7.8 injection pump timing - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Old 10-16-2009, 08:18 PM   #1 (permalink)
A friend of mine pulled the injection pump off his 1988 LN 8000 dump truck to fix a leak. He reinstalled it and says thats fuel is only going to the front three injectors, he said he did not move the pump gear. I want to help him get it running but need to know how to check / set the engine and pump timing. Its a 200 mile trip for me to do him a favor so any advice would help.Thanks
refish is offline
Old 10-16-2009, 10:29 PM   #2 (permalink)
nevrenufhp's Avatar
There has to be a severe problem if fuel is only getting to the front 3, they share a common supply in the pump. It is possible that it could have stuck plungers or something similar, due to crud or rust damage. Make sure the primary filter(one that's also the fuel-water separator) that's back closer to the tank has recently been replaced. That one gets overlooked way too often, and will starve it for fuel. That, and pump the primer a few dozen times to make dern sure it pushes fuel thru the whole pump.
Other than that, if the timing stayed the same while it was off, you should advance it a few degrees. In a nutshell, loosen the gear from the pump, and hold it while you move the crank backwards, which is approx. 1/8" per degree of advance desired. Shoot for about 17*(more if you upped the fuel rate), and stock is 13-15*.
commuter: 67 F100,300,offy intake,edel carb,274* cam,header
swapping in a Ford/New Holland 6.6(12 valve). Ford engine in a Ford! 6.6 vid: http://www.youtube.com/watch?v=zcflwjpRHUQ
Work truck:'94 IH 4900, DTA466 lightly bombed(#0 fuel plate, timing at 22*, 3 clicks tighter gov springs), Allison MT653, Voith retarder, and straight piped
nevrenufhp is offline
