Fixed #4 HP Line Failure, Now recv P0148 that can’t be cleared & I can’t id the cause - Diesel Forum - TheDieselStop.com
Go Back   Diesel Forum - TheDieselStop.com > Other Topics > General Diesel
Old 03-17-2009, 03:30 PM   #1 (permalink)
This is my first time posting to this forum, as I could use some help.
I believe I have done my do diligence searching and reading other posts before electing to post my own; however nothing I have found seems to fit the specifics of my issue. I hope someone out there will have an aha moment that can help me keep from throwing money at this issue, that I simply do not have. (Office closing at the end of this month. )
I have a 2004.5 Dodge 2500 4x4 Cummins that recently had the #4 High Pressure line fail, witch pumping a ton of diesel (i.e. More that I would have ever wanted) on the drivers side Engine Compartment and all down the drivers side of the truck, before dieing when I let off the throttle.
I replaced the #4 High Pressure Line, but the truck initially did not start.
After discovering that the system was suppose to be “Self Priming” I started doubting the functionality of my Lift Pump and proceeded to remove the top cover on the fuel separator cylinder, so I could visually check to see if fuel was being pumped when the key was turned on. After draining fuel using the drain valve, it appeared evident that the pump must be working as fuel was being pumped into the cylinder, so I put the cover back on and did more research.
I found a Priming Sequence, which required me to cycle the key to the on position for 25 seconds and repeat a couple times, then try to start the truck.
After a couple attempts including one time of cranking the key for about 15 seconds, the truck started and idled normally.
Unfortunately I now discovered that the Check Engine Light was on and proceeded to turn the truck off and check the codes. (It was throwing a P0148 “Fuel Delivery Error”.)
I did some research on this code and found a multitude of possibilities; however most of them dictated a trial and error approach replacing parts along the way.
Several posts indicated that the Lift Pump and/or a clogged fuel filter could cause the problem, so I pulled the cap back off the separator and discovered that the Fuel Filter defiantly should be replaced. It looked dark black in color with a sludgy appearance on the outside of the filter. (Please don't grill me on this one, as I will pay closer attention to this in the future and remember that the truck was running fine prior to the line letting go…) I replace the filter and the O-Ring on the separator cap and start the truck again. I read and cleared the codes, but “No Luck” as the code simply would not go away...
I then bought a Fuel Pressure Tester and designed a Tee I could connect to tester to and used Clear Tube on either side so I could see if any obvious air bubbles were being pulled from the lift pump to the injector pump. (I temporarily replaced the existing rubber hose that joined the two steal lines between the Lift Pump and the Injector Pump with my T-Connector.)
I turned the key to the on position and observed the pressure reading to be 10 psi. I pushed the bleeder button, but it remained at a constant 10 psi, while the Lift Pump was running.
I turned the key off and bled the pressure down to 0 and repeated the test indicated above. (Same Result, 10 psi.)
Although I am very concerned about damaging the Injector pump, I figured that 10 psi was double the minimum, of 5 psi, so I started the truck and checked it while idling. (Same result 10 psi.)
I took the truck for a test drive and to be honest, it has plenty of power and does not show signs of any problems.
I realize that the P0148 code could be caused by anything starting from the fuel tank all the way to the injectors, but my mind is telling me the issue has to be coming from something before the injector pump and may be electrical in nature, with the following considerations:
1. The Code “Never” clears and continues to occur without ever starting the truck. (i.e. Turn the key to the On position, with the Lift Pump running only. Clear the code, Check Engine Light Flashes, but will not go out. I have used two different tools, one of which was a Snap-On brand with the same result..)
2. The High Pressure Line did fail and caused the engine to die. However the code was not present prior to this issue.
3. The Filter was changed and the Lift Pump holds a constant 10 psi, for the 25 - 30 seconds that it runs in the ON position as well as while the engine is running.
4. I realize that an unplugged sensor could cause an error to be thrown, so I have checked to see if I inadvertently disconnected any plugs near the Fuel Rail System or the injectors and they all look to be connected.
5. I have unplugged and re-plugged the three connectors I found on the Lift Pump and Fuel Water Separator housing. I have also visually looked at the wires going to the Injector Pump, but they all appear to be fine.
Although I may be wrong and my logic might be flawed, but it seems to me that Injector Pump Pressure and Injector issues should throw a code after the engine starts or at least allow me to clear the codes before reoccurring after the engine has started. Although I would not expect getting diesel on any of the plugs, found in this area, should cause an error code of this nature, I am still trying to determine the timing of the code since it only occurred after the fuel line let go.
Is there any chance I could have caused this code when I removed and replaced the Fuel Filter? I do not see how, but check engine light was not on prior to the line letting go...
Anything constructive would be greatly appreciated.
Thank you in advance for your time.
BHinote is offline
Old 03-17-2009, 04:56 PM   #2 (permalink)
Sounds like you are dealing with a really elusive gremlin! Your expertise is likely way above mine, but I would start with the simple and cheap stuff first. I'd get a spray can of electrical contact cleaner and go over all the connections (sensors etc) that might have been sprayed with fuel when the line let go. Maybe even leave them unplugged after cleaning to allow a good dry-out. Also (if you haven't already done so) disconnect the batteries for at least 30 minutes and see if the code clears or resets.
Good luck!
'06 Ram 3500 4X4 QC CTD 6sp LB
'01 F350 PSD 4X4 6sp Crew Cab (sold)
'68 F250 C/S 4X2 C6/428PI
Stidham 24' enclosed car hauler
Bunch of big old cars
In theory, practice and theory are the same.
In practice, they are not.
Packard8 is offline
Old 03-19-2009, 03:39 AM   #3 (permalink)
Packard8, Thank you for taking your time to read and reply with constructive Ideas.
At one time I too had considered using Contact Cleaner on all the connectors, as you suggested. However I honestly got so wrapped up in the "Diagnostic" research that this idea simply vanished from my mind. :-) Thank you for knocking on this door. I will give it a try and see what results it may produce.
Disconnecting the batteries was a good idea as well, but unfortunately I have already tried this one to no avail. However, the good news is the battery posts have now been cleaned.
Thanks again for your time.
BHinote
BHinote is offline
Old 03-21-2009, 12:48 AM   #4 (permalink)
Follow-Up
Since my last post I have now completely disconnected all electrical connectors found between the common rail and the injectors as well as the connectors associated with the Lift Pump and Fuel Seperatore Housing. I then spraied each side of the connectors with Contact Cleaner and allowed them to dry, before plugging them all back in. Unfortunately this did not resolve my problem either.
I took the truck for a spin and again it feels like it is running as it should, but the P0148 code simply will not go away.
Hello... Anyone else out there besides Packard8 amd myself? Am I really going to have to take my truck to the Dealer and trust them to solve this problem? (Dang... There went the neighborhood.)
BHinote is offline
Old 03-22-2009, 10:19 AM   #5 (permalink)
try these sites Dodge Cummins Diesel Forum Dodge Diesel - Diesel Truck Resource - Cummins - Home
04.5 2500 SLT 600 auto QC 4x4 3.73 Autometer Phantoms Protech box Truck Pics
Sold: 99 PSD
PowerStroker1234 is offline
Old 03-22-2009, 11:31 AM   #6 (permalink)
chuckster57's Avatar
P0148 is "fuel delivery" and when I looked it up, one possible cause was a severly restricted fuel filter and/or severly restricted fuel supply line. I see that you did replace the filter. Maybe there is a bunch of crud that "busted" loose and is stuck in the fuel line between the filter and the IP. might want to disconnect line starting at the IP and blow it out with a rag on the other end to see what might dislodge. Ou could have to work your way all the way back to the tank(s)
1997 Jayco 323RKS fifth wheel w/2 slides, Air Lift 5000 bags
Train Horns: Pictures here
PM please not visitor message
chuckster57 is online now
Old 03-22-2009, 04:26 PM   #7 (permalink)
PowerStroker1234, Thank you for suggesting the links. I will give Diesel Truck Resource a try, as I already posted on the Cummins Diesel Forum and received Zero Replies... :-(
BHinote is offline
Old 03-22-2009, 04:34 PM   #8 (permalink)
Chuckster57, I will see if I can disconnect the line and check for crud, as I have not done this yet. However, I still can't help but think 10psi, after the Lift Pump, proves it is able to sustain more than the minimum requirement of 5psi and the code is present even when I never start the truck... I suppose it is still worth a look.. Thank you.
BHinote is offline
Old 09-14-2009, 08:21 PM   #9 (permalink)
Hey Brother, I got that code going on too. I have read everything i can find on it and it is so generic in nature that it could be almost anything from a leaky injector to a fuel burp. My bullydog clears the code, i drain a small bit of fuel from the filter and go another hundred miles till the DTC comes back. About priming after filter change or draining fuel; you need to bump the starter, wait 15 secs.,turn key off. Turn key on to bump the starter again and after 15 secs. it's readt to go. Sorry can't be more helpful.
jim dandy is offline
Old 09-14-2009, 08:22 PM   #10 (permalink)
Sounds like the code is not really being cleared.
Old 09-14-2009, 08:27 PM   #11 (permalink)
One more thing- Autozone can put a scanner on your rig and give you the option of clearing that code. FOR FREE!
Old 09-16-2009, 04:04 PM   #12 (permalink)
Jim Dandy,
Thank you for your Suggestions and Comments.
Although my Lift Pump was putting out 10 psi, I finally took the truck to the dealer and they replaced the Lift Pump indicating it was bad.
After they did this, the issue has never returned. (Doesn't make sense as 10 psi was more than the 5 psi minimum, but the problem has been resolved and that was my main objective. ;-) )
By the way, I also found out that the 2004 injector pumps are not the ones that can burn out because of a bad lift pump. This as an issue with prior year models...
Thanks again...
Last edited by BHinote; 09-16-2009 at 04:09 PM. Reason: I forgot to comment about new Injector Pump details
BHinote is offline
Old 09-17-2009, 07:30 PM   #13 (permalink)
Thanks Brother, Looks like I can now justify a F.A.S.S system without risking a divorce.
Old 09-17-2009, 09:52 PM   #14 (permalink)
Red face
Here's the deal, It appears that my bullydog triple dog programmer is setting the CEL P0148. I thinks maybe me needs to to add an additional fuel mod to this here sucka, or don't run the fuel box. Quandary to say the least.
Old 09-21-2009, 04:56 AM   #15 (permalink)
Fuel Control Actuator
Jim Dandy,
I apologize, but after receiving your latest reply I noticed that I had inadvertently left out an additional part the dealer also replaced.
In addition to the “Fuel Lift Pump”, they also replaced the “Fuel Control Actuator” (FCA).
Since the FCA in and of itself has also been identified as a possible cause for the P0148 code, I would be very remorse if I did not bring this to your attention as well.
Because you mentioned the “Bull Dog” Programmer appears to be setting the code, I wonder if your FCA may be defective and the Programmer is simply causing it to go out of its acceptable range. (Please run this idea past Bull Dog Support, as I would not want to cause a Divorce or any unnecessary expense if this did not fix the problem.)
BHinote is offline
