General DieselDiscussion about diesels in general. All brands are welcome, please refrain from brand wars. Discussions about types of diesel fuel also go here.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
Nope.....It's fine.....You gotta figure it was layin around a few million years underground once....It don't go bad till you pour it in your crankcase and beat it to death.
95 F-350 DRW extended cab Dixie Custom, 180K troublefree miles, straight pipes, no other mods....Yet.
All of the above. All you would need to be concerned about is whether it meets your engine requirements. (API rating)
Oil is manufactured with lots of additives to stabilize it.
2003 KR F-250 4X4 CC SWB, 6.0, 5 Speed Auto, 3.73 Axle, no Limited slip. Rhino bedliner, Unicover bed cover.
Built on February 19, '03
#2 93 F-150 XLT, 5 Liter, Auto, 4X4, X Cab. 251,000 miles. Uses no oil between changes.
Only if you're the military. Once the expiration date comes around, they get rid of it. I lucked into 10 gallons of gear lube a couple years back that way...
well if its only a few years old i cant imagine it wont be compatable with my '99
__________________ BLACK BOX FABRICATION: OFFROAD BUMPERS, DIY BEAD LOCK KITS, AND MUCH MORE
JEEPERZ CREEPERZ: COMPLETE LINE OF OFF ROAD PARTS AND ACCESSORIES FOR YOUR VEHICLE
Gotta keep that diesel truckin', just put that hammer down and give it hell - Cledus "Snowman" Snow
You are right. Only if it were a year or two older than your truck would I be concerned.
