Go Back   Diesel Forum - The Diesel Stop.com > Other Topics > General Diesel
Old 09-01-2008, 12:02 AM   #1 (permalink)
Cummins 4BT in a full size 80's van?
I have noticed that people are selling the full size 80's and even 90's for cheap. I would like to get one and put a diesel in it so that I can afford to drive the thing. Several people have mentioned the Cummins 4BT as a good option to drop under the hood along with a 5 speed standard transmission that originally came with it.
The weight of the engine is not to far off the weight of the V8 that would be taken out. The size is also pretty close.
I am going to be doing 70% highway miles and 30% around town.
Will an engine like this have enough power to move my van and 5 or 6 people along at 65 mph? Will it give adequate acceleration to help me merge onto the freeway?
What are your opinions?
Pengyou is offline
Old 09-01-2008, 12:56 AM   #2 (permalink)
It would be a sweet swap, but it will take some serious effort. But very cool.
1993 Ford Bronco, 351W, Manual transmission swap (M5OD) THE TOY
1996 Ford F-150, 300 I6, Manual transmission,2WD 157,000 miles, going up for sale to get my diesel
I SPEED UP TO RUN OVER HYBRIDS
B-rad is offline
Old 09-01-2008, 02:12 AM   #3 (permalink)
SIC-E's Avatar
thought about a 4bt in an ol' jeep, but a full size truck...for highway...? dunno
good luck with it.
2004 E450 Cutaway, 6.0L, quigley 4x4, ambulance pkg., maxbrake controller, curt 20k fifth wheel. Future mods: 52" sleeper, tandem (6x6?) rear (aint look'n likely), frame cover. maybe a Herd front bumper.
2003 F350 Lariat, 4x4, CC, SRW, Dark Green Fx4 SOLD
1995 C3500 6.5l work trk, 2x4, CC, DRW, white DECEASED PREMATURALLY
2003 JEEP WRANGLER, ooooops, not anymore!
1986 26' Seaway Northstar w/ 454 Mercruiser
2008 Montana Mountaineer 332PHT
1991 GMC Topkick, CAT, 4' vert. gang boxes, 12' dump. if only all were as reliable!
SIC-E is offline
Old 09-01-2008, 04:13 AM   #4 (permalink)
I would think that it would work fine, it would just be like a good ol' 6.9 it may take ya a bit but you will get there.
B-rad is offline
Old 09-01-2008, 08:38 AM   #5 (permalink)
There is a couple videos on youtube of a cummins powered ford van.
2003 E-350 7.3, 38R, DIY intake, 4" turbo back, DP Tunes, forged rods, exhaust ported heads, comp 910's, h-11's, stealth twin pumps, 230cc hybrids, racerx trans and tc, water injection
rpm1 is offline
Old 09-01-2008, 12:25 PM   #6 (permalink)
If I recall, I think the 4BT was actually an engine option w/ the GM chassis when 3rd party manufactures put a box body on it. But that may have been later models....
1999 E-350 Cub Wagon, 7.3L Power Stroke, E4OD, 3.55
1990 E-350 Club Wagon, 7.3L IDI, E4OD, 3.54LS
1983 F-150 2x4, 4.9L, C-6 w/GV-OD, 3.55 Farm pickup
1981 C-8000, 3208 CAT, RT-6510, Rockwell SSHD Tandems (Swap)
1977 K100C, NTC-350, RT-1110, Tandem
1977 Transtar II, NTC-290, RT-9509 Single
1977 Transtar II, Formula 290, RT0-9513, Tandem
1974 C-750, 391CID, Clark 5 speed, Eaton 2 speed
Kaliburz is online now
Old 09-01-2008, 11:28 PM   #7 (permalink)
I would think...because that engine is used in UPS-type vans and are drive on highways....it should be able to move a vehicle smaller and lighter as well.
If I took an engine/tranny combo and dropped it into the van would it really take a lot of work? I am not interested in trying to make the engine up with the prior tranny - I want a 5 speed manual to take advantage of the engine's characteristics. I would not be looking at a newer engine with all of the electronic gadgets that go with it.
Pengyou is offline
Old 09-22-2008, 09:47 AM   #8 (permalink)
The 4bt is great on fuel, but will vibrate your eye teeth out. If ya dont mind the vibration, it will move it fine. At Cummins, the tech center has had a really nice ton 15 passenger van running with one for a while.
1987 F250 2wd 6.9 C6 orphan truck,with a new lease on life.
35 years wrench slingin,gettin over it fast.
Owned many diesels,Cummins, Detroit,and this is my 4th Navistar.
tlm47201 is offline
Old 09-22-2008, 01:08 PM   #9 (permalink)
Consider a 3 point mount with relatively soft mounts for a big 4 cyl diesel. That will mitigate the vibration.
Regarding the adequacy of the motor, the Europeans and Japanese regularly use 4cyl ~4L turbo-intercooled diesels in class 4 and 5 trucks. It should be fine unless you envision yourself towing 10 ton trailers uphill at 70mph. The Mercedes Sprinter 3500 uses what, a 3.2L?
Charlie
diesel Landcruiser & M37; 05 Unimog U500 w/Unicat camper
Charlie is offline
Old 09-22-2008, 02:09 PM   #10 (permalink)
FionaThe02PSD's Avatar
My Photos: (12)
It all depends on your skill level and budget. I have a buddy with a 66 Bronco and a killer 4BT in it that is right around 400HP..
2006 Dark Slate F350 CC LB 6X6 Lariat Complete with training wheels.
Vegetarian, an old indian word for bad hunter!
K&N Intake, Ragin' Coolant filter, SCT from ID, Recon smoked LED tail lights, clearance lights, Center bumper LED's, and Fat fender smoked LED lights, Pressure pro TPMS, Firestone Ride rite bags, Alpine/Infinity/Polk sound system W/Sirius, Autometer Phantom EGT,Trans,Boost gauges above the rearview mirror.
For the BEST in performance parts and accessories ITP Diesel
Arizona Powerstroke Group
FionaThe02PSD is offline
Old 09-24-2008, 06:31 PM   #11 (permalink)
Thanks! Is there any way to get the vibration of the 4BT softened enough to be only slightly noticeable? I have already decided to almost soundproof the interior so noise would not be much of a big deal. I read somewhere of a harmonic balancer "thingee" that could be put on the engine to dampen vibration considerably. Any ideas?
Pengyou is offline
Old 09-25-2008, 06:11 PM   #12 (permalink)
My Photos: (12)
We put a Fluidampr on the one in the Bronco. It's still loud though...
Old 09-26-2008, 08:41 PM   #13 (permalink)
What kind of noise? Is it the valve rattle? or the sounds of aspiration, i.e. sounds of air being sucked in?
Pengyou is offline
Old 10-09-2008, 07:27 AM   #14 (permalink)
Seafarer12's Avatar
It would work but It will be loud, shake like a 300lbs stripper and depending on the version you get low on power. You also have to look at what transmission you are going to run. If you are going to be running that much highway you will need over drive. Then look at cost vs reward. Cost per mile will probably equal a newer minivan. You probably wouldn't save any money on operating costs.
Sold, 97 F250 Supercab back to the 85 S10 and loving it.
Seafarer12 is offline
Old 10-09-2008, 04:59 PM   #15 (permalink)
If you are doing it only because of cost of fuel, be careful. Likely you could motor on for nearly forever on a fuel injected 351 vs. the cost of putting a 3.9BTA in. I'd suggest doing a spreadsheet and using current prices to anticipate project cost.... I assume you'd be using a Ford van, so would you use a GM trans? Not that you couldn't but factor in mounts, driveshaft, maybe wiring or control, etc. I could see a 3.9BTA, done right, costing $3-6k. That might buy a lot of (cheaper) fuel. How long would your payback be estimating your MPG for the stock gas van and a BTA? Right now around here gasoline is 75% of the cost of diesel. So if your mileage is only incrementally better, it would be a wash. I think I got around 16-17 mixed driving with an 89 F250 4x4 5 sp. I'd expect a half ton van to get marginally less.
Also given that you are much closer to the engine in a van than a truck I'd think sound attenuation would have to be top priority.
But if you want a diesel because you want a diesel, have at it! I "upgraded" to my 01 Dodge from an 03 Focus SVT. Totally different but fun in its own way.
2005 Volvo S40 T5
2001 Dodge 2500 Cummins
1987 Mercury Grand Marquis
1974 International 100 4x4
1931 Caterpillar #9 Auto Patrol Motor Grader
Forcus is offline
