Did you do the step up test on ET and check actual VS desired ICP.Also there are plugs INSIDE the Oil galley on certain years that go strait in to each Injector bore.They have been KNOWN to come out.This will cause a performance problem and Erratic ICP.Sometimes that particular Injector where the plug may have came out will fail sometimes it wont.There are 6 external plugs on the outside of the Oil rail.Drain the rail first then remove these plugs on the SIDE of the rail.Its tough but you can look strait in the hole and you should be able to see another allen head plug right inside the rail.Each cylinder will have one.IF you find one missing remove the large plug on the rear of the rail and usally its right there.It CANNOT go anywhere else or into the engine.I would also stick a long head allen in and check that each one is tight if you decide to do this.Also when you decide to do the ICP test and fing that there is a problem.You will also have to pull the V/cover and depending on the year of the engine it may have a Bad jumper tube that feeds a inj or blown or leaking O-rings on the Newer style heui's there is alot to look for.
07,F-250 4X4 6.0 Torqshift, Lariat, Highline package, S/C LWB.
