Originally Posted by sterjess
I just picked up an '88 chevy with a 6.2 in it. It runs and drives but seems to have a slight miss, there's a service engine soon light that comes on after starting, does anyone know what these old chevy's check engine lights are referring too when they come on?
The SES on these trucks only dealt with the EGR systems. All 6.2L's have mechanical injection pumps and injectors, so the SES won't have anything to do with timing, injection, etc.
It might be possible that the EGR valve is stuck open. If you pull the air cleaner off, the EGR valve is right in the middle of the intake manifold. Pull the valve off, and find the correct size freeze plug to drive into its place to block off the exhaust passages. Better yet, find a non-EGR manifold off a 1 ton 6.2L truck. Then pull the bulb out of the SES light.
This only applies to 1/2 ton and light duty 3/4 ton VIN code "c" trucks. Heavy duty 3/4 ton and 1 ton VIN code "J" trucks didn't have any EGR systems.
Casey
1996 E-350 Van Cutaway, 7.3L PSD, E4OD, Dana 70 dually with 4.10 gears, Reading enclosed utility body, 160K miles....
1995 Chevy K1500 Tahoe, 6.5L TD, NP241, 4L80E, 3.42 gears, Kennedy Diesel OPS harness and FSD cooler kit.
1981 Chevy 3/4 ton converted to 6.2L TURBO DIESEL, bored .040" over, 6.5L pump, turbo injectors, DSG timing gears, lowered compression w/ceramic-coated pistons, 17 lbs of boost....4 speed auto, custom built 4" exhaust, 4.10's, keyless entry, etc. etc.... See my photos
