Cummins 4BT Performance - Diesel Forum - TheDieselStop.com
post #1 of 24 (permalink) Old 11-28-2005, 07:19 PM Thread Starter
What kind of HP can a guy get out of a Cummins 4BT and still have a reliable, 300,000 mile engine? I am talking about a light duty application, commuting back and forth to work under the hood of a Chevy Tahoe (or something similar) towing maybe 5 times a year maybe 30 miles a pop (a 20' boat). Of course it will have guages and all of the typical stuff.
Also, what sort of cash am I looking at to mod it? I know it is similar to the 12V Cummins, which makes HP rather cheap. Are any 12V parts compatible with the 4BT, like the throttle plate (or whatever it is called) or performance injectors?
I started out thinking that an Isuzu engine out of an NPR would be the way to go (3.9 liter 4-cylinder) because I thought it would be more compatible with the Chevy, but it did not seem to be. Coupled with the fact that it is electronic, I decided that the only way to make it happen would be to buy a donor NPR and strip it of the stuff needed to make it run. Sounded like too much work, so the Cummins just got more interesting.
Just so you know, the reason for all of this goes something along the lines of:
1.) because I can, and it would be cool;
2.) biodiesel, biodiesel, biodiesel;
3.) because they did not put a factory diesel in anything but the 2-door tahoes (as far as I can tell) and we want a 4-door;
4.) because I am counting on the 4BT getting better fuel economy than the 6.5 anyway;
5.) because I can, and it would be cool; [img]/ubbthreads/images/graemlins/smokin.gif[/img]
This would be so much easier if they would just put diesels into these rigs to begine with!!!
'99.5 PSD 6 SPD 4x4 Extended Cab long Box F-350
AFe Stage 1 intake, Marinco Block Htr Plug Mod., Hutch in-Tank Pickup Mod, $10 AIC, Walker BTM, Edge Juice with Attitude, and that is all, FOR NOW!!! Next mod = Regulated Return???
Old Truck - '95 PSD 5 spd 4x4
Haulin' a 11.5' camper, an '85 Bayliner Capri 20' boat w/ Chevy 350, and a flatbed w/ two big quads.
2004 Grizzly 660 Yamaha (For Me)
2004 Polaris 500 HO (For the Wife)
Spokane, WA
"I don't ride bulls, but I have fought some men" Hank Williams, Jr.
"Sie vie pacem, para bellum" (if you want peace, first prepare for war...)
Hoss350 is offline
post #2 of 24 (permalink) Old 11-28-2005, 08:25 PM
Re: Cummins 4BT Performance
basic HP with a turbo is 105 HP. If your looking to put it in a Tahoe, then your best bet would be finding one out of a delivery van like Frito Lay or something like that. Those came with the adapters and a TH400 tranny behind them. Not sure what all can be done with them for increase in performance though or how much abuse they can take.
'03 F150 Supercrew FX4. Little 1/2ton that gets 15 MPG on 23 gallons.
'06 F250 FX4 CC SWB
MudHog is offline
post #3 of 24 (permalink) Old 11-28-2005, 08:35 PM
My Photos: (17)
In the marine world we see a lot of 250HP 4BTs and they are grenades. They don't last more than a couple of hundred hours at most without some sort of problem. Usually burn up injector tips or overheat plus they shake, rattle and roll so much all sorts of parts and pieces break off. Over 80HP/cyl is too much. I think 150-170HP should be max for this size engine for what you want to do with it.
Shimon Mor
1985 F250XL, 6.9L, C6, 4x4 (BW1345), Dana 44HD front, Dana 70 LS 3.54 rear, 190,000 miles, Rebuilt longblock (88,000 miles), ARP studs, electric fuel pump, Edelbrock Performer IAS shocks, Velvet-Ride Shackles, Firestone Airbags all around, Transfer Flow fillnecks, lots of gauges, Line-X, Jordon Brake Controller, B&M Stacked Plate Transmission Cooler, TCI Aluminum Transmission Pan, Banks Sidewinder (wastegated)
shimonmor is offline
post #4 of 24 (permalink) Old 11-28-2005, 10:26 PM
Seafarer12's Avatar
The newer 4bt with an inline pump make 120hp and 300 lbs. I think you can use the same fuel plate to stoke it up some. People want a premium for these engines you coud probably do a 6bt for not much more money and there wouldnt be any problem with power. I think it would be fine just driving but maybe lacking when it comes to towing.
Massey 65
Seafarer12 is offline
post #5 of 24 (permalink) Old 11-29-2005, 01:09 AM
I have a Cummins 4bta in my 1996 Bandit chipper and it's rated at 116hp.
1987 Ford F-350 FWD 4spd. 6.9L International Chipper Dump w/tool boxes for Arboricultural work.
1983 Ford F600 Allison 545 Auto 8.3L Detroit Diesel w/15ft. Chipper Dump.
1985 International S1900 DT466 5spd 2spd rear
1996 Dodge 3/4 Ton 4WD extended cab 5.9L Cummins Auto Trans.
Two stump grinders with 58/75hp. Duetz diesels.
Bandit chipper w/116hp. Cummins 4BTA diesel.
Bobcat 7753 with 46hp Kubota
DanNelson is offline
post #6 of 24 (permalink) Old 11-29-2005, 05:36 AM
Have you thought about the 4.5 liter baby stroke. That would give you alot more oomph and will probably last longer since they are specifically made for those type of stop and go applications as our autos. Dual exhaust out the back.
HACKY
1996 F350 PS w/extang tonneau cover, 4" magnaflow exhaust, afe air intake, and edge evolution chip programmer. 10k mod and shimmed FPR, and have the 5th wheel in the back. Living in the land of Potatoes.
What I want to do: Anything and everything to this truck.-Use the FORCE wisely, MAXX...
560TURBO is offline
post #7 of 24 (permalink) Old 11-29-2005, 07:56 AM
Seafarer12's Avatar
I doubt he wants to spend that much and he was wanting something without electronics.
Massey 65
post #8 of 24 (permalink) Old 11-29-2005, 11:40 AM Thread Starter
That would be just about perfect. I am looking for something similar to the 6.5 power-wise, and this is getting close enough. Not looking to build a drag racer. Also, in your marine applications, at 250 HP, they are probably running 90% power full-time (or close to it), where in this tahoe, it would not be at 90% power for any more than a couple seconds a day. I wonder if a 190-200 HP 4bt would hold up under these conditions? It is such a light application.....
Spokane, WA
Hoss350 is offline
post #9 of 24 (permalink) Old 11-29-2005, 11:43 AM Thread Starter
I considered this, but the problem is twofold:
1.) the tahoe is a half-ton, and I don't want to go to a 3/4 ton suburban, so the weight issues associated with a 6 would all but eliminate the possibility of sticking it in a tahoe
2.) this would probably not do me a whole lot of good fuel economy wise. I am hoping that by going a bit underpowered, I can get good fuel economy.
I appreciate the help! Keep it coming, guys!
Spokane, WA
Hoss350 is offline
post #10 of 24 (permalink) Old 11-29-2005, 11:49 AM Thread Starter
Considered, but I don't want to spend more for the engine than for the truck. Also, I was seriously hoping to get away from the electronics issues associated with the newer model engines (even the 6.5 liter TD, for that matter) because that ususally means finding a donor vehicle, if you don't want to mortgage your house buying everything new. Finding a donor vehicle with a 4.5L would be next to impossible, and then i would have to have a donor vehicle in the yard, and I just wouldn't like that at all... I have seen 4BT's for sale in the $3,500 range. A 4.5 baby stroke would probably end up costing me 15K at least.
I am not all that concerned with it being a drag racer. 180 HP with the amount of torque and low RPM power band you get out of these diesels would be PLENTY. At that HP level, it would probably feel pretty peppy because you would get into the power band so much faster and at lower RPM than a gasser. The 350 in the tahoes used to only make 200 HP with less torque than a comparable 4BT, and they did fine.
I am just curious if in such a light duty application, the 4BT would hold up at 180 to 200 HP. (figuring use of guages, pyrometer, etc)
Spokane, WA
Hoss350 is offline
post #11 of 24 (permalink) Old 11-29-2005, 01:03 PM
You should check out some of the Toyota landcruiser/jeep forums. cummins swaps are very popular and some of them have the wisdom of having run these engines for a while. I think in the right application they would do a great job.
johnraym is offline
post #12 of 24 (permalink) Old 11-29-2005, 10:10 PM
Yeah marine is a different ballgame. Not comparable at all.
BigDaddyT is offline
post #13 of 24 (permalink) Old 11-30-2005, 03:39 PM
mjm
Another option, but I still think it might be too heavy and large for a 1/2 ton, is a Detroit Diesel 4-53? Here are the specs I was able to find: 140hp, 2800 rpm, LxWxH = 39 x 27 x 37 inches, 1110 lbs. Noise supression is advised!
93 F350 7.3L IDI Turbo, 4X4, Crew Cab, 5-speed, 3:55, stock, 100K miles;
01 Jetta TDI, 90K miles;
83 MBZ 300D Turbo Diesel, 287K miles;
John Deere 870, 28 HP 3 cyl Yanmar Diesel;
70 Torino GT, 429, C6, 3:00, 58K original miles;
JD 350C Dozer; Intl S2500 DD 6-71, 8LL Road Ranger
mjm is offline
post #14 of 24 (permalink) Old 11-30-2005, 05:24 PM
Seafarer12's Avatar
A 4-53T makes about 170 but I think a 4bt would be more user friendly. No problems with cracked heads. Don't have to adjust the rack. I knew a guy with one in a half ton it did alright just loud. He got about 28mpg out of it.
Massey 65
post #15 of 24 (permalink) Old 11-30-2005, 10:44 PM
Ever thought of using a Peninsular Diesel 6.5 crate motor? Its a bolt-up and you can get 240-300 HP, depending on which turbo you use.
At this HP, it might be more reliable.
'00 F-350, 4x2, 6 Speed AIC 210,000 miles
3.08:1 Gears
Fuel tank mods: MaroonHarpoon, Pre-Pump,
Evans, 203 degree thermostat, Poor Man's Tymar, 4" Single SS Exhaust, Rugged Air Dam
225-75x16E tires in front 235-85x16Es in back, tires aired up to 100 psi, Lowered 4" in front and 6" in back, "Fastback" bed fairing
21.3 MPG before mods
27.0 MPG tested with mods
Dave Whitmer is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
