dt466e just shuts off - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 09-28-2005, 08:54 PM Thread Starter
I HAVE A 1996 DT466E AND NOW AND THEN WHILE IDELING IT JUST SHUTS DOWN AND WONT START. IT WILL RUN ON ETHER AND THE FILTERS ARE FULL AND AFTER A WHILE OF RUNNING ON ETHER IT WILL TAKE OFF AGAIN. CAN ANYONE HELP ME?
81251 is offline
post #2 of 2 (permalink) Old 09-29-2005, 12:14 AM
fourhatz's Avatar
Re: dt466e just shuts off
Push in the diagnostic button on the console and read the blink codes to see if you have any fault codes. It sounds to me that you may have a fuel pressure problem or an high oil pressure system problem. If you have a 335 or 333 code and you have base engine oil pressure than the high pressure system is the culprit.
96' F-250 4x4 SB Crewcab, 3.55 gears, rebuilt E4od, Air bags, 2" leveler kit, 10 disc cd changer, Tymar intake, Tymar 4 pos TS chip, 4590 cooler, boost, pyro(pre-turbo) & tranny temp AutoMeter gauges mounted in pillar, Diamond eye 4" exhaust with lost kitty, Tymar 3x4" downpipe, Warn hubs, Prodigy brake controller, Hypermax intercooler, CCV mod,17* HPOP, stage 1 injectors, fpr. Rebuilt tranny with pump and valve body mods, 3 disc torque convertor. Diesel mechanic 20+ years
fourhatz is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
