Cummins L10 problems.... - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Old 10-28-2008, 11:26 AM   #1 (permalink)
Have a 93 L10 - 300 (non celect) upon startup it smokes and runs rough, once warm it smooths out and no smoke exept on load. Strangly when i use the block heater it does not smoke for the first 5 mins of start up but then starts to run rough again and smoke until warm....???
could the thermostat cause this? Hoping its not major like a leaky head gasket, or injectors, though the engine consumes no oil or coolant, and there is no evidence of water in the oil....
any help would be great
LKCONCRETE is offline
Old 10-29-2008, 11:23 PM   #2 (permalink)
We have a tractor on our farm with a '92 non-electric L10 as well. We had similar problems that turned out to be a problem with the fuel pump. We did fuel pump and injectors at the same time and that helped it out a lot. Might be due to have the injectors gone through. I don't think that the thermostat would have anything to do with the symptoms you describe either. Ours probably had about 4000-4500 hours on it at the time. Definately hard hours though.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters.
sdan27 is offline
Old 10-31-2008, 09:04 PM   #3 (permalink)
More than likely an injector(s) problem. You'd have white smoke pretty much all the time if the thermostat was stuck.
'04 Excursion EB, 6.0 PS, 4X4, Magnaflow Performance exhaust, Isspro gauges (boost, pyro and tranny), Bilsteins, aFe intake, front and rear leaf spring upgrade w/ bags, 30mm rear sway bar, SCT Xcal2, Red-Head box, Jordan brake controller, Arctic Fox 29V - 20,420# GCW, Everything haulin' me, the wife, the 5 Amigos, Millie and Yogi (our 2 Berners).
Stewey is offline
