DT466E and DT530E.......power upgrades???? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 04-04-2007, 09:43 PM Thread Starter
KentuckyDiesel's Avatar
My Photos: (63)
Are these engines on the same block??
What is the maximum RPM when the programming is changed?
How much power can you get out of these with a chip only?
How much power with a chip and injectors?
Thanks, Phillip
1995 F350 CC DRW XLT, Converted to 4x4 with D60 front, Alcoa Classics, Large syncro ZF5 tranny with fluid cooler and pump, SuperDuty electric fuel pump, Aeromotive fuel pressure regulator, Davco/Detroit Diesel fuel filter assembly with twin 10 micron Cummins OTR style filters, Stanadyne Fuel heater, Superduty VC harnesses, Tymar intake, Isspro EV Pyro and boost gauges, Autometer pod, Ford AIC, Techonsha Hydraulic brake control, TS 6position chip, JD coolant eye, 4" DP with 5" Auto-Jet muffler and exhaust out the back, SWAMPED.
1997 F350 CC XLT 4x4 Auto tranny. Hypermax gauges, chip, intercooler, DP, and 4" straight exhaust.
1984 F250 4x4-6.9 diesel with a Western plow...Bone stock-about to be restored.
KentuckyDiesel is offline
post #2 of 8 (permalink) Old 04-05-2007, 02:09 AM
My Photos: (33)
Re: DT466E and DT530E.......power upgrades????
TS makes a box for the E motors and DP tuner will custom burn you a program also.
00'F350 psd CC Drw 2wd Bright Amber Western Hauler, exhaust brake transfer flow 50 gal tank tool, 30K Cody goose neck hitch, hawk pads, cryo'ed rotors, stainless lines, 380,000 miles
02' Psd Excursion Limited ultimate Estate Green 7.3L Auto 2x4 hellwig swaybars and rancho 9000's. 381,000 miles.
1993 F-superduty (F-450) 7.3L Gutless non turbo 2x4 Auto, Tire eating S.O.B. 12,750lbs 80,000miles lincoln Vantage 500 Duetz bolted in the back.
1994 7.3 I.D.I.T. factory turbo, auto 2x4 DRW with lots of upgrades, 11 transmissions under 100K factory warranty. 280,000 miles Currently Cavitated and parked.
96 F-800 24'flat 5.9L cummins, 4spd allison juice brakes.
89 F-800 6.6L 5+2 27,00lbs light weight with National 556A crane behind the cab.
2006 T800 KW 550 C-15 18spd 22K front, 52K rears murray ramps, 195" W.B. CA spec heavy haul SOLD
2006 Murray 16 tire professional lowbed SOLD
1996 fetherlite 4 horse GN, Walton 18' 14K tag tilt equipment trailer.
Dualie is offline
post #3 of 8 (permalink) Old 04-05-2007, 09:25 AM
Poster is correct TS has a D-466 tuner/box but I'd stop at 300 HP for a DT-466. The 530 and now 570 have other upgrades to deal with additional torque and heat. We own many DT-466's and if not abused they will go 500K no problem. If you are driving your 466 with light loads I suppose going over 300HP would work but for constant pulling very heavy loads there is a lot of heat building.
Think this way the new 6.4 Ford and the 350 L-11 Cummins technically make the same power. Think the Ford 6.4 will pull the heavy constant loads a L-11 Cummins 350 will for very long? NOT!
Too much junk/toys to mention, ever changing due to too getting bored too quickly. I need a 10 step program!
Want to call? I'm in the book. Want to argue....First explain the square root of negative one....lol
roofeditor is offline
post #4 of 8 (permalink) Old 04-05-2007, 08:38 PM Thread Starter
My Photos: (63)
My powerstroke is making about 300hp to the rear wheels and is doing great at 300,000mi. The 466 won't do more?
Is the 530 a better engine then? What is the difference? I don't know anything about the 570.
Thanks, Phillip
post #5 of 8 (permalink) Old 04-05-2007, 10:04 PM
My Photos: (33)
Your power stroke is in a 8,000 Lb. pickup. The DT will be in a 15,000Lb. MDT. not to mention the almost double frontal area.
The MDT will have to work much harder to get to and maintain highway speeds. if you have ever driven an MDT you will know what I'm talking about.
How much do you have your PSD floored to get to and keep moving? In a MDT it can often be over 75% of the time spent driving. its not making the HP its keeping the motor together while using it.
Dualie is offline
post #6 of 8 (permalink) Old 04-05-2007, 10:43 PM Thread Starter
My Photos: (63)
I drive one of three International 4700s that my employer owns everyday. They aren't very heavy at all.
I believe a 4700 cab/chassis only weighs something like 11-12,000lbs. My F350 weighs about 9000lbs and runs like a greased rocket.
The 466 is a dog of an engine. 210hp or so in the trucks at work.
When I have my horse trailer on my pickup, it has every bit of the frontal area of one of the 4700s and weighs more but I can hold whatever interstate speed I think I can get by with.
The 466 is a DOG. [img]/ubbthreads/images/graemlins/vomit.gif[/img]
-Phillip
post #7 of 8 (permalink) Old 04-06-2007, 08:22 AM
-Phillip
The 466 in 220 form is a good long lasting engine. In 300 form it gets up and goes very well for what it is. The DT can be tuned up to 500 HP but you won't have a 500K mile engine any more. The DT in 300 HP form has quite a bit of torque and will pull any LEGAL load you can put on it.
post #8 of 8 (permalink) Old 04-06-2007, 04:50 PM
weasel79's Avatar
-Phillip
I drive a 06 4400 DT466 that is 260hp. The truck weighs around 18-20k. It does pretty good for power. Has pretty good lag off the line. I would rather it be around 300hp. The mileage is terrible at 5-7mpg. Now the mileage is great that its been in the shop for 6 weeks. [img]/ubbthreads/images/graemlins/eek.gif[/img]
Overall it can use more pep.
2003 F-250SD XLT X-Cab short box March 03 6.0L Torque shift, manual 4x4 superwinch hubs, 121,000 miles,315/75/16 BF Goodrich mud terrains, autometer boost/fuel psi/tranny temp, AFE 4" straight pipe,
weasel79 is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
