Go Back   Diesel Forum - The Diesel Stop.com > Other Topics > General Diesel
Old 06-09-2008, 06:53 PM   #16 (permalink)
Originally Posted by Kaliburz View Post
What I meant by 'jewl' is in regards to fuel economy......
I see what you mean. It should be, assuming it can be made to "go."
Jerry/MT: if you can find those books, I'll buy them.
Henry
The Fleet:
*1996 F-250: 7.3l Turbodiesel, Auto, 4x4, Extended Cab; air bag springs, Tymar air intake, Goodyear SilentArmor Pro 285/75/R16s, otherwise stock.
*1999 Escort LX, auto, AC, stock.
*1985 Escort diesel, 5-speed, stock.
Steelehc is offline
Old 06-10-2008, 11:46 AM   #17 (permalink)
Henry
So far I've found the wiring diagrams, the electrical and vacuum troubleshooting guide, and the Emmission Diagnosis volume. I'll keep looking as I know I bought a whole set.
Jerry/MT is offline
Old 06-10-2008, 08:27 PM   #18 (permalink)
Well, like I said, I'll buy them all from you, assuming you can find them. Where are you located at?
Henry
The Fleet:
Steelehc is offline
Old 06-11-2008, 01:21 PM   #19 (permalink)
Henry
I'm just north of Missoula, Montana in the Mission Valley.
Jerry/MT is offline
Old 06-11-2008, 01:31 PM   #20 (permalink)
My neighbor gave me an 84 escort with a 4-speed several years ago. He said it got over 50 mpg on the highway. I recall he said it had 1.4 L Isuzu diesel, but that was a few years ago and he might of been wrong or my memory has failed.
I gave it to a friend (this was when the diesel for my F250 was $1.50/gal) and a few months later the freeze plug vibrated out. He roasted the engine and scrapped the car.
Check the freeze plug and Keep an eye on the temp gauge.
Woollybob is offline
Old 06-11-2008, 01:34 PM   #21 (permalink)
This is a Mazda 2.0L. Thanks for the advice, though.
Henry
The Fleet:
Steelehc is offline
Old 06-11-2008, 01:35 PM   #22 (permalink)
That's a little far, but well within postal service range. Let me know when you've got them, and we'll work out a price.
Henry
The Fleet:
Steelehc is offline
Old 06-12-2008, 11:26 PM   #23 (permalink)
So... bad news.
We got the motor to turn over yesterday, but it sounded real bad. Really weak and slow, almost like it was only firing on one cylinder.
Turns out, it was only firing on one cylinder. No compression in two of them, only a little bit in the third.
Are there any things to look for at this point? Any other possible solutions?
Henry
The Fleet:
Steelehc is offline
Old 06-13-2008, 12:45 AM   #24 (permalink)
Well, at least now we know why it was abandoned and left on the side of the road....
When you got it running, did you remove the oil fill cap and observe the 'blow by' coming from the engine? Sometimes you can tell how bad it is by watching that or the breather....
Depending on how much you want to spend, the next move is really up to you. I'm going to hazard a guess that it could be valves or rings. If you have a leak down tester, it might help narrow it down. I'm not familiar if this motor is an over head cam type or not....
Which two cylinders had no compression?
1999 E-350 Cub Wagon, 7.3L Power Stroke, E4OD, 3.55
1990 E-350 Club Wagon, 7.3L IDI, E4OD, 3.54LS
1983 F-150 2x4, 4.9L, C-6 w/GV-OD, 3.55 Farm pickup
1981 C-8000, 3208 CAT, RT-6510, Rockwell SSHD Tandems (Swap)
1977 K100C, NTC-350, RT-1110, Tandem
1977 Transtar II, NTC-290, RT-9509 Single
1977 Transtar II, Formula 290, RT0-9513, Tandem
1974 C-750, 391CID, Clark 5 speed, Eaton 2 speed
Kaliburz is offline
Old 06-13-2008, 01:46 AM   #25 (permalink)
bockhold's Avatar
Send a message via AIM to bockhold
how many cylinders does it have??
Jarrod
NRA member
1997 F350 4door 2wd long bed white 7.3L Powerstroke, E4OD, C5 4:10LS diff 326K miles on org engine
and is being repaired
bockhold is offline
Old 06-13-2008, 03:09 AM   #26 (permalink)
Kaliburz: No, we didn't pull the oil cap off. It was pushing the dipstick up and down, though.
I'd like to get her running, but I'd rather not spend much more than, say, $1,000 or $1,500 or so. It is an overhead cam. Cylinders 1 and 2 from the left have no compression, and 3 has a little. 4 seems to work.
Bockhold: It's a straight-4.
Henry
The Fleet:
Steelehc is offline
Old 06-13-2008, 06:07 AM   #27 (permalink)
Banned
....... but it was impounded for being abandoned in the roadway,.........
Is this why they call it a FoundOn Road Dead??
MaxHuey is offline
Old 06-13-2008, 01:58 PM   #28 (permalink)
Evidently so. I was hoping I could turn it into something that would be First On Race Day. At least, in fuel economy terms.
Henry
The Fleet:
Steelehc is offline
Old 06-13-2008, 03:25 PM   #29 (permalink)
bockhold's Avatar
Well good luck on the rebuilding process. Sounds like a summer project to keep you busy.
Jarrod
NRA member
bockhold is offline
Old 06-13-2008, 04:42 PM   #30 (permalink)
Rebuild it! There's virtually nothing on the market now that is cheap and gets that kind of MPG. Especially diesel. Couple guesses, it overheated and warped the head (usually will use water, or loose compression between two cylinders) or just a plain old bad head gasket (diesel = higher compression and some of the early car diesels were converted gassers...).
2005 Volvo S40 T5
2001 Dodge 2500 Cummins
1987 Mercury Grand Marquis
1974 International 100 4x4
1931 Caterpillar #9 Auto Patrol Motor Grader
Forcus is offline
