brown/yellow smoke...? - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Old 05-17-2009, 10:23 PM   #1 (permalink)
my DD 8v71 just got all her oils and filters changes and she's smokin like everyone in the 40s. there is smoke idling and when you give her fuel the smoke is brown/yellow. also seems to have lost power too, should be tons of pickup for a gutted charter bus, but she's lackin.
suggestions?
rita_thebus is offline
Old 05-17-2009, 10:29 PM   #2 (permalink)
chuckster57's Avatar
Welcome to the Diesel Stop
Any idea what the smoke smells like?? Brown/yellow smoke is not a color I have encountered. Did you have the fluids changed at a shop? Maybe someone over filled the oil, or put the wrong stuff in the wrong fill hole...
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now
Old 05-18-2009, 12:01 AM   #3 (permalink)
If it smokes at idle and gets worse at full rpm I would guess a blown tip on an injector. Bad fuel or varnished fuel will cause the color smoke and could blow a tip on an injector.
95 F250,XLT, 4WD, Auto Trans,bbshimmed,synthetic trans oil,4:10 gears ,Truck Trunk ,Nerf Bars ,crome Mud flaps, Aux. trans cooler, front diff. drain plug. External trans.filter, trimmed snorkel. American wheels water temp guage, front fuel tank mod,Warn Manual hubs,Putman class 4 hitch 189k mi.
It is said if you sit by the river and watch the water flow by long enough, your enemies will pass by. This I believe to be true. It is also possible to watch your loved ones pass by as well.
Wife Candi 08/14/07 missing her always
Gone Fishen is offline
