General DieselDiscussion about diesels in general. All brands are welcome, please refrain from brand wars. Discussions about types of diesel fuel also go here.
Very interesting post.
Sort of puts the damper on the ideas pf a conversion needing a 3.9 Cummins.
I watched the video several times. Did not hear what HP rating was on this Ford tractor. Looks around 60hp???
Anyone have any ideas about the engine ratings of these THREE conversions?
thanks again...great post...bill
NRA member...GUN(s) Owner...Bluegrass performer and festival promoter. Now have an International 9400 Eagle, Cummins N14, 10 speed, 72" mid-rise sleeper. Pulling a 45' Teton 4 axle, triple slide. http://www.youtube.com/watch?v=GqI14CfACjU (I'm the guy singing lead, w/beard)
"http://www.traditionalbluegrass.us"
------------A stock 4600 3 CYL 201 CID is 52 HP,turbo would be around 65 HP @ 1900 RPM,that's PTO 540 speed,top RPM is 2300,We had 3 Ford diesel's when we farmed,4600,3 CYL,6700,4 CYL & a TW 10, 6 CYL @ 401 CID,they all had the same bore & stroke, they just added CYL's, the largest tractor Ford made in house was the TW 30 6 CYL turbo/intercooled @ 165 HP, ,they bought a 4 wheel drive articulated with a Cummin's 855 CID and called it the Ford FW series, tractor's of that vintage,1975-1990, were rock solid,with good care you could see 14,000-15,000 HR'S before overhaul,then you have the guy's who only get 3,000-4,000 HR's on one one the tractor look's like it's been through WW2 ,no Idea on size in the perken's 4 CYL,no information on what's it's out of to base it off of,all I can say was it seemed to push that F150 right along & the 40 plus MPG would be great for someone running lot's of mile's to work.
2002 F350 4 door Dually XLT lariat PSD Crew Cab 4R100 4.10 VDH4 Prepump, In-Tank, Crossover,Tymar air intake, Edge Evolution, Magellan 6000T GPS, White Night backup light's, DPPI Guages, Walker "Big Truck" Muffler, b&w turn over hitch, pulling a 2004 Sunnybrook 31bwks triple slide 5th wheel. , Total Gross 20900#.truck wt empty 7420# all at the scale, born 05/02/02. bought 06/18/02 & the wife's 2007 eddie bower expedtion 5.4,6 speed automatic ,power everything,redfire & tan.
The only thing I would worry about this kind of conversion, is the emissions. If you are in an area that does NOT get tested, go for it. But since the engines are NOT rated for on-road use.... the EPA might fine people.
Those are not small bore engines. 201CID. A 4600 family engine can be rated 55 HP at the PTO, so the engine is about 60-65HP. I've got a Ford 3000 diesel that I removed when I put a 4630 engine in my Ford powered grape harvester. I think it idles fairly smooth, but that's w/ a heavy cast body and no springs. Might 'wiggle' a bit more if inside a truck w/ a suspension.
1999 E-350 Cub Wagon, 7.3L Power Stroke, E4OD, 3.55
1990 E-350 Club Wagon, 7.3L IDI, E4OD, 3.54LS
1983 F-150 2x4, 4.9L, C-6 w/GV-OD, 3.55 Farm pickup
1981 C-8000, 3208 CAT, RT-6510, Rockwell SSHD Tandems (Swap)
1977 K100C, NTC-350, RT-1110, Tandem
1977 Transtar II, NTC-290, RT-9509 Single
1977 Transtar II, Formula 290, RT0-9513, Tandem
1974 C-750, 391CID, Clark 5 speed, Eaton 2 speed
