cummins in a ford - Page 2 - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Old 10-04-2005, 08:54 PM   #16 (permalink)
Re: cummins in a ford
From what I understand... body lift is needed for folks doing NEWER Cummins conversions because the oil pan on the 04.5 and newer engines is so deep.
- SOLD: 1991 F-350 XLT crewcab, dually. BTS E4OD. My favorite truck.
- NEW DAILY DRIVER: 2006 Ram 3500 SLT quad cab. 5.9L Cummins, 6-speed manual transmission, nav system, Jake brake. No mods, now or ever. 100% satisfied.
Mike Lewis is offline
Old 10-09-2005, 08:59 PM   #17 (permalink)
IS ther a place on the east coast that does the installs of the cummins engines?
2000 Ranger V-6 115K miles
2001 F-350 Fummins
1998 Dodge 2500 SC SB
Lee Haenschen is offline
Old 10-09-2005, 09:59 PM   #18 (permalink)
Wobblin-Goblin's Avatar
Just imagine the utter practical beauty of a Cummins 5.9L in a brand-new Super Duty.
Ahhhh.
2003 F-350 SRW XLT 7.3L 4R100 PSD 4x4 Supercab SB 3.73
1985 Chevy K20 6.2L Turbo-400 3spd auto 4x4 4.10
2003 Ford Explorer XLT 4.0L V-6 5-spd auto 4wd 3.55
16' American Hauler tandem axle cargo trailer
NRA Life member
Wobblin-Goblin is offline
Old 10-09-2005, 11:08 PM   #19 (permalink)
My Photos: (29)
How much $$$ did you guys end up with in your conversions? with engines seperate if you don't mind.
I'm looking at purchasing a 95 F-350 crew cab dually 4x4 with a 460 but the only way I'd buy it is to put a diesel in it. I'm trying to figure out what I can do cheaper, a cummins or powerstroke swap.
Thanks, Jeff
New Truck 2006 GMC Duramax/Allison 4x4 extended cab Long Bed. Stock for the next 3 years
96 F250 Powerstroke 5 Speed 4x4 4:10, LUK Single mass flywheel, EBPV gutted, TYMAR 3x4 DP and Straight 4" exhaust, Air bags up front with rebuilt Dana 50 and energy suspension bushings.
Isspro EV pyro & boost, Wildman 4 pos chip, JS IDM, SP perfofmance module, Baby Swamps. Gone Bye ByeMy Pics
Dirt_Farmer is offline
Old 10-09-2005, 11:32 PM   #20 (permalink)
Factory did not make a dually 4x4 crewcab in 1995. Some one has already started mods. Most that I have seen used spacers for the rear wheels and you still only have the 6250# gross axle rating. Read the axle code tags to verify which axle you have. The pick up dually axle was rated at 7400# and the chassis cab axle was rated at 8250# but will not bolt into a pick up because of the wide pick up frame versus the narrow chassis cab frame.
EDWARD
EDWARDWD is offline
Old 10-09-2005, 11:38 PM   #21 (permalink)
My Photos: (29)
Sorry it's a Centurion conversion, factory dually front axle added and t case added.
-Jeff
Old 10-09-2005, 11:40 PM   #22 (permalink)
brahamfireman's Avatar
The Fummins
I am not sure why a Body lift would be needed except for maybe an Allison. I am going to put a E40D in this winter. It has a ZF5 speed now but I hate to shift so its gonna have to go. I think its about as clean of an Install as your gonna find. Exhaust on the second page is out dated.
I have seen this truck in person and its SWEET very clean, and looked great on the dyno too. [img]/ubbthreads/images/graemlins/smokin.gif[/img] [img]/ubbthreads/images/graemlins/smokin.gif[/img]
very interesting thread, I wanna do one in the '96 this winter, any one know how I can get a motor, there non existant around here...
Diesel Rod
Formerly Diesel Rod.
A '97 F250 with 295K miles, 90 LED's and 5" stacks, among other things....
A '96 F250 Reg cab with 210K miles, Needs to go away. PM me.
'86 359 Peterbilt SHORT HOOD. The ongoing "project" it aint pretty but its got a 425 air to air Cat motor .....13 speed Eaton. Corvette Dash, 17 gauges, 8" black stacks, 63" flat top---> 36" sitting here waiting for paint. 1.305 Million Miles.
I don't know what I am doing, I just know I don't have time to do it.
brahamfireman is offline
Old 10-10-2005, 08:21 PM   #23 (permalink)
My Photos: (29)
Well I was wrong, it's a dually conversion. I'm not sure I want it now. I got them down to $5100 out the door tonight but it has some problems.
Does any one have an estimate on what it would cost to put the cummins in it? I was figuring around $2000 for the adapters plus engine and will probobly need a tranny rebuild in the near future.
Thanks, Jeff
Old 10-10-2005, 10:01 PM   #24 (permalink)
Jeff. Go on Google or any good search engine and type in ford cummins conversion and you'll come up with a lot of good info.... Good luck...
Al
1991 F-350 XLT Lariat 4x4. Metallic Midnight Blue over Silver Gray.. Canadian Made. Now has 82000 miles. Std Cab SRW-7.3 With a Banks Stinger Kit. ZF-5 speed- 4:10. Five rear overload springs rated at 3000 lbs, Smitty Built side step tubes, mounted to frame with 1/2 " steel plate.. SteelHead sliding rear bumper. SteelHorse overhead panel with a Cobra 25. Dash mounted compass and altimeter, pillar mounted Banks pyrometer. 11.5 FT camper in the bed 99% of the time. Camper has been restored all the way out from it's frame. Camper has two #30 batteries, good for a week dry camping in the woods..
--- Two 1978 Bronco's- One stock 400 cu" and one Bombed 406 cu"--- 1972 E-200 van. 302 cu"--- 1975 F-600 with 361 cu" Industrial engine.
HiWayMan is offline
Old 10-10-2005, 10:12 PM   #25 (permalink)
My Photos: (29)
Thanks Al, I looked at a lot of the conversion sites and got a rough list of parts and adapters I'd need but (around $2000) I'm still wondering if theres some cost (parts) I'm not thinking about.
Thanks, Jeff
Old 10-10-2005, 10:12 PM   #26 (permalink)
Thanks, Jeff
From what I've read, the Cummins engine itself will run $5000+ (if you buy one of those factory takeouts or out of a new wrecked Dodge), a transmission built to match/handle it will cost $4000 +/- a few $100, adapters, motor mounts, electronics, and incidentals will run another $2000 or so. So you're looking at least $10k or more just to get it running and driving.
With all that being said, I'd find a rough 89-93 Dodge D-250 Cummins and junk the truck and have the engine rebuilt and go from there. These trucks even with the Cummins can be found dirt cheap (less than $4000) if you look in the right places. Another benefit is having the mechanical injection and ease of making power with the 12v head.
<font color="blue">2005 National 2nd Place Winner in Agricultural Mechanics in Repairs and Maintenance for The National FFA Organization.</font>
2004 Ford F-250 XL Regular Cab Longbed 4x2, 6.0L PSD/TS Auto, 3.73, stock for now. Tekonsha Prodigy, Curt Mfg. 10k WC/12k WD receiver hitch.
Traded in: 1995 Ford F-250 XLT Super Cab Longbed 4x4, 460, auto, 3.55's., K&N filter, glasspack duals. Miss everything about this truck but the gas mileage....
Some days you're the dog.....Some days you're the hydrant.
Mwheeler is offline
Old 10-10-2005, 10:42 PM   #27 (permalink)
Thanks, Jeff
You're welcome Jeff. And like Deerepower said try to find and older 12 valve.. Keep your eyes open for a older wrecked dodge truck.(roll over or rear ended) you don't want major frontal damage. If you find a good "donor truck" take what you need and sell the rest. The 94-98 5.9's have the P7100 inline pump. They are very good... Go for it Dude!
Al
HiWayMan is offline
Old 10-10-2005, 10:44 PM   #28 (permalink)
That is what I have sitting in storage. A rolled 91 with a new tranny. I know the records since it was mine and my dad rolled it [img]/ubbthreads/images/graemlins/shocked.gif[/img]
Thanks, Jeff
2003 4x4 crew cab 7.3 4x4 auto ,203* thermostat w/billet housing, Bob Riley Water filter, Magnaflow XL 4" exhaust, HX mod, DI 4 Position Chip(stock /40/80/100),AFE series 1,
intank / pre-pump mod , intake heater delet ,
shift kit, DiPricol gauges, DI regulated return, Retrax Bed Cover
cjheap is offline
Old 10-10-2005, 10:47 PM   #29 (permalink)
And are you selling it?
HiWayMan is offline
Old 10-10-2005, 10:51 PM   #30 (permalink)
no crap, I will drive to texas this winter. its gunna be a long one.
5 speed or auto???
Diesel Rod
