5.9 cummins fuel shutoff selenoid - Diesel Forum - TheDieselStop.com
post #1 of 10 (permalink) Old 07-25-2005, 10:10 PM Thread Starter
where is a good place to order one cheap?
97 dodge cummins, 200,000 miles, cat removed, otherwise stock
Matador is offline
post #2 of 10 (permalink) Old 07-26-2005, 06:00 PM Thread Starter
Re: 5.9 cummins fuel shutoff selenoid
Here is what happens. It sometimes cranks for some time and then starts or sometimes it doesnt start till I go out while leaving the key on and lift up on the solenoid till it clicks in place. I then go back in and recrank it and it starts immediately. I figured it was the solenoid.
Any suggestions or remarks as to what it might be? Any help would be greatly appreciated.
Thanks,
Matador
Matador is offline
post #3 of 10 (permalink) Old 07-26-2005, 06:09 PM
You have it located. Is your boot cracked? Number one cause of failure is due to the boot. As for a cheep one - hold your breath and head to Cummins. There just aren't many ways around it without serious modifications.
jcchristn is offline
post #4 of 10 (permalink) Old 07-26-2005, 06:43 PM Thread Starter
I will look more closely at the boot. Cummins wants from 225 to almost 300 for one. I thought that was outlandish. Maybe not eh?
Matador
Matador is offline
post #5 of 10 (permalink) Old 07-26-2005, 08:58 PM
nevrenufhp's Avatar
When mine wasn't starting, similar to your symptoms, it was the relay on the firewall. Those are sure less $$$ than the whole solenoid. Do a search for LarryB, he has the sol. and relays for a good deal.
commuter: 08 VW R32, or 67 F100,300,offy intake,edel carb,274* cam,header
Work truck:'94 IH 4900, DTA466 lightly bombed(#0 fuel plate, timing at 22*, 3 clicks tighter gov springs), Allison MT653, Voith retarder, and straight piped
nevrenufhp is offline
post #6 of 10 (permalink) Old 07-27-2005, 07:56 PM
The solinoid is to simple of a device to fail. My 96 with 260K miles still has the original. When ever I take the solenoid off it falls apart (boot is not in good shape anymore) but it works fine when bolted in place.
Many poor starting situations that play out like you said (key on and pull up solinoid to start) are related to a week power supply to the solinoid , i.e., week batteries, dirty/corroded terminals. A very common issue is the light blue wire that connects directly to the battery and feeds this circuit can be broke or have a bad connector at the battery. Change the relay on the firewall what that controls this circut...much cheaper then the solinoid. As a last resort, change the solinoid.
jjw
ND
JJW-ND is offline
post #7 of 10 (permalink) Old 07-27-2005, 08:42 PM
if it is the soleniod you might want to check your local CASEIH dealer.they use the 5.9 in the MAXXUM tractors.not sure of price but might be worth a shot
92 F250,7.3,E4OD,BANKS POWER,COOLANT FILTER,8 FOOT WESTERN PRO PLOW 193,000 on original ip and injectors
rancherman84 is offline
post #8 of 10 (permalink) Old 07-28-2005, 07:55 AM Thread Starter
If it turns out thats what I need. I will definitely check there at CashIH.
Thanks,
Matador
Matador is offline
post #9 of 10 (permalink) Old 07-28-2005, 10:44 AM
Matador
if it turns out that it is the selenoid and you don't want to spend that kind of money to replace it you can convert over to a manual fuel shut-off using a pto cable for about $40 bucks total cost including the cable and all the other little incedentals you might need.
Cam
91 F350 reg.cab, SRW, 4x4, Powered by a '98 Cummins 12v. BHAF, #10 plate, 3k gsk in the near future, Di-Pricol pyro and boost gauge and VDO oil pressure gauge in a custom A-pillar mount, 4" straight exhaust, PSD intercooler, 4.10's, ZF 5spd, 4" superlift, 305/70/16's
2001 Bullit Mustang, #292
Radcam is offline
post #10 of 10 (permalink) Old 07-28-2005, 01:46 PM
M1A
Larry B's
Go to Larry B's . For 197.90 you can get a new one.
2004 Kubota BX23 TLB
2003 VW GLS Jetta TDI 5-speed.
1997 Dodge 2500 ST Cummins 6BT 12-Valve 4x4, NV4500 Torque King 5-speed, 4.10 axle, Luk 13.25 HD clutch, Boost, fuel pres, @ EGT gauges, TST #10 fuel plate & AFC Spring kit, 370 Hp Injectors, PDR HX40 Turbo (40 lbs boost), 3K GSK, limited slip axle, Amsoiled. Jardine 4" turbo back exhaust.
M1A is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
