EMP Proof Diesel?? - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 08-29-2012, 03:01 AM Thread Starter
EMP Proof Diesel??
I'm looking to buying an older 70s or 80s, or possibly a 90's stick shift truck. Im not too familiar with what year certain makes diesel trucks were carburated and something about a points type distributor aswell. I am looking for the most basic manual shift diesel trcuk that has no electronics or very little electronics as possble. I believe early to mid 1980s fords and 1989-1997 dodge cummins diesels fits the criteria. Any knowledgeable feedback and what years, makes and models fit this criteira, thanks
Buying_a_Diesel is offline
post #2 of 6 (permalink) Old 09-14-2012, 02:18 PM
lone_star_dsl's Avatar
Ok, I'll bite.
First off, diesel engines have never been carbureted. All diesels have their fuel injected directly into the cylinder.
Secondly, diesels are compression ignition engines meaning the heat developed during the compression stroke ignites the fuel. They don't have spark plugs like gasoline engines do.
I'm not sure about other brands but any 1993 or older Ford diesel will not have electronics.
2016 RAM 3500 Big Horn, CC LB, DRW, 6.7 CTD, 4wd, Aisin trans
Gone but not forgotten...
2002 F-350 SRW
Lariat, Crew Cab, Long Bed
4X4, Auto Trans, Tymar Intake
Wicked Wheel, Zoodad Mod
DP Tuner - 60E, 80E, 40T, 80T, Decel
05+ Harley Headlights
6" Upper and Lower Windshield Brows
ISSPRO Gauges, Edge Insight CTS
Sold at 206,000 miles
lone_star_dsl is offline
post #3 of 6 (permalink) Old 09-14-2012, 07:06 PM
chevys to 1993,6.2-6.5 mechanical pump/fords to mid-year 1994,6.9,7.3,7.3t mechanical pump
trukdoc is offline
post #4 of 6 (permalink) Old 09-25-2012, 07:33 PM
You are going to want something that is not controlled by any thing like something with a exit 100 on i 40mechanical pump or if you are going with a gasser than it will need a carb points and mechanical fuel pump on it weather its a diesel or gas for the ford with the diesels with will be 1994.5 and below as for the gassers I dont know the year
1988 ford f250 2wd sadly in the works on making it a 4X4 5 speed 7.3 IDI 17 to 18 MPG average
oldschool2 is offline
post #5 of 6 (permalink) Old 09-25-2012, 08:55 PM
rammertide07's Avatar
Send a message via MSN to rammertide07
Lead paint?
Sent from my DROID RAZR using AutoGuide.com App
2001 F350 7.3 4x4 CC SRW/ Aeroforce Interceptor/ BD Thruster II/ Bellowed Up-Pipes/ 4" turbo back straight exhaust / CCV Mod /DIY 6637/ TS chip reburned with PHP tunes/160/stock FFD/PowerSlot rotors and green EBC pads/
/MM Hubs/Hood/HPx/FRx/
rammertide07 is offline
post #6 of 6 (permalink) Old 10-11-2012, 04:37 PM
Get a gen 1 cummins that's 89-93? Get the 5 SPd you'll want to go ahead and doable the fuel shut off solenoid and install a cable to the Manuel shut off lever also you might know a little bout a gasoline motor but use google and read up on the basics for diesel its almost apples to oranges
1990 f250 4x4 e4od 7.3l idi
Turbo ip turned down tq screw
315/75r16
3in lift
K&n air filter and home made ram air
5in stack straight pipes
165,xxx mi (I think/hope)
Large tranny cooler
16-18mpg
Soon to be turbo'd with nice cold air and wraped exhauste be for turbo
Rustyshackleford is offline
  Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
