Bus with Ford 6.6 diesel - Diesel Forum - TheDieselStop.com
post #1 of 35 (permalink) Old 08-28-2007, 08:13 AM Thread Starter
Just purchased a 92 bus with the 6.6 6-cylinder turbodiesel. I know nothing about that engine. Does anyone have experience with it? So far, we have found that it is rated at 170hp at 2100 rpm, that is all the information we have.
93 F-250 mostly stock 270,000 miles original engine 2nd rebuild on E4OD...92 F-700 Bus/Motor Home 160,000 miles 6.6 Brazilian Ford td engine
wtom24 is offline
post #2 of 35 (permalink) Old 08-29-2007, 04:41 AM
My Photos: (33)
Re: Bus with Ford 6.6 diesel
Its a Brazilian Ford/New Holland Diesel. Uses the bosch inline injection pump. INSANELY low power, no load RPM OF around 2800 RPM can be spun up to 3400 going down hill using the engine to help slow the vehicle. Same family as the 7.8L Ford/New Holland diesel also made in brazil.
I have a 6.6L I-6 in my 89 F-800 boom truck (27,000 Lbs EMPTY). 7000+ hours 60,000+ miles. Damn little if any maintenance by the previous owners. starts great in cold weather and dosent burn hardly any oil with almost NO blow-by. Near bullet proof as any motor can get. Not enough HP to actually tear anything up.
If your looking to turn it up I would start by finding an intercooler setup from a junk yard and then adding a pyrometer and a boost gauge and then turning up the fuel.
what else do you want to know?
00'F350 psd CC Drw 2wd Bright Amber Western Hauler, exhaust brake transfer flow 50 gal tank tool, 30K Cody goose neck hitch, hawk pads, cryo'ed rotors, stainless lines, 380,000 miles
02' Psd Excursion Limited ultimate Estate Green 7.3L Auto 2x4 hellwig swaybars and rancho 9000's. 381,000 miles.
1993 F-superduty (F-450) 7.3L Gutless non turbo 2x4 Auto, Tire eating S.O.B. 12,750lbs 80,000miles lincoln Vantage 500 Duetz bolted in the back.
1994 7.3 I.D.I.T. factory turbo, auto 2x4 DRW with lots of upgrades, 11 transmissions under 100K factory warranty. 280,000 miles Currently Cavitated and parked.
96 F-800 24'flat 5.9L cummins, 4spd allison juice brakes.
89 F-800 6.6L 5+2 27,00lbs light weight with National 556A crane behind the cab.
2006 T800 KW 550 C-15 18spd 22K front, 52K rears murray ramps, 195" W.B. CA spec heavy haul SOLD
2006 Murray 16 tire professional lowbed SOLD
1996 fetherlite 4 horse GN, Walton 18' 14K tag tilt equipment trailer.
Dualie is offline
post #3 of 35 (permalink) Old 08-30-2007, 01:44 AM
Sounds like a good dependable working motor, goes anywhere does anything as long as you are not in a hurry, it's a mule.
Andy
Early 99 5-98, F350 extended cab, DRW LB 245,000 miles and counting, Hood insulation delete (Soaked with fuel), Hutch mod, Harpoon mod. Otherwise, pure stock (for now)
You only need two tools: WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
arisley is offline
post #4 of 35 (permalink) Old 09-01-2007, 09:49 AM
ford_doctor's Avatar
The Ford/New Holland Diesel engines were highly regarded for their dependability but as stated, not a super power house. Do remember though, that engine is from an era when most diesels were not zippy power plants like todays high revving turbocharged, after cooled electronically controlled engines. The recommendations for improving power were good but I would not expect to get too much more from this engine unless you know somebody in a fuel shop. Wow. I haven't even seen one of these in about 10 years!
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline
post #5 of 35 (permalink) Old 09-01-2007, 12:32 PM
Fordman84's Avatar
I have a great running 6.6 here in a CF6000 cab and chassis. I can't give the thing away!!! People seem to be scared of them but it seems like a reliable engine.
2006 Chevy 2500HD Crew Cab SB 4x4 LBZ LT3. Driv Devilslide 20x9 wheels with 305-50-20 Cooper Zeon Tires, Magnaflow 4" Turbo Back Dual Exhaust, Edge Juice/Attitude
Fordman84 is offline
post #6 of 35 (permalink) Old 09-01-2007, 07:40 PM
nevrenufhp's Avatar
I'll take it!!!
I think most are scared of the parts & repair costs.
Got any measurements off of it by chance? I could use the length of the head & the overall height.
commuter: 08 VW R32, or 67 F100,300,offy intake,edel carb,274* cam,header
Work truck:'94 IH 4900, DTA466 lightly bombed(#0 fuel plate, timing at 22*, 3 clicks tighter gov springs), Allison MT653, Voith retarder, and straight piped
nevrenufhp is offline
post #7 of 35 (permalink) Old 09-01-2007, 11:25 PM Thread Starter
Just got back from a 380 mile road trip bringing the bus home. It ran great and would hold 60 mph up any hill we went on. Top speed 65 limited by rpm. Little to no smoke and used no oil and had no leaks!! Spent the day today removing the seats in preparation for a camper conversion. Brake system is hydraulic with engine driven pump. It seems that the boost piston is in constant motion when the engine is running; is this normal? Brake warning comes on when the key is turned on and the emergency pump operates-all is ok after engine start. So far, can't find any information on this type of brake system.
wtom24 is offline
post #8 of 35 (permalink) Old 09-02-2007, 10:36 PM
I remember that Ryder used the 6.6's tied to Allison auto's in their fleet of F650's?? for consumer based 24' rental trucks back in the early to mid 90's IIRC. The startup you mentioned about brake warning before starting engine and the electric backup pump running was normal. After you start and the engine pump builds pressure, the electric emergency pump shuts off.
2008 F350 XLT CC DRW 4x4, 6.4, Auto, 4.10, Manual Transfer case, Supplemental Heat, Wide Track Front Axle, Sirius.
1996 Newmar Dutchstar, 8.3L Cummins 6CTA, MD3060 Allison
** SOLD with 80,300 miles ** 2003.25 (Feb. 14, 2003 build) F350 Crew Cab 4x4 XLT, 6.0
unmguy2000 is offline
post #9 of 35 (permalink) Old 09-13-2007, 10:04 PM
Yep, I had a whole fleet of ex Ryder and Penske F750's with the 6.6. I still have one running daily. I agree with everything said above, but i think the 91 will have an aftercooler already on it. I think the fuel plate etc used to turn up the 5.9 cummins will work on this pump, and a turbo upgrade is needed. Otherwise why wouldnt it run as good as any 89-98 cummins 5.9????
Diesel Mechanic 34 yrs Maintenece Manager 23 yrs
Garbage_Mechanic is offline
post #10 of 35 (permalink) Old 09-13-2007, 10:10 PM
nevrenufhp's Avatar
I think a 6.6 would be great in a pickup!
post #11 of 35 (permalink) Old 09-15-2007, 09:56 PM
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: arisley</div><div class="ubbcode-body">Sounds like a good dependable working motor, goes anywhere does anything as long as you are not in a hurry, it's a mule. </div></div>..........6.6L's=401 cid,we had one in a 1990 TW10 ford tractor,it had 110 hp,the TW 20 model had a turbo,hp was 135,the TW30model was turboed and intercooled,had 163hp,Rock solid power plant's never ever had any issue's with them,had over 12000 hr's total on the 3 of them and took vary little fuel, our's at the 110 hp lever used just under "2 gal's an hr" pulling a 18 foot disk with a 20 foot drag behind the disk @ 5 mph or a 5 bottom X 18" plow,that's 90 inche's of dirt X 10 inche's deep being moved@4 mph ,at that time ford had a 3cyl 52 hp @201 cid in the 4600 model and it used UNDER a gal per hr,it had over 5300 hr's when we sold the farm ,4cyl 70 hp @256 cid,and 6 cyl motor 110 hp @401 cid's,they used the same bore and stroke, piston's and rod's in all of them,our's had a CAV inline inj pump on the 6 cyl and 4 cyl,the 3cyl had a sime's rotery pump,fwiw,back then ford did build bullet proof diesel motor's IN HOUSE!!!!,never overhauled any of them,only thing we replaced was the waterpump's on the 6cyl&3cyl,the 4 cyl was never touched@just under3700 hr's,LOVED ALL MY FORD DIESEL'S I had, including my 2002 7.3 that I have now.
2002 F350 4 door Dually XLT lariat PSD Crew Cab 4R100 4.10 VDH4 Prepump, In-Tank, Crossover,Tymar air intake, Edge Evolution, Magellan 6000T GPS, White Night backup light's, DPPI Guages, Walker "Big Truck" Muffler, b&w turn over hitch, pulling a 2004 Sunnybrook 31bwks triple slide 5th wheel. , Total Gross 20900#.truck wt empty 7420# all at the scale, born 05/02/02. bought 06/18/02 & the wife's 2007 eddie bower expedtion 5.4,6 speed automatic ,power everything,redfire & tan.
poppie is offline
post #12 of 35 (permalink) Old 10-29-2007, 11:33 AM
Have a friend who just got a Ford B700 65 passenger bus with a 6.6L Brazilian Ford in it. 30,000 miles! Sounds like a dependable engine.
I am new to diesels, and am learning my way through the 7.3 IDI...so I would love some links to info about the 6.6L if anyone has them. I'm mostly done with my first WVO conversion, and my friend wants to convert also.
Some questions:
Anyone converted these before? Tried blending fuels at all?
It has the Bosch PES injection pump...anyone have info on this IP?
What's the PSI needed on the inlet of the IP? Any more info on the lift pump?
Thanks!
89 IH 7.3L IDI
Blue Bird short bus
110,000 miles
green_bus is offline
post #13 of 35 (permalink) Old 10-29-2007, 10:53 PM
nevrenufhp's Avatar
Your pump would be the PES-6A, or -6MW. It's almost the same as the P-pump they used on the 94-98 Dodges. I got info on how to turn up the pump, if you were looking at a little more power. Link in my signature. The lift pumps rarely go out, that's about all I remember about em.
post #14 of 35 (permalink) Old 10-30-2007, 03:23 AM
My Photos: (33)
well.
they as slow as all Heck and underpowered to boot. But they are damn dependable!
Dualie is offline
post #15 of 35 (permalink) Old 10-30-2007, 10:15 AM
i have had both engines in trucks, the 7.8 was where the power was at, if you could call it that. all were dependeble, and gave no issues. shooting more fuel to them is possible, and makes a difference. i recently bought a bus with a reman 6.6 in it, only 30k miles on the engine. i will proably part it out, if i had the time, i would find me a f450 and stick that dude under the hood. gotta finish my cummins gmc conversion first!
the fleet; ferds ,02'f350,01'f450, 11' f350 the generals ,82'2500, 82'2500 4x4, 82' blazer, 86' blazer ,93'3500, 96'3500, and a 99' 3500hd with 12 valve cummins power. the goats, 90'd250, 91'd350 4x4, all are diesel powered. a list of bigger stuff, as well as gasser's, got lucky, wife comes from a family that collects junk iron too!
navistar45 is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
