6BT -Allison MD3060 conv parts - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Old 10-31-2009, 08:09 PM   #1 (permalink)
8x8
I have a 2nd gen 95 Dodge 2500 w/ 5.9 cummins auto
I am looking to pull this engine and mate it to an Allison MD3060 + I need an air compressor for air brakes, as plan to install into Sisu A45 4x4 military truck.
I know I will need a SAE #2 flywheel housing
but could someone with knowledge tell me what else I would need to mate this trans
  • Flexplate
  • Starter mtr
  • which SAE #2 are there differences
  • what parts will i need to instal the air compressor
Any recommended vendors for these parts
8x8 is offline
Old 11-01-2009, 11:09 AM   #2 (permalink)
My Photos: (27)
You might check with a Cummins engine authorized outlet and ask them what's available (if anything). I was sent to a factory school on those engines before they put them in Dodges and they were actually a mid duty heavy equipment engine----front end loaders, graders, etc. They were supposedly going to have so many industrial uses that there may be brackets, pulleys, etc, available for a belt driven compressor. Can't be of help on the Allison conversion.
'91 F-250 SC 4X4, 5spd. ATS Turbo http://sports.webshots.com/album/180135797kNEIOu
LMJD is offline
Old 11-02-2009, 07:35 PM   #3 (permalink)
nevrenufhp's Avatar
That should be all you need, but you left out the throttle pos sensor. The Alli needs it to know when to kick down. On the early 90s F6-800's with the 5.9, they had a mount for a compressor with a bracket and power steering pump haging off the back of that. They mount under the injector pump, where Dodges have the Saginaw PS pump. I saw a compressor and MD3060 on 4btswaps in the classifieds.
commuter: 67 F100,300,offy intake,edel carb,274* cam,header
swapping in a Ford/New Holland 6.6(12 valve). Ford engine in a Ford! 6.6 vid: http://www.youtube.com/watch?v=zcflwjpRHUQ
Work truck:'94 IH 4900, DTA466 lightly bombed(#0 fuel plate, timing at 22*, 3 clicks tighter gov springs), Allison MT653, Voith retarder, and straight piped
nevrenufhp is offline
Old 11-07-2009, 03:15 PM   #4 (permalink)
My Photos: (9)
Just checking, why do you want a 3060? A 1000/2000/2400 is the transmission that is typically mated to a B series, smaller and probably cheaper.
Birken
Birken Vogt is offline
