanks. I will give that a try.
Old 10-15-2009, 11:04 PM   #4 (permalink)
Plug off the return line to the tank, install a hand pump and pressureize the fuel system AFTER the fuel pump to 70 psi. The leak will show up. Usually a damaged jumper line or a loose line under the rocker cover. I have also seen the 3/8 washer under the fuel line connector at the top of the head leaking. Remember AFTER the fuel pump. ANy pressure greather than 15 lbs at the fuel pump will blow the seals out.
95 F250,XLT, 4WD, Auto Trans,bbshimmed,synthetic trans oil,4:10 gears ,Truck Trunk ,Nerf Bars ,crome Mud flaps, Aux. trans cooler, front diff. drain plug. External trans.filter, trimmed snorkel. American wheels water temp guage, front fuel tank mod,Warn Manual hubs,Putman class 4 hitch 189k mi.
It is said if you sit by the river and watch the water flow by long enough, your enemies will pass by. This I believe to be true. It is also possible to watch your loved ones pass by as well.
Wife Candi 08/14/07 missing her always
Gone Fishen is offline
