Cummins 8.3 Ford L8000 ** HELP ** - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 12-03-2009, 02:45 PM Thread Starter
I have a 1996 Ford L8000 with Cummins 8.3
I bought it about 6 months ago... it fired up when i bought it and i drove it for 6 hours with no problems. I parked it and fired it up again 2 days later, and then it sat for a week then wouldn't start. (i think a switch got left on somewhere).
I replaced all 3 batterys and have power now, only now it won't start. I sprayed a little starting fluid and it tried to turn over but wouldn't stay.
Someone told me to change the fuel filter and add "diesel 911" to it.
A buddy told me that he has to plug his diesel pick up in for a couple hours for it to start, but mine has no plug anywhere that i could see.
I don't know. I have never owned a diesel, let alone a diesel dump truck of this size.
I need some help please.
Thanks.
SilverTouch is offline
post #2 of 3 (permalink) Old 12-03-2009, 05:56 PM
Sounds like you might have some air in the system. Is there a primer on your fuel transfer pump? The transfer pump should be on the driver's side of the engine, just below the fuel filters. The fuel line going from the filters to the inline pump should have a banjo fitting that has a 10mm bleeder screw in it. Loosen that and try and prime the fuel system by hand. There should be another bleeder, on top of the fuel filter housing on the return side that takes a 12mm wrench. You might loosen that one and try and get fuel out of it too. Try and keep pumping until you get fuel with no air bubbles in it and the primer gets hard. If that doesn't start it. Crack the nuts on the fuel lines that go into the injectors and crank the engine until you see fuel squirting out of them and then tighten them back up. It might be something else yet but should be a good place to start.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters. SD starter. DP 80hp tuned PCM.
'04 F550XL reg. cab. ZF-6 speed. EGR delete. Coolant filter. Cat EC-1 coolant. LF777 bypass oil filter. Blue-spring fuel pressure regulator. ScanGauge II. Glowshift fuel pressure gauge.
'06 F350 xlt crew cab. 5R110 auto trans. 4x4. EGR Delete. DIY Coolant filter. Cat EC-1 coolant. Blue spring fuel pressure regulator. Open CCV. SCT X4 Gearhead Tunes. Dual SPA fuel/oil pressure gaugeWicked Wheel 2.
sdan27 is offline
post #3 of 3 (permalink) Old 12-03-2009, 11:33 PM Thread Starter
Thanks. I do remember seeing a primer. it said something on it about pushing it to get water out and then something about getting air out. it has a drain knob on the bottom of it. Not knowing what the problem was i replaced both of the fuel filters.
Thanks for the direction though. i will try that tomorrow. hopefully it works.
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
