A/C stuck on DEFROST.! Its HOOOOTTT here in dallas.! - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 05-28-2006, 02:57 PM Thread Starter
Hey anyone,
2000 f250.
my ac is stuck on the defrost mode...the swtich will not move the air to face or floor or anywhere else..anyone has the problem before?
could it be my vaccuum door flap or acenuator(?) or is it all sensors?? it blows cold air and now it flips back and forth to hot and cold..
any help would be great.. i am about to tear the dashboard!
m
mike5689 is offline
post #2 of 6 (permalink) Old 05-28-2006, 03:30 PM
Banned
My Photos: (38)
Re: A/C stuck on DEFROST.! Its HOOOOTTT here in dallas.!
Hey anyone,
2000 f250.
m
DO NOT tear into the dashboard. It's a vacum leak, or bad vacum pump, or lastly a fuse.
Most common is a leak. Do you have 4x4 w/switch in dash? Check lines going to hubs. You can take out the tee with the lines going to it by the vacum pump and bypass it too.
gregrob is offline
post #3 of 6 (permalink) Old 05-28-2006, 04:23 PM
MarkEkberg's Avatar
My Photos: (13)
My guess is the vacume pump. Little thing on the pass side fender. We just had to replace ours on our 2000. It was $115 from Ford.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
post #4 of 6 (permalink) Old 05-28-2006, 08:35 PM
My 2000 model F350 did the same exact thing last year. It was the fuse.
TDCLefty
TDCLefty is offline
post #5 of 6 (permalink) Old 05-28-2006, 11:06 PM Thread Starter
hey lefty,,
do you happen to rememebr what fuse number it was?
thanks
mike5689 is offline
post #6 of 6 (permalink) Old 05-29-2006, 02:46 AM
klhansen's Avatar
My Photos: (180)
Duplicate post
Please reply HERE
), AIS,
regulated return,
klhansen is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
