Diesel Smog Check in California - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Old 11-20-2009, 01:19 PM   #1 (permalink)
So I just received an ET Blast on my smog machine....... we will be testing beginning Jan 1, 2010 all 1998 and newer diesel pwered vehicles with a Gross Vehicle Weight Rating (GVWR) up to and including 14,000 pounds will be subject to biennial and change of ownership inspections.
I feel sorry for all of you guys that have mods on your trucks, all I can say is good luck to you guys i'll try to help you guys thru the process as much as I can.
MHS911 is offline
Old 11-22-2009, 10:51 AM   #2 (permalink)
This is just going to be a visual inspection from what I've heard. The way inspections work, with gassers, is that they do a OBD test first then do the visual inspection. Meaning, you could very well have your vehicle within spec, but fail the visual inspection because of mods like deletes of sorts or something even more simple like intakes.
2008 F250 PSD XLT Super Cab Long Bed (4x2)
2006 Nissan Titan, 6 inch Procomp lift (4x2)
2000 Nissan Frontier, Custom Motorsports 8 inch lift (4x2)
timid1 is offline
Old 11-22-2009, 02:31 PM   #3 (permalink)
CHILLLS's Avatar
from what i understand the AFE stage 2 has a carb cert.
for those who are running it
02 7.3l psd 6 spd 4x4 cc lb srw
cut muffler
afe stage 2 pro guard 7
wicked wheel
superchips programmer
BD x-monitor
aic
pro comp 6.5 lift
35x13.5x18 mtz
kmc wheels
pro comp track bars
viair 480c compressor
5 gal. tank running 200psi
train horns
firestone bags
piaa supper white head lights
70 gallon in bed tank
warn semi hidden winch mount
warn 12,000 winch
piaa 4" smr fog lights
thats it for now but more to come
CHILLLS is offline
Old 11-23-2009, 11:34 AM   #4 (permalink)
Actually
Actually there will be 3 parts to the exam. The first will be visual meaning exactly what we do in a regular smog check for EGR O2 ......etc no mods, if yu do have mods they have to have eo numbers from CARB.
Second will be a OBDII test done on the vehicle which checks for any type of codes you may have in the computer memory whether it be soft codes or hard codes. Now if you do have codes and but the light is off and the readiness monitors are set ( set meaning at least 2 max can not be ready ) you will pass the OBDII test. If you have no codes ( because you just reset the light before coming to a smog station ) then you will fail due to the readiness monitors not being set and obviously if you have not codes and monitors are set you will pass pass pass all day on that section of the smog test.
Now third is the trick part. We will be doing a snap throttle test on the vehicles. It consists of 3 snaps of the throttle each about 2-3 second apart from 2500 rpms to 3000 rpms little less little more... We will be checking to make sure no black smut.... and i repeat no black smoke or smut coming from the tail pipe I am not talking about condensation which comes out and disipates I am talking about black smoke that lingers in the air for a while and does not disipate. I do know that if you have a after market computer upgrade make sure its setting are low or at least back to stock before brings it in.
Any q's let me know hope this info has been helpful.
CHEERS
MHS911 is offline
Old 11-27-2009, 06:12 PM   #5 (permalink)
Don't feel bad. All "heavy duty" diesel vehicles (Class 4 and up) pre 2007 are being required to put on diesel particulate traps if they even DRIVE THROUGH Calif., even if registered in another state. Motorhomes serendipitously excepted.
So a bunch of Unimog guys I am acquainted with are frantically looking for Alaskan campers etc.
California keeps going on its' merry insane way....
Charlie
diesel Landcruiser & M37; 05 Unimog U500 w/Unicat camper
Charlie is offline
Old 11-27-2009, 07:27 PM   #6 (permalink)
OT
OT's Avatar
MHS..just curious cause Nv. test diff. except for 1. visual. So..if you pass on 1. visual (req'd emission parts) & 2. OBD, but fail 3. visual smoke, then what happens?
btw...here..t.p. sniffer figures out level of particulants being emitted = pass/fail. I dont know how one argues with a machine, but with a person that's diff. Anyhow, update in Jan if you can. TIA.
03 F250 XLT SC/SB 4X4 6L (stock) A/T. SRW 3.73's BD:02/11/03. 01 TL 23' SGII
OT is offline
Old 12-15-2009, 02:30 PM   #7 (permalink)
Tia
Hey sorry for the long delay. Well if you do fail the visual smoke parts you are going to have to find why it is smoking and fix the problem. As far as I know we will not be sticking anything up tail pipes for a while just check for visual smoke.
Q's let me know
MHS911 is offline
Old 12-15-2009, 03:14 PM   #8 (permalink)
chuckster57's Avatar
Charlie
I thought I saw on the news this last week that the trucking industry "picketed" Sacramento and the EPA admitted the guy they used for testing was NOT QUALIFIED.. and now they are going to have to start all over again on the DPF stuff.
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is offline
Old 01-27-2010, 03:29 PM   #9 (permalink)
Apparently the new law's inforcement has been postponed. I didn't get anything in my renewal for Feb.
SOLD 97 F250 XCab SWB 5spd, 4.10, Built 10/97. South Bend Clutch, 3"DP, 4" AFE, GTS Intercooler kit, Tony's Tunes, Gauges.
°=ALT248
The day they take away the 2nd amendment is the start of the 2nd revolution.
LCOwner is offline
Old 01-30-2010, 12:53 AM   #10 (permalink)
I read on the BAR that air cleaners won't be checked for CARB EO exemption. Exhaust modifications as long as exhaust treatment remains in tact (e.g., urea injection, diesel particulate filter) are also not on the inspection hit list. Intake manifolds are. Programmers/chips are.
Cheggit out
http://www.bar.ca.gov/80_BARResource...%2012-2009.pdf
timid1 is offline
Old 01-30-2010, 02:05 AM   #11 (permalink)
Send a message via Yahoo to sportbiker929
How can they tell if you have a tuner?
05 Crew Cab, FX4, Lariat. 156K runnin strong, SCTX3 with Erics tunes, Bilstein 5100s, Bilstein front leveling springs, ARB Bull bar, 15K Smittybuilt winch, Pioneer 6 disc DVD changer/player, Rhino lined, Infinity Reference. US Navy retired.
sportbiker929 is offline
Old 01-31-2010, 12:37 AM   #12 (permalink)
It is all really up in the air right now for California. I also saw conflicting reports on the news saying things are going to be delayed.
QuoteWarz Insurance is offline
Old 01-31-2010, 05:49 AM   #13 (permalink)
magusjinx's Avatar
So much for my moving to California ... I am building a diesel trike ... Using an '86 6.9 IDI ...
magusjinx is offline
Old 01-31-2010, 11:25 AM   #14 (permalink)
Well your engine in the trike would be exempt from the smog laws (for now) I for one would love to see a diesel trike. When I say for now, I mean they (the goonies that think this crap up) just might make all of us retro fit with a dpf or something.
Old 02-03-2010, 04:59 AM   #15 (permalink)
magusjinx's Avatar
My hard part is keeping the db under 90 on't want anyone to hear me till I hit the train horns ... I may have to run 8 short pipes with Harley baffles in each one ...
