DIY bypass oil filtration - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Old 03-01-2005, 05:20 PM   #1 (permalink)
I trying to put together a DIY bypass oil filtration system ( on Ford IDI 7.3) . I have a couple of remote filter heads that have a 3/4-16 threaded nipple . However , the filter of choice ( Baldwin B50 - 2 micron ) has a 5/8-18 thread . I am looking for an adapter nipple if readily available so I can use the base I have or otherise an low cost base that fits .
I plan to put a tee in line with the sending unit for my oil source to the filter and return back to the pan - Is this Ok ? - thanks
1994 F250 7.3 IDI E4OD
rkpatt is offline
Old 03-02-2005, 02:41 PM   #2 (permalink)
2x6 Bulldog's Avatar
Re: DIY bypass oil filtration
I'm no expert but that pressured oil is filtered and goes to the engine for lubrication of bearings and such. Do not dump back into pan. Take a look at installation instructions on commercial units.
There are in and out ports for bypass lube filters on a stock PSD.
2008 F450 DRW CC LWB 4x4 Off Road, Lariat, Oxford White, 4.30 LS rear end, Navigation, audiophile stereo, Memory package seats, heated seats, heated mirrors, warmup heat option, power back window, traction control system, backup alarm, rear DVD with wireless headphones.
2x6 Bulldog is offline
