I am trying to swap out my DT466 but have stumbled upon a good deal on a DT408 and wondering how compatible they are: mounting brackets, components, fuel system, size of block, year. Any information on these engines would be much appreciated as I have scoured the Earth and it seems no one has any experience or knowledge with the DT408 as International only made them for a year or two. In more detail, here is my predicament....
I have a 1978 DT466 in my 1979 Bluebird School Bus.
Gus Bus's Photos - Vegas or Bus! | Facebook On my drive from Seattle to Austin, we were just outside of Phoenix and broke down. Leading up to this, the engine would over heat in a matter of minutes and we kept stopping to let it cool. After a few more miles on flat ground, a very loud, metal-on-metal rattle started from the engine. It went away but came back in a few minutes and we lost nearly all power. Taking out the dipstick showed that there was no motor oil left (only black muck) and it was smoking heavily from the dipstick tube. After getting towed to Tucson, I took off the valve cover and the oil pan. Both were coated in one inch of black
jello, and I mean jello; it keeps its form and you can ball it up.
While I have been running vegetable oil which probably accounts for the bizarre texture of this alien goo, here is my theory as to what happened: My injection pump started leaking fuel which ended up in the oil sump. The fuel mixed with the motor oil and started forming the black jello until all the motor oil had turned to jello which stopped lubrication of components until something internal blew. I think it likely that, even if we were running only diesel, the fuel would have still mixed with the motor oil, eventually (although possibly farther along) thinning the oil and causing the same end result of a blown rod/piston/camshaft/etc....
Because of the price of an inframe kit ($1500-$2000), and as I have no experience rebuilding engines, I am just shopping for a completely new engine.....which leads me back to my questions about the DT408. Does anyone have any clue about these rare engines?
http://www.thedieselstop.com/forums/...lies/SM127.gif
