6 speed plus manual transmission - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 12-15-2006, 05:12 PM Thread Starter
Can someone explain me the 6 speed plus manual tranmission for international?
gush is offline
post #2 of 8 (permalink) Old 12-15-2006, 06:22 PM
Re: 6 speed plus manual transmission
It is actually a 7 speed. Ultra low gear plus 6 regular ratios and of course reverse.
R 1 3 5
L 2 4 6
04.5 2500 SLT 600 auto QC 4x4 3.73 Autometer Phantoms Protech box
Sold: 99 PSD
PowerStroker1234 is offline
post #3 of 8 (permalink) Old 12-15-2006, 07:42 PM
there was/is two 6spds available from spicer.spicer the the tranny most often found in ih mediums. the 6+1 is actually a od tranny,dont remember the percentage of the od off hand.pretty good little tranny btw ...
the fleet; ferds ,02'f350,01'f450, 11' f350 the generals ,82'2500, 82'2500 4x4, 82' blazer, 86' blazer ,93'3500, 96'3500, and a 99' 3500hd with 12 valve cummins power. the goats, 90'd250, 91'd350 4x4, all are diesel powered. a list of bigger stuff, as well as gasser's, got lucky, wife comes from a family that collects junk iron too!
navistar45 is offline
post #4 of 8 (permalink) Old 12-17-2006, 04:06 PM
rmyers2051's Avatar
Wish I had that instead of the 6 speed direct in my rollback. 72mph is 2700rpms for me.
F250Ext. 4x4 5spd. GV overdrive,4.10s,23+mpg
Some people are like slinkies, Not really good for anything, but they still bring a smile to your face when you push them down a flight of stairs!
rmyers2051 is offline
post #5 of 8 (permalink) Old 12-17-2006, 08:03 PM
What I can tell you is that it's called the ES066-7B. It's very easy to shift since it's synchronized. Parts and rebuilds are readily available. I got a reman for ~$2,300. Many will say they're not so good because they see so many fail, but I think so many fail because there's so many of them out there.
It's a nice trans if you need an O/D gear to get higher highway speeds and has a 7.48 1st, 4.43 2nd, 2.76 3rd, 1.90 4th, 1.34 5th, 1.00 6th and a .74 7th O/D. Reverse is 6.66. Torque capacity is 660 ftlbs.
There's also a ES527B, which is a 7 speed direct trans.
IBUILD is offline
post #6 of 8 (permalink) Old 12-29-2006, 12:38 AM
is this an option for the 99+ trucks? I have a 6 speed now... but sounds like that 7th gear would give me better fuel mileage right? and where would I get one?
2016 F-3506.7 PSD, Crew Cab, Long bed, Lariat with the Ultimate package, Fx4, Bench seat in the front, tan interior, white platinum with Caribou accent 5th wheel prep package, 3.55 rear end with Electronic lockers - Purchased New
2002 F-350 Crew Cab Long Bed, Lariat, 4x4, Automatic, , In-Tank Hutch Mod, Edge Insight Monitor. 320k miles
2000. Stock F-350 XLT 330K+ miles, white, 4x4, 6 spd manual, extended cab, Long Bed. Marinco Block Heater Mod, Tymar Intake. 4" Turbo Back Straight pipe, In-Tank Hutch Mod, Swamps Diesel 175/146 injectors - with TS Performance 6 position chip
jchipper is offline
post #7 of 8 (permalink) Old 12-29-2006, 12:42 AM
Not available in Ford chassis, only International chassis applications. The 6 speed plus also uses the SAE bellhousing IIRC, so it would not be a simple bolt up, changing the flywheel housing would be needed and a bit of fabrication to make everything work together.
Buddy
Former Ford Diesel Tech
ASE Certified Parts Counterperson, Automotive, Medium, & Heavy Truck Technician
1999 F250 XLT 4x4, Red, 7.3 6spd AWA5, 3.73LS rear, CCV Mod, APC Headlamps, Autometer C2 Gauges, (Boost,Pyro,Trans), 4" Turbo-back exhaust, XM Radio, AIS, ITP Regulated return, fuel feed lines, Airdog, & 4pos. chip.
2001 Ford Escort ZX2 - Black- 4cyl 2.0DOHC, 5spd.
1999 F350 4x4 XLT, CC/LB PSD, 6spd, Aluminum service bed, York Compressor Onboard air, CCV, Custom Intake & Exhaust, Strobes and a few other goodies
RIP Steph F. & Trista J., 4/27/07, you will be missed by many.
budman451 is offline
post #8 of 8 (permalink) Old 12-29-2006, 06:12 PM
rmyers2051's Avatar
But,,, this would work fine in my 650 with the cummins, right?
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
