99' Dodge ISB, intermittent - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Old 11-23-2006, 09:25 PM   #1 (permalink)
I've got a buddy with a 99' Ram with the Cummins motor. He complains of an intermittant miss at idle, after the motor has warm-ed up. Any advice or tips? I know the obvious answer is to buy a Ford, he's thick headed. Thanks in advance,
Justin
J_Ashley is offline
Old 11-24-2006, 10:16 AM   #2 (permalink)
Re: 99' Dodge ISB, intermittent
Check codes, but it's most likely a dying VP injection pump. Lift pump, injection pump failure is typical for 24v Dodges, believe me, I know.
<u>02 Dodge 2500-</u> HO Cummins, NV5600 6 speed, Edge EZ, ISSPRO gauges (fuel pressure, boost, and EGT), 4 to 5 inch straight pipe exhaust, Vulcan 1/2 fuel system with Holley blue pump.
<u>93 Dodge D250-</u> tweaked pump and timing, POD injectors, Mag-Hytec covers for trans and rearend, KDP killed, straightpipe exhaust, ISSPRO gauges, Transgo shift kit, aux trans cooler. 288k miles and climbing every day
TX_Firefighter is offline
Old 11-25-2006, 08:58 PM   #3 (permalink)
Well, he's prelaced the IP once already so I'm sure he'll be thrilled to hear about this... Anyways, does anyone know what this might be specifically? Thanks again...
Justin
J_Ashley is offline
Old 11-25-2006, 11:23 PM   #4 (permalink)
I would recommend asking over at dieselram.com to get better advice than you can get here. Its best to diagnose exactly what is wrong because as he already knows injector pumps are not cheap. It would suck for him to replace it and the problem be something else.
2005 Dodge Ram 3500 Quad Cab Laramie SRW 4x4 5.9 Cummins 48RE Automatic 3.73 gears Leather/Suede Power/Heated Seats, Infinity Sound System w/6 Disc Changer, Dual Zone Climate Control, Hella Fog Lights
Socialism and higher taxes isn't the kind of CHANGE we were HOPING for.
Quicksilver Ram is offline
Old 11-26-2006, 04:23 AM   #5 (permalink)
Cummins northwest has a computer plugs right into the injection pump. It runs off the computer instead of the ecm. Thing will tell you in a hurry if its the injection pump.
BigDaddyT is offline
