DT466 has water in oil - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 06-26-2008, 04:16 PM Thread Starter
We recently overhauled this engine and during the overhaul replaced the oil cooler. The truck left for 500 miles and came back with oil in the water. We removed the oil cooler and had it pressure checked, checked Ok. Removed head and had pressure checked, checked OK. We made a block off plate for the top of the block and pressure checked the oil galleys withe 85PSi shop air and had no bubbles in the coolant galleys. We have had the local machine shop look at the old head gasket and they see no sign where there was cross contamination. Does anyone else have any thoughts?
lance_wright is offline
post #2 of 4 (permalink) Old 06-27-2008, 10:11 PM
timberjack's Avatar
My Photos: (17)
Which condition do you have? In the thread title, you say water in oil, but in the thread you say oil in water.
I have a dt466 that had both problems at different times. The oil in water ended up being the oil cooler. I also had mine tested, but it didn't show as leaking unless it was at operating temperature. The rad shop i had test it couldn't heat it to 190 degrees and pressurize it at the same time. I replaced it with a reman one and all was well.
Several years later i found water in the oil. Fortunately, i caught it very quickly, and had no trouble with bearings or other lube damage. In that case it happened to be the liner seals. The very bottom one(s) had basically rotted out, and was allowing coolant to leak into the crankcase while it was shut down. I replaced all the liner seals and back in business again.
If you've got water in the oil, it's possible one of the liner oring seals twisted, rolled, ripped, or something while you installed them. If you can pull the oil pan and pressurize the coolant system, don't use 85 psi, 10-15 should be lots, a leak from the bottom of the bad liner will be easy to spot. Obviously you'll need the cylinder head back on to do this, or your block off plate if you can seal the coolant ports.
Good luck
2007 F-250 XLT 4x4 Supercab PSD - Such a screaming deal I couldn't resist
1996 F250 XLT 4X4 Supercab PSD, Dana 60, Boss PowerV-XT 9'2" snow plow.
timberjack is offline
post #3 of 4 (permalink) Old 10-11-2012, 10:52 AM
Hey There ... When looking for the Liner O rings - Does anyone have a diagram where these are located? And the best view of them?
Thanks A Bunch!
CuttingEdge is offline
post #4 of 4 (permalink) Old 10-11-2012, 11:01 AM
chuckster57's Avatar
Welcome to the Diesel Stop
Thanks A Bunch!
Here's a link that should help you out:
~~~~~School Bus Mechanic: International DT466 Diesel Engine Rebuild Cylinder Liner Seals
Train Horns:
PM please not visitor message
chuckster57 is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
