Cummins Hydroboost question...need serious help?! - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 09-09-2006, 04:01 AM Thread Starter
Alright...My buddy has 00 Dodge 3500, automatic, Cummins, 4x4. His brakes went out like he had no assist at all and it would barely stop...it took several hundred feet to stop from 70 and the pedal went all the way to the floor and didn't come back. So I put a new brake booster (hyrdroboost assembly) and a new master cylinder on it and still...no brakes, pedal goes to the floor. I did the whole fill it with fluid turn wheels back and forth turn it off pump pedals a few times and start it...repeat...Well I repeated til I can't repeat any more and still...no brakes. ABS light is on, BRAKE light is on (one in the gauges)...the pedals goes to the floor (making a hissing sound) and then comes back real slow. It is not leaking fluid from anywhere and we bled the brakes. Still nada. I worked on it for several hours AFTER the new parts were installed to no avail...if someone could please help me out or send me in the direction of someone that knows please let me know...hell you can even call my cell phone....I would appreciate any help ya'll can provide.
Thanks,
Daniel
(Late)99 F-250 XL-Work Truck Special -Super Cab-4x4-6 spd-LWB-Homemade cold air-Edge Evolution-straight pipe-3inch lift-280k miles
SOLD-89 F-350 Single Cab-SRW-Banks Wastegated Sidewinder-Straight piped-5 spd-LUK clutch-Single Mass Flywheel-Isspro gauges
nostroke is offline
post #2 of 3 (permalink) Old 09-09-2006, 12:04 PM
Re: Cummins Hydroboost question...need serious help?!
Is your vacumm hoses hooked up or is it that cummins has some kind of pump I think that works off of pressure. Cant remember had a 01. Just a thought.
2006 Ford 250 4x4 crew cab short bed auto
front windows 20% and back factory with 35%
auto meter gauges
4inch exhaust
JasonBarhorst is offline
post #3 of 3 (permalink) Old 09-09-2006, 02:19 PM
Uh I think you have to love these new computor controled vehicles.
Best my pea brain can remember you have to take it to the dealer for some kind of special bleeding proceedure to get the abs and proportioning vales set back to there preferd settings.
I say this because the Grand Cherokee"s were like this.
Alot did there own brake work like you did then had them towed in to get bled.
amunderdog is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
