E4OD same as 4R100....? - Diesel Forum - TheDieselStop.com
post #1 of 22 (permalink) Old 11-24-2007, 05:09 PM Thread Starter
Now, I'm going to say up front that this is pretty much a stupid question. Really stupid....but, I feel the need to ask just because I'm curious...
I know with out a doubt that the 4R100 isn't the exact same as the E4OD but, when I was talking to the guy from Destroked about my interests in a Cummins conversion, he told me that the flexplate for the 4R100 is the same for the E40D. So what exactly is the difference in the two? And if the flexplate is the same, could I bold a 4R100 up to my '96? (Would it even be worth it?)
-clay
'96 F250 ExCab 4x4, 4" exhaust,Shimmed FPR, Tymar intake, 4" lift, front end replacment, soon to have a rear end and a headache rack, 315/75R16 BFG All Terrain KO's, Optima Red Tops...
clayc_989 is offline
post #2 of 22 (permalink) Old 11-24-2007, 08:41 PM
Re: E4OD same as 4R100....?
Yes they are the same. The name change was to conform to ISO standards, the same thing was done with the other Ford transmissions, GM too. I.e. AOD-E became 4R70W.
Ford made the name change at the same time they made some design changes, which will lead some folks to argue till they are blue in the face that the names indicate different transmissions. However there were changes made all through production from 1989 to present. Ford just used a convenient cutoff.
Now there is no reason to "swap" your E4OD for a newer transmission, with a new name, just to do it. However if you needed to replace a failed unit, it can be done provided all the electronics match up (there were changes in the solenoid packs and TCC over the years).
1997 Ford F350 SRW 7.3L PSD
1985 Ford Ranger 2.3L 5 speed
1966 Mustang 200 I6, auto, 4 wheel disk, power brake retrofit, Corvette master.
Former vehicles, 1994 E350 7.3L IDI, 1985 International 1654 rollback, 6.9L IDI, (2) 1994 Ford E350 7.3L IDI, 1985 Ford F350 DRW 6.9L IDI, 1985 Ford F350 wrecker 6.9L IDI.
*dual ASE Master Certified, Automotive, Medium & Heavy trucks*
Owner / operator, Patriot Automotive, N Ridgeville OH
Mr_Roboto is offline
post #3 of 22 (permalink) Old 11-25-2007, 03:01 AM Thread Starter
That's pretty interesting...I always thought that they were completely different.
post #4 of 22 (permalink) Old 11-25-2007, 07:11 PM
Very similar trannies. The 4r100 is basically an upgraded e40d. They can be made to fit in a e40d application. Just need to change a few things around to allow for the electronics, shift linkage, and the converter lockup.
I should have my 4r100 in my 95 by the end of this week.
1995 F250 4x4 with 4r100; SuperDuty Axles w/Sky RSK and Billstein's: Thanks to CaryT!
yellow_jacket is offline
post #5 of 22 (permalink) Old 11-25-2007, 07:30 PM Thread Starter
Is it that much stronger, or did you just happen to come across one?
post #6 of 22 (permalink) Old 11-25-2007, 07:37 PM
Mark Kovalsky's Avatar
My Photos: (6)
The 4R100 is quite a bit stronger. The 4R100 came out with the '99 trucks and was beefed up because of the increase in torque over the '97 engines.
Mark
Former
Automatic Transmission Engineer 1988-2007
Mark Kovalsky is offline
post #7 of 22 (permalink) Old 11-25-2007, 08:45 PM
No questions the PSD's put out more torque than the engineers ever dreamed of when they designed the trans for 1989.
post #8 of 22 (permalink) Old 11-26-2007, 12:37 AM
"The 4R100 is quite a bit stronger. The 4R100 came out with the '99 trucks and was beefed up because of the increase in torque over the '97 engines. "
That's good to know! If I come across a new one cheap,
I might go that route. Or, at least buy it and keep it
around for later.
1997 F250 HD PSD 4x4 OR Auto 3.55LS CC SRW SWB 265x75x16 Michelin LTX DP 211K mi.; Ford AIC; Fuel milege; 20.3 mpg @ 70 mph. 12.5 mpg pulling my boat,12.5K, along two lane rural roads. A number of mods ordered from DaleI. Nice round replacement DP. FS2500 by-pass oil filter installed. Fumoto drain valve. Tymar Intake installed! HX mod from Tymar installed. TFI fillneck kits installed. Auto-Rx cleaner in engine & transmission done. Switched from Rotella dino to Rotella synthetic. Amsoil 5W-30 Series 3000 installed!
FS-2500 Bypass filter installed. CD Changer
Velvet rides installed. Joe Servo IDM mod was installed. Replaced with Swamps HV/HF IDM! Rear air lift springs. 4" exhaust installed all the back from DP and bye bye Kitty.
Sparkydm is offline
post #9 of 22 (permalink) Old 11-26-2007, 01:26 PM Thread Starter
I'm wondering if the 4R100 would hold up to more powerful injectors? I'm not sure in the difference in power ratings of the '94-'97 7.3's and the new ones is but, I would hope that the 4R100 would hold up to a good amount of power. Then again, I'm not sure when they stopped using it...I'm guessing before they adopted the 6.0?
post #10 of 22 (permalink) Old 11-26-2007, 01:36 PM
My Photos: (6)
When the 6.0L came out it had the TorqShift transmission. The gas engines stayed with the 4R100 for another year or so. The last 4R100 was built in 2004.
Mark
Former
post #11 of 22 (permalink) Old 11-26-2007, 04:55 PM
I haven't looked for a while but, a few years ago I could get
a new 4R100 for $1700. I haven't checked back lately but, do
these hold up to mild power improvements like say 350 hp in
an OBS truck? I'm not in a position to buy a BTS at this point.
Sparkydm is offline
post #12 of 22 (permalink) Old 11-26-2007, 07:42 PM
New? Ford remans are 2 grand maybe a little more.
I know the reman I got for a 94 was in a newer case, as it had a plugged hole in the bellhousing for a sensor. I would guess that the remans are all the same except for the solenoid pack and converter to match the year.
post #13 of 22 (permalink) Old 11-28-2007, 12:17 AM Thread Starter
Sparky, that's what I was wondering but, I'm pretty sure that the 99+ 7.3's didn't make that much more horsepower...and the 4R100 being an E4OD with slight improvements would lead me to believe that they cannot withstand that much HP. However, I'm thinking that maybe since they are 'improved' maybe there's a way to help them withstand a pretty hefty power increase without going the BTS route...
post #14 of 22 (permalink) Old 11-28-2007, 09:35 AM
spg
A shift kit in a good stock transmission will make a BIG difference in its life and shifting capabilities.
2001 International 4700LP T444E 210HP Fuller Six Speed 4.10
spg is offline
post #15 of 22 (permalink) Old 11-28-2007, 09:37 AM
"A shift kit in a good stock transmission will make a BIG difference in its life and shifting capabilities. "
This might be a way to go. Many on here have mentioned
shift kits before. I had almost forgot about it. Didn't
realize they made that much of a difference in durability
though.
Sparkydm is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
