Cat 3054C DIT - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 04-01-2007, 12:48 AM Thread Starter
Rutcutter's Avatar
Cat 3054C DIT
Is there anyway to turn up a 3054C DIT in a 420E backhoe?
16' SD CC F350 6.7L FX4
White Platinum Tri-coat
Lariat Ultimate Pkg
5th wheel prep
Leveled front
35/12.50/20 Toyo MT's
11' SD CC 6.7L 4x4 (Sold)
08' SD CC 6.4L 4x4 (Sold)
06' SD CC 6.0L 4x4 (traded)
12' CanAm 1000 XT in Camo
12' Cat 430E 4x4 Backhoe Loader/Cab&Air
Rutcutter is offline
post #2 of 8 (permalink) Old 04-02-2007, 12:38 AM
MT765's Avatar
Re: Cat 3054C DIT
I would think the only way to turn it up would be for the CAT dealer to plug their computer into it and turn it up.
10' F-350 Powerstroke CC SB, XLT, 4X4, auto. Stock for awhile.
01' F-350 Powerstroke CC SB, 4X4, auto. MODS: 4" Exhaust with muffler delete, ATS E-Power Tuner, Autometer Phantom pyro, and boost guages, Rapid Flow intake.
MT765 is offline
post #3 of 8 (permalink) Old 04-02-2007, 10:11 AM Thread Starter
Rutcutter's Avatar
Re: Cat 3054C DIT
I may have to call my dealer and see if he can send someone out and put a tune in it... LOL
Lariat Ultimate Pkg
5th wheel prep
Leveled front
post #4 of 8 (permalink) Old 04-02-2007, 11:19 AM
Re: Cat 3054C DIT
When you do call them, please post back here and let us know whether or not they're willing to do that. The reason I ask is that my understanding has been that in the case of stuff like earthmoving equipment, you generally don't want to do that because engine power is normally set to work within the limits of the hydraulics. I've been told that turning one up often just results in pressure relief valves opening more often, accomplishing nothing except the consumption of more fuel and the generation of extra heat in the hydraulics. I guess that isn't necessarily true in all cases though.
1998 Dodge 12v 5 spd 2wd dually, 275k on truck, bhaf, CPP 7x10 injectors, timing at 19 deg, 3k gsk, no fuel plate, htb2 64-13 turbo with stainless exh housing, wastegate set at 50 psi, southbend dual disk clutch, detroit locker, has broken 2 stock dana 80 limited slip units, has run 14.65 at 98 granny shifting the 5 spd, dynoed at 450 hp and 906 ft/lbs on REALLY STINGY dyno
v8440 is offline
post #5 of 8 (permalink) Old 04-02-2007, 02:00 PM Thread Starter
Rutcutter's Avatar
Re: Cat 3054C DIT
Thats true V8440,didnt think of it like that,probley just gonna leave it alone.
Lariat Ultimate Pkg
5th wheel prep
Leveled front
post #6 of 8 (permalink) Old 04-03-2007, 12:25 AM
Re: Cat 3054C DIT
The 3054C engine uses a Delphi DP200 injection pump (pump and nozzle system) there is no way of electronically turning it up. Also dealers don't touch those pumps they just remove them/replace them or send them out beacuase they themselves don't do the adjustments. Really the most common power adjustment done is on 3116's in the older 953 and 963s where you can adjust timing and max fuel so the engine doesn't bogg so much when going against a pile.
(actually there are alot of power adjustments you can make on machine engines but not really on backhoes whats the point) I would say if you want more digging power adjust compensator and load sensing (signal pressure) on the pumps.
juggernaut150 is offline
post #7 of 8 (permalink) Old 01-16-2012, 08:41 PM
Do any of you guys have access to a shop manual for the 3054c engine? I bought a new injection pump and need some help re and reing it. Very framilliar with Cummins but Cats are a little difffrent.
Grinding1 is offline
post #8 of 8 (permalink) Old 02-15-2012, 10:26 PM
there is actually a company that makes a plug and play for ag-ind engines--google it
trukdoc is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
