4700 international speed limiter - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Old 05-08-2009, 12:46 PM   #1 (permalink)
I just bought a 2000 International 4700. It is an auto w/ a dt 360. It was a Ryder rental truck and has a speed limiter at about 65 Mph. I am wondering if there is a way to adjust that.
Thxs in advance.
1997 F 250 BONE STOCK 305,000 MILES
Jmikan is offline
Old 05-08-2009, 10:33 PM   #2 (permalink)
nevrenufhp's Avatar
Most of the time they gear them down so it hits the engine's governor. I'd bet it has some pretty steep gears in it, like 4.44, 4.78, or close to it. According to my info, they quit making the DT360 in 93. You can adjust fuel and rpm for free on a DT360, but not if it's a 2000 model, then it would be a T444E, DT466E, or DT530E.
commuter: 67 F100,300,offy intake,edel carb,274* cam,header
swapping in a Ford/New Holland 6.6(12 valve). Ford engine in a Ford! 6.6 vid: http://www.youtube.com/watch?v=zcflwjpRHUQ
Work truck:'94 IH 4900, DTA466 lightly bombed(#0 fuel plate, timing at 22*, 3 clicks tighter gov springs), Allison MT653, Voith retarder, and straight piped
nevrenufhp is offline
Old 05-08-2009, 11:23 PM   #3 (permalink)
i wonder the truck you're refering to has a vt360 engine, also reffered to as the 6.0L in ford trucks. seems like international starting using those about the same time ford did. any chance it might be a little newer than a 2000? seems like they usually have the vin and model year on the driver's side door pillar. the speed is probably limited by either the engine ecm or the trans ecm. they might be able to adjust the computer parameters for you at an international dealership.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters.
sdan27 is offline
Old 05-09-2009, 03:47 PM   #4 (permalink)
You are right it is not a DT360 it is a T444E. So would that be adjusted at a dealership?
Jmikan is offline
Old 05-09-2009, 05:04 PM   #5 (permalink)
if your speed isn't being limited simply by your gearing, the best chance would be to go through a dealership.
sdan27 is offline
