Cat 3116 No throttle - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Old 11-01-2008, 12:50 PM   #1 (permalink)
ClassicIDI's Avatar
Ok guys i just bought a 1995 Kodiak with the Cat 3116 in it. The truck has 450,000 miles and has been sitting for several months. So far I have replaced both fuel filters added five gallons of fresh diesel. And made sure all the fuel lines are free of blockage. I also disconnect the supply line at the injection pump connected a little tank of diesel hanging from the mirror kind of an IV drip of diesel, and after bleeding the air from the head with this method the truck started and idled but was completely unresponsive to any throttle input and also was smoking excessive amounts of white smoke. I had it running like this for probably 15 min when i reconnected the regular fuel line the truck would not restart. I am thinking it has a weak transfer pump and can't draw fuel from the tank and with my IV connected draws just enough to idle.
thanks for any help
1988 F250 extra cab long bed 4x4. Hypermax turbo and intercooler. Converted to a ZF5 and NAPA solid flywheel and clutch 285/75/16 Yokahama A/T's, exhaust, Vac, water, and boost gauges. 4inch lift and now Dana 60 front
Early 99 F-250 extra-cab temco 8ft Flatbed 4x4, Detroit Transmission performance built auto trans, 4 inch superlift, 2004 HP60 and 10.5, converted to manual shift t-case. triple guage pod, pyro, trans, boost. 4 inch straight pipe into duals, K&N open air intake,DP tuner, 6.0 Tranny cooler, Beans D66 turbo with ebpv delete pedistal, Banks Big Head, AD code injectors, adrenaline High pressure oil, CB radio, Full audio system with JL audio stealth box 10" sub, 2005 front Seats and 2006 Harley Headlights
ClassicIDI is offline
Old 11-01-2008, 02:19 PM   #2 (permalink)
My Photos: (5)
White smoke isn't usually a sign of an engine starved for fuel.
Originally Posted by ClassicIDI View Post
... a little tank of diesel hanging from the mirror kind of an IV drip of diesel ...
Sounds like somebody's been watching too much Red Green.
Douglas Campbell, P.E.
1986 Isuzu P'up, 177,673.8 miles.
- Hella headlights (highly recommended)
- DOT C-2 back end (also recommended)
- R-12 air conditioner converted to R-406a. Saved ozone and money
- 4.1:1 final drive converted to 3.4:1. Quieter, better mileage but it's a good thing I live in the flat Midwest.
- 9/22/2007, age 21: Still running well when reluctantly sent away for reincarnation, due to body & frame rust.
drcampbell is offline
Old 11-02-2008, 01:11 AM   #3 (permalink)
ClassicIDI's Avatar
Not true I used no duck tape in the making of my IV
