General DieselDiscussion about diesels in general. All brands are welcome, please refrain from brand wars. Discussions about types of diesel fuel also go here.
Ok I remember reading a post on this a year or two ago has anyone acctually tried using acetone as an additive w/diesel? I saw an article in the local paper about it increasing mileage up to 25% in trucks and 35% in cars.
I'm real skepticle about using something like this with these exspensive injectors
This was debunked years ago in these forums but since the cocked up changes to the website and the lack on indexing on older posts you cannot find it. No advantage.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2µ Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203º T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
I can't imagine throwing acetone into my diesel. But I'm intrigued about two-stroke oil, so am going to start my own thread..... [img]/forums/images/%%GRAEMLIN_URL%%/wink.gif[/img]
Sold: 1999 White Lariat CC SB F-250. Sold to next-door neighbor in 2001....received final payment 2007! Still going strong at 198Kmiles as of Dec'07
Sold: 2001 Bright Amber Lariat CC LB F-250 with 4 million candlepower of LightForce lights in the bow. Line-X bedliner. Dual alternator. Clearance lights. Glass-tite cap. 250-gallon auxiliary tank for trips to the Lesser 48. 70-gallon auxiliary for trips around Alaska. Rec'd Dec'07: '08 ForestGreen/Gold F-350 CC LB. Handshaker, as always, Rear stabilizer, rear static video, rear step, dual alternators. B&W turnover ball on its way; soon to be Line-X'd. LightForces on their way.
I can ask the same question about using acetone in your fuel as I do about using two stroke oil. If it is so good and beneficial and harmless, why doesn't someone market it as "Diesel Fuel Mileage Supplement"
As was stated earlier, many TSD members tried it years ago. I doubt if any stayed with it.
2003 KR F-250 4X4 CC SWB, 6.0, 5 Speed Auto, 3.73 Axle, no Limited slip. Rhino bedliner, Unicover bed cover.
Built on February 19, '03
#2 93 F-150 XLT, 5 Liter, Auto, 4X4, X Cab. 251,000 miles. Uses no oil between changes.
Mythbusters did an episode on acetone and showed it does very little if anything, IIRC. They rerun fairly regularly, so maybe you can watch and draw your own conclusions.
I've been there, done that, already used the T-shirt as a grease rag. It did improve my mileage but only a very small amount. I don't remember the amounts I used and mileage improvements I gained, but I determined it wasn't worth it. I did an extensive test on the same roads, same conditions, same fuel station, several tanks and a few months. I think I covered it pretty good and stopped using it because it wasn't worth it. You may can do a search on my name (a year to a year and a half ago) and find it. My suggestion is don't waste your time with it on a diesel (I've never tried it on a gasser).
My .02, Joe
2002 F350, Crew Cab, 4WD, ISSOPRO Gauges,
3.73, Auto, 2wd low range mod, No door dinger,
Interior lights off switch, Zoodad Mod,
Extra Trans Cooler, Before coolers trans fltr,
Coolant fltr, Crimestopper remote start/alarm
Oil Guard Bypass, Air horns
I think it only helps on engines that don't atomize fuel well. So it won't do much for a diesel or a fuel injected engine. I tried it a few years ago with my neon and couldnt tell any benifit.
If I had some sticky injectors I might think about using it to try and clean them, but not as a normal everyday additive.
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
