Go Back   Diesel Forum - The Diesel Stop.com > Other Topics > General Diesel
Old 06-13-2008, 05:26 PM   #31 (permalink)
these engines wore out the rings at about 250,000---or less--had three diff ones---and none of them ever took out a head gskt--money says do a cheap rering job--and throw it back together--also---sometimes the valves got tight--and wouldnt close--there went the compression-----and dont go milling the head if its warped--it screws up the timing with the belt arrangement--
94_turbo is offline
Old 06-14-2008, 04:34 AM   #32 (permalink)
We're going to run a leak test, to try to see if it is the rings or valves or what.
If it's just something simple like that, then great, we're good to go. If not, I have a secret backup plan. I've found another engine for sale in a scrapyard. A full long-block, less than 100K miles, and, the best part, it's "guaranteed." I don't know what the guarantee consists of, but I do know it runs, so if this one is a wash, then all's not lost for this car.
Henry
The Fleet:
*1996 F-250: 7.3l Turbodiesel, Auto, 4x4, Extended Cab; air bag springs, Tymar air intake, Goodyear SilentArmor Pro 285/75/R16s, otherwise stock.
*1999 Escort LX, auto, AC, stock.
*1985 Escort diesel, 5-speed, stock.
Steelehc is offline
Old 06-14-2008, 12:42 PM   #33 (permalink)
Originally Posted by Steelehc View Post
So... bad news.
We got the motor to turn over yesterday, but it sounded real bad. Really weak and slow, almost like it was only firing on one cylinder.
Turns out, it was only firing on one cylinder. No compression in two of them, only a little bit in the third.
Are there any things to look for at this point? Any other possible solutions?
Henry
If you have some compresion like 250 -200 psi, I'd say you had a problem with the rings. The compresion should be something like 400-500 psi. if you get like 50 psi, your valves are most likely burned or open.
Have you pulled the valve cover to see if the valve springs are intact and crank it so see if the valves are opening and closing?
Jerry/MT is offline
Old 06-15-2008, 03:06 PM   #34 (permalink)
I know a guy who has one who gets something like 50mpg.
99(4/99)F350 PSD 4X4 crew cab long bed dually lariat isspro triple pod air bags with compressor
99(6/99)F250 PSD 4X4 X-cab short bed xlt 5in str8 piped air bags autometer ultra light triple pod junk yard pcm running 22 psi 250k miles bought 8/15/01 w/40k miles first diesel
00(12/99)Excursion PSD 4X4 limited
65 Mustang 289 V8 4brl 69 GTO 400 4spd 99 Neon R/T
04 and 09 PJ 15k dump trailer 04 H&H 9K tilt bed 98 Haulmark 7x14 enclosed
86GLHS is offline
Old 06-16-2008, 01:56 AM   #35 (permalink)
If it were I, I would prob. buy the other motor and have it...... but that's just me though.
1999 E-350 Cub Wagon, 7.3L Power Stroke, E4OD, 3.55
1990 E-350 Club Wagon, 7.3L IDI, E4OD, 3.54LS
1983 F-150 2x4, 4.9L, C-6 w/GV-OD, 3.55 Farm pickup
1981 C-8000, 3208 CAT, RT-6510, Rockwell SSHD Tandems (Swap)
1977 K100C, NTC-350, RT-1110, Tandem
1977 Transtar II, NTC-290, RT-9509 Single
1977 Transtar II, Formula 290, RT0-9513, Tandem
1974 C-750, 391CID, Clark 5 speed, Eaton 2 speed
Kaliburz is online now
Old 08-27-2008, 12:59 AM   #36 (permalink)
Diesel pump bench test
Injector malfunction is also a potential common cause for black smoke as is incorrect engine timing. For example in a two cylinder engine, if you have one bad injector, the system cannot develop the RPM to burn the fuel called for since the properly fueled injector is working against an essentially dead or less than efficient cylinder. A poor cylinder will put out black smoke if it is getting fuel because compression problems prevent complete combustion. The good cylinder will put out smoke because it is being supplied more fuel than it can effectively use. you may be advised to remove the injectors and have them checked at a competent shop.
Aniecruz
http://www.hookup-tonite.com
Aniecruz is offline
Old 09-29-2008, 03:19 AM   #37 (permalink)
Re: Ford Escort Dieselr
The Ford Escort 1.8 was ranked the highest in the J.D. Power and Associates 1997 Indian Customer Satisfaction Study. It was also voted the Best Quality Car in the J.D. Power India Initial Quality Study.
williamgeorge
Car Auctions
williamgeorge is offline
Old 10-15-2008, 08:22 PM   #38 (permalink)
I had an 84 escort diesel for 10 years, and put over 130k miles on it before my wife let a full-serve gas station attendent put gasoline in it. It lasted for a while after that, but ended up with a cracked head. I HATED to let that car go; it was the best car I ever had, before or since. 55mpg on the highway when it had 120k on it (60 when just broken in), and 40+ commuting 12 miles back and forth to work. Never had a problem starting it even 10 below zero (fahrenheit), because of the high power glow plugs, and separate battery that supplied them.
LOVED that car, and would love to get another one if I could find one in decent condition. Anything you want to know about routine maintenance and stuff, let me know; I never had to do any internal engine work, or any major work on the chassis, just normal maintenance (struts, brakes, etc). Not even a clutch replacement.
archer1960 is offline
