Go Back   Diesel Forum - The Diesel Stop.com > Other Topics > General Diesel
Old 08-12-2008, 03:19 PM   #1 (permalink)
Buck Marine Diesel
Just wanted to get the word out on a new Diesel engine. The engine is called a Buck Marine Diesel.
I work at Buck Marine Diesel. We are currently developing a prototype diesel engine specifically designed for inboard marine use, but we are planning on eventually putting one in a Chevy Tahoe. We're still working on things right now. We're getting VERY close to getting the first prototype fully up and running. We had it running yesterday for about an hour at around 2000 rpm without any problems. We need to do a little more work to get our dyno fully-functional but things are going good.
Since we didn't have the dyno working properly, we're not positive on the actual power numbers. However, while running under a moderate load at about 2000 rpm, the exhaust temperatures were around 1000 degrees F. We ran under those conditions for about 15 minutes. The hottest that the coolant pump got was about 120 degrees F. None of the 6 heads were over 140 degrees and all of them were within about 5 degrees of one another. You could lay your hands on top of the valve covers.
Check out our website for further pictures and videos.
Feel free to ask any questions that you have.
http://www.buckdiesel.com
timbillyosu is offline
Old 08-12-2008, 04:55 PM   #2 (permalink)
Thumbs up
Timbillyosu,
I remember reading the neat story of the Buck Marine Diesels in an earlier issue of Diesel Power Magazine. Good for you guys! I'm curious as to why there's plans to put one in a Chevy Tahoe, why not put one in a real truck like a Ford Excursion, a Ford Chassis motorhome, or a Ford SuperDuty (this is a Ford site ). The higher GVWR ratings should help to meet emissions, if it's a concern. Also, if I remember correctly, all the bolts on the engine were a black oxide coated allen head type. It may just be because the engine was a prototype, but I've found Torx head bolts to be vastly better at not rounding off. In addition, since the engine will see use in marine environments why not use a stainless alloy for the bolts?
What fuels will the engine be compatible with? Will the fuel system be capable of using alternative fuels such as B100 biodiesel ?
Thanks,
K.N.
3/94' F-250XL 4x4,PowerStroke Diesel power, DP-tuner flashed to MLE1, H.D ZF 5-Spd. w/SBC Con-O clutch, Std. cab, 3.55, Mobil 1 syn. in T-case & tranny, Chevron's DELO 400 & Fleetrite Anti-Foam Additive, Valvoline's Durablend 85w-140 in rear, LT265-75R-16 Goodyear AT/Ss, 300,100 miles, Ported Snorkel & Tymar Intake, TS 6-pos chip, Banks 3" 409 Stainless Downpipe, S.D. 409 Stainless Cat Delete, Hidden Hitch, Stock
http://community.webshots.com/user/kn94psd
K.N.94PSD is offline
Old 08-13-2008, 08:15 AM   #3 (permalink)
Originally Posted by K.N.94PSD View Post
Timbillyosu,
Thanks,
K.N.
Well, we're planning on using the Tahoe because it is readily available to us (i.e. my boss already owns it) All of the bolts are a black oxide coated Socket Head Screw type. We have not yet seen any problems with rounding off or with rusting of the bolts. I personally would MUCH rather use an allen head type than a Torx head.
As of now, the engine is just being run on straight pump diesel, but we have been looking into making future engines Biodiesel capable. As I said, right now we're still just working on getting the first one up fully and running.
Old 08-13-2008, 11:09 AM   #4 (permalink)
Smile
Timbillyosu, thanks for the reply.
I'm curious as to why the socket head bolts are preferred? Most industries that I've seen that used the socket head bolts have switched to Torx type, most notably the automotive industry, to reduce rounding problems.
Since the design of the Buck Diesel is modular, what's the smallest engine size that's planned? I looked at the article again in the June 2008 issue of Diesel Power, and was curious if the cylinders (which appeared to be aluminum) had cast iron liners?
Also, I briefly looked at the website and was curious as to what units the drawn dimensions were in ?
Thanks,
K.N.
Old 08-13-2008, 11:49 AM   #5 (permalink)
I have rounded off a lot more Torx heads than I have socket heads. You just have to be careful. We were having a few problems with the button-head screws on the connecting rods. We have since changed them to a regular socket head.
The smallest engine size planned is the 3-cylinder which is shown on the website. All of the units of the drawings are in inches.
The cylinders are aluminum and they do have a cast iron liner that is pressed in. The jug design allows coolant to flow around all 360 degrees of the cylinder.
Old 08-13-2008, 12:38 PM   #6 (permalink)
MarkEkberg's Avatar
My Photos: (13)
I thought I remember reading something about this new development a few years ago. is it the same? Where some set backs in the delay?
MarkEkberg is offline
Old 08-13-2008, 01:16 PM   #7 (permalink)
We have been working on the project for a few years. A lot of our delays came in suppliers. It took a long time to figure out who could get us some ofthe things we needed. We had trouble getting reliable, quality cast parts for some time.
We've since gotten a pretty good handle on who is worth dealing with and who isn't.
Old 08-18-2008, 02:58 AM   #8 (permalink)
Welcome!
I too saw the article some time ago. I even showed it to the mechanic at work (school bus mechanic). The other mechanic at work use to work for the Navy (ship yard) and he said it seemed like a good set up. Both seemed it was a different approach.
1999 E-350 Cub Wagon, 7.3L Power Stroke, E4OD, 3.55
1990 E-350 Club Wagon, 7.3L IDI, E4OD, 3.54LS
1983 F-150 2x4, 4.9L, C-6 w/GV-OD, 3.55 Farm pickup
1981 C-8000, 3208 CAT, RT-6510, Rockwell SSHD Tandems (Swap)
1977 K100C, NTC-350, RT-1110, Tandem
1977 Transtar II, NTC-290, RT-9509 Single
1977 Transtar II, Formula 290, RT0-9513, Tandem
1974 C-750, 391CID, Clark 5 speed, Eaton 2 speed
Kaliburz is offline
Old 09-23-2008, 08:55 AM   #9 (permalink)
YouTube - Buck Diesel First Engine Run - Video of the Engine Running
YouTube - Upper End Replacement - Upper End Replacement
Old 09-26-2008, 03:43 PM   #10 (permalink)
Nice.
Kaliburz is offline
Old 09-26-2008, 05:22 PM   #11 (permalink)
I second that!!
I will keep looking for more info. on the vehicle installation.
macmaniac1 is online now
Old 10-06-2008, 04:50 PM   #12 (permalink)
mac, hopefully when we get into production, we'll look at trying it ourselves
I'll keep you all updated periodically on what's going on... right now we're waiting on a few crankshafts from the heat treater...
Old 10-06-2008, 09:01 PM   #13 (permalink)
that things cute.....
bout the size of the generators on my boat.
I really like the individual cylinder heads, that is typically something only seen on larger engines like the detroit mains in my boat.
What I don't recall seeing, is REAL specifications, fuel system is very important to me.... What kinda pump?
the reason we use alot of detroits is the flexibility in them.... in theory they can fit any need, In designing an engine just keep in mind that the marine enviroment is vastly different boat to boat, keep it simple but adaptable.
best of luck
drew
'89 F250 7.3 IDI, c6, 3.55rear, 2wd, 152k miles
DeepRoots is offline
Old 10-07-2008, 08:49 AM   #14 (permalink)
best of luck
drew
What size is your boat?
We are currently using a Bosch Fuel pump and Delphi injectors. When we get into production, we will be making our own injectors.
Are engines are very flexible. We are lighter than anyone else by about 1000 lbs. We are using a standard SAE-2 bellhousing, so we can fit a lot of applications.
My boss, Mike Buck, is the one that designed this engine. He has been working in/on/around the marine market for the last 40 years or so.
Old 10-07-2008, 01:13 PM   #15 (permalink)
I'm the chief engineer on the tug robert. 30ft by 86ft, 1800hp with 2, 16v149 mains, 471 generators and winch engine.
Other boats in our fleet have 12v149's @ 1200hp, 16 645 emds @ 4000hp and there are some caterpillars of varied sizes.
Our dredges have wartsila, and MAK engines as well.
nice, simple fuel system, I love it. Robust pump, and cheap/easily servicable injectors. It's nice to have the ability to limp home.... beats an engine throwing a code and shutting down at an inconvienant time.
I don't know what the epa jive is for smaller boats, I know they're starting to get to us about the 2strokes. I'd hate to be designing engines around all that BS.
drew
» Network Links
»Ford Car Reviews
