Diesel Smogging in California - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Old 10-06-2007, 11:28 PM   #1 (permalink)
Bacon104's Avatar
My Photos: (18)
With all the emissions requirements on the diesels now, is it a requirement to have them smogged or anything in California now? If so what years apply?
Truck:
Early 99 F-350 (99.5+Conversion)
Lariat Crew Cab Long Bed
05'-07' Front End/08' Tail Lights
184,000mi
Body:
8" Fabtech Lift
37" Toyo Open Country M/T
18" Rockstars
15" Cieling DVD
Engine:
99.5+ Conversion
AFE Stage 2 Intake
4" Turbo Back Exhaust
Ceramic Coated Bellowed Up-Pipes, Exhaust Manifolds, High Flow Turbo Outlet
ITP In-Tank/PRE-Pre-Pump Mod
HP Oil X-Over Line
AIH Delete
ISSPRO Boost, Pyrometer, Trans Temp A Pillar Gauges
CCV Mod
Truspeed
Other Rides:
67' Camaro RS/SS Dart Big M 540cu
Bacon104 is offline
Old 10-07-2007, 09:52 AM   #2 (permalink)
My Photos: (5)
Re: Diesel Smogging in California
Depends on where you live and what your local laws are. Here in Colorado I live in a county where diesel emmissions are required, but if I lived one county over I wouldn't have to bother with it. When you register your truck with the DMV, they will tell you real quick if you need an emmissions test or not. If testing is required, you can't renew your registration until you pass emmissions.
Pocket is offline
Old 10-07-2007, 12:15 PM   #3 (permalink)
I'm in the Bay Area and there is currently no diesel testing here. I don't know how long it will stay that way.
Joseph, San Francisco Bay Area
'06 F-350 CC, King Ranch, FX4, 6.0 PSD/TorqShift, Dually, 4.30 Gears, Tow Boss, Loaded, Ford Remote Start/Alarm, No Performance Mods
Proud to be a member:
The Calif. Rifle & Pistol Assoc. (Life Member)
The National Rifle Association
What part of "shall not be infringed" do you NOT understand?
joseph3724 is offline
Old 10-08-2007, 09:28 PM   #4 (permalink)
NP
My Photos: (10)
Currently the only requirement in CA for diesel emissions testing is an annual opacity test, and that is only required if you have a "fleet" of diesel powered vehicles. CARB says a "fleet" is 2 diesel vehicles with a GVWR of more than 6000 lbs.
So If you have one F250 (most are around 8800 gvwr) you are OK, but if you have 2 you need to be doing the tests.
The fellas that own the big trucks are now getting ticketed by CARB for not having the factory emissions labels on the engines.
CARB also has a draft proposal on the table to require retrofitting all diesel powered vehicles over 14000 or 14500 GVWR (I can't remember which number is correct) with the particulate traps.
__________________________________________________ ________________
2000 SD CC PSD 4X4 Lariat, 156 WB, Island Blue & Harvest Gold, AIC, Autometer Pyro, Isspro Boost gauge, Banks Monster Exhaust, AIS Filter Kit, Racor CCV3550, Stainless Steel grille, & Grover Organtone Air Horns. Ordered 11-23-99, Built 01-13-00, shipped 01-14-00, Delivered 2-2-00. Running board LED light project
2001 150 SuperCrew XLT 4x4, DESTROYED 10-24-2003.wrecked F150 SuperCrew 2004 F150 SuperCrew Lariat ordered 11-1-2003, delivered 2-19-04.
My Trucks & upgrades
NP is offline
Old 10-11-2007, 09:45 AM   #5 (permalink)
My Photos: (9)
You only have to "smog" your "fleet" if it is for business use or something along those lines. Just because you personally have two diesel F250s does not mean you have to go along with this but the way I read it, if you are a logger and have a pickup and a log truck then both of them get it.
Birken
Birken Vogt is offline
Old 10-11-2007, 09:13 PM   #6 (permalink)
NP
My Photos: (10)
<div class="ubbcode-block"><div class="ubbcode-header">Originally Posted By: Birken Vogt</div><div class="ubbcode-body">You only have to "smog" your "fleet" if it is for business use or something along those lines. Just because you personally have two diesel F250s does not mean you have to go along with this but the way I read it, if you are a logger and have a pickup and a log truck then both of them get it.
Birken </div></div>
You are correct, I should have clarified that a bit more
NP is offline
