Detroit Diesel 8v92 - Diesel Forum - TheDieselStop.com
post #1 of 26 (permalink) Old 05-04-2005, 01:06 PM Thread Starter
Detroit Diesel 8v92
Hey guys,
I dont normally post in this forum, but My father and I have an offer in on a Hatteras with a pair of 8V92 Detroit Diesels. They are 1982 model and I am not to familiar with them. We are having an engine survey preformed on the motors and they will use an endoscope on the cylinders. I am really just looking for some opinions on these since I dont have knoledge of them like I do with the powerstroke. Thanks.
Pat
2003 F-350 Lariat 6.0 CC LB SRW, FX4 3.73, 4" Lift, 315/75/16 Toyo Tires, Mickey Tompson Rims, Custom Intake, Amsoil, Polytuff Liner, HID Headlights. 140K miles.
SOLD*** 1997 F350 XLT CC LB SRW,4x4, 4.10, Custom 4" Exhaust, Baby Swamps, Late Model HPOP, DPP Downpipe, IH Waterpump W/Filter Boss, 315/75/16 BFG A/T, E4OD Rebuilt for a 2nd time, AC Mod, TYMAR Intake and HX mod, Guage Pod With Auto Meter Ultra-Lite Guages, AMSOIL front to back, 2 Tru-Cool Trany oil coolers,$12 AIC, Line-X, Diamond Cut Headlights and Altezas, Vent Shades, 325,000 miles.
"Eveyone should believe in something. I Believe I will go Fishing." -Henry David Thoreau
"Clothes make the Man, Naked people have little or no influence on society."
lancinfish is offline
post #2 of 26 (permalink) Old 05-04-2005, 01:53 PM
My Photos: (9)
Re: Detroit Diesel 8v92
Good motors for the time, they are powerful if a little smoky [img]/ubbthreads/images/graemlins/wink.gif[/img] They are fully rebuildable if the boat manufacturer built it so you could access them anyway...otherwise check to see if they can be removed without taking a chain saw to the deck. But that applies to all motors.
They were used extensively in fire trucks all the way into the 90s. They are not my favorite motor because they are a bit thirsty, noisy and they smoke too much but in a boat they are thought to be pretty well suited.
Birken
Birken Vogt is offline
post #3 of 26 (permalink) Old 05-04-2005, 02:08 PM
Not ot mention thay leak oil like they're bleeding. Oh sorry, thats any Detroit I've been around.
2006 Chevrolet 2500HD 4wd CC/SB
Duramax LBZ/Allison 6 speed
SCOOBY14B is offline
post #4 of 26 (permalink) Old 05-04-2005, 02:27 PM
if i rember right on 8V-92 TA verison on marine duty [boat engine] have few diffrent hp rating and your boat what you described i know it is capable to run 550 hp to 650 hp rating but iam not sure depending on what injector it have [ it will show on valve cover or you have to pull the cover off to see the number like N65 or N70 verison etc ] i know few 8V-92TA did ran high as 750 hp but the power is kinda limited for that duration so hard to me to say the correct answer for it.
Merci , Marc
french277 is offline
post #5 of 26 (permalink) Old 05-04-2005, 06:41 PM
My Photos: (9)
Hey Marc, it's great to see you back, we need to hear all we can from you Detroit old timers [img]/ubbthreads/images/graemlins/wink.gif[/img]
Birken
post #6 of 26 (permalink) Old 05-04-2005, 07:21 PM
Pretty fast engine for a 40 foot sport fisherman. 3406 Cat would be my preference, but the 8-92 is pretty good and rebuilds are more frequent than a Cat but a lot less expensive!
Too much junk/toys to mention, ever changing due to too getting bored too quickly. I need a 10 step program!
Want to call? I'm in the book. Want to argue....First explain the square root of negative one....lol
roofeditor is offline
post #7 of 26 (permalink) Old 05-04-2005, 09:43 PM
The series 92 is a wet liner, capable of 655 hp stock. Yes it can be pumped up. It is listed with 9225 injectors. All 92 injectors will begine with 92xx. 9280 is the smallest I've seen but there is a gen set here in town with 9260 and pushes 780 hp. The 9280 is an 80mm injector, the 9225 is a 125mm injector. You figure out the last one. Most marine engines are intercooled as well. They are quick to get there as they are a 2 cycle engine compared to a clakerpiller which is a 4 cycle. Best is to get it up to plane and back off th where it will cruise. No need to waste fuel on un-needed rpm's. Oh ya, mash that puppy to 2500 and watch the birds being past by. They can drink fuel but like I said back off and let them cruise. Excessive smoke is just unburned fuel.
95 F250,XLT, 4WD, Auto Trans,bbshimmed,synthetic trans oil,4:10 gears ,Truck Trunk ,Nerf Bars ,crome Mud flaps, Aux. trans cooler, front diff. drain plug. External trans.filter, trimmed snorkel. American wheels water temp guage, front fuel tank mod,Warn Manual hubs,Putman class 4 hitch 212k mi.
Currently also have 2012 Dodge 4X4 with a Cummins engine.
It is said if you sit by the river and watch the water flow by long enough, your enemies will pass by. This I believe to be true. It is also possible to watch your loved ones pass by as well.
Wife Candi 08/14/07 missing her always
Gone Fishen is offline
post #8 of 26 (permalink) Old 05-04-2005, 10:50 PM Thread Starter
These motors are the 650hp models. They have been overhauled before and have 650 hours on them. Anyone have any idea what it would cost to do an overhaul on one?
post #9 of 26 (permalink) Old 05-04-2005, 11:21 PM
lww
So Hank, you're much more an authority here, did marine engines have any if all the short comings of the highway 92's. Specifically the bottom end troubles, and block fractures that seemed to plague those "Double O" with flames on the exhaust manifold versions? [img]/ubbthreads/images/graemlins/bleh.gif[/img]
If I remember correctly that was right around the early 80's when Alpine green turned briefly to black (or red in Cornbinders), only to be followed by silver at which point many operators had gone broke by reason of down time already [img]/ubbthreads/images/graemlins/shrug.gif[/img] (maybe it wasn't that bad in other areas, but up here in BC and our mountain roads, things got pretty bad.
Lorne
1990 F250 with 325oookm - ATS (non wasteGated kit ) on since 0km's / ZF / Single Cab Conversion to 6 seater keeps the family involved / Getting on, but running strong
lww is offline
post #10 of 26 (permalink) Old 05-05-2005, 01:07 AM
There were several modifications done at the time of the 'silver thing'. Keep in mind however that truck engines are completly different breed even though they are the same engine. Lets take a boat or even a gen set. Start it up [gen set] and a set rpm/load is achieved NOW. A boat is simular however it is mounted differrent and it's load/power is the same also. Yes the movement around the dock area is a little load but still when you ar running a constant load is achieved.
Truck drivers/industrial equipment is different. Load now/ idle a while/run like heck for 6 to 12 hours at different loads and vibration ect. Up the hill, down the hill. uneven loads cold weather useage, overheat in some dumb desert ect. Gen sets and boats have a longer life. There are 2 gen sets out of town with 6V-92 with 28000 hours on them. 1 inframe each. Yes 28 thousand.
Yes if I owned one and had 1 or 2 in a boat. for a truck, every 200k for mains and rods. There is a hour for boat but I don't know what it is. There are not to many here and I really try to stay away from boats. Busses are bad enough nowdays. [img]/ubbthreads/images/graemlins/bleh.gif[/img]
The 92 series broke a lot of truck outfits and DDA had a bad name for a long while. I was 1 of 2 people who linebored blocks. The 2 of us got quite good at it. We even did some tricks that the boss never did find out about. It was bad all over.I heard that if you had a DDA engine there were outfits who did not give a load to you. There were people who would take an old new engine and paint it and sell it as a 'silver block engine'. Anyone with access to DDA could tell you if it was a real silver engine. We would answer questions all the time on the serial #'s. However the series 60 changed all that. If you have read my bio it says I work for a DDA distributor and I still do. I have been doing this for a few years and some say I still have green blood. Don't know about that, looks red to me sometimes.
post #11 of 26 (permalink) Old 05-05-2005, 02:13 PM Thread Starter
Gone Fishen, I know that every situation is different, but what could be the expected payout to do an overhaul on one of these motors? I want to be prepared. Plus, what does detroit think about extended life coolants? Should they be run in a boat?
Pat
post #12 of 26 (permalink) Old 05-05-2005, 09:19 PM
i usually don't see repair quotes so I will have to ask tomorrow maybe even call the boat branch in Florida to give me an idea. Greyhound runs ELC in their busses and they still have a few 2 cycles.
post #13 of 26 (permalink) Old 05-07-2005, 02:04 PM
the 8v92s up at school use 9290 injectors. Yesterday I had to adjust valves and the rack and governor. What a long process!! They say we will never see any 2-strokes anymore, but im really glad I am learning this!
Thanks,
Jeff
2015 Ford F-350 XLT CC, Fx4, Diesel, SRW, 3.31 gears, stock and 53k miles
1996 F-250 Powerstoke Diesel XLT,
open element air filter, H2E turbo, Custom Tranny, 6.0 Charge air cooler, Swamp 175/173 squirts, TW Chip and some other neat stuff.
DieselWiezil is offline
post #14 of 26 (permalink) Old 05-08-2005, 04:57 PM Thread Starter
Gone Fishen,
Any luck with an Idea of Cost for a major?
Pat
post #15 of 26 (permalink) Old 05-08-2005, 10:49 PM
lol well thats the down side, but i figure it isnt any more than a 4 year university. Well for a degree you have to take a core class includes 6 months and then you take 1 elective course. Each elective course you take is 3 months long. If you take a core class + ASM (business management) you will recieve 2 degrees.just 9 months is close to 22 grand. Wyotech is the ONLY tech school that you will be able to recieve DEGREES. Any more questions just hollar at me.
Thanks,
Jeff
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
